Welcome to the RAS Solution Forums HEC-RAS Help How to export an Assembly canal from Civil 3D to HEC-RAS
  • This topic has 2 replies, 123 voices, and was last updated 6 years ago by Anonymous.
  • #7460
    I am developing a Trapezoidal Canal for a college homework, but I’m having problem to export my assembly to hec-ras. When I click on Export to Hec-Ras it asks me to select the river banks, but when I select my geometry it says that there is no polyline.
    What am I doing wrong?
    How should I proceed?
    Thanks in advance.
    Greeting from UFRGS!
    #12540
    I’m experiencing the same problem!
    #12541
    hasansins
    Hi Igor. You need to create sample lines and sample the surface of your channel. Only then you can export it to hec ras. As for selecting bank lines it is optional you dont have to define it to export geometry.
