Welcome to the RAS Solution Forums HEC-RAS Help How to call the HEC-RAS model in external program? Detailed things inside. Thank you!
  • This topic has 2 replies, 303 voices, and was last updated 10 years ago by Anonymous.
  • #5944
    I want to do the optimization problem. Now, I need to programming the optimization algorithm in MATLAB, and I need give the input data and run the HEC-RAS model externally.
    Which exe. or other file could be called in HEC-RAS???
    Thanks for your answer.
    #9574
    mat A.
    You must open your file projet *.r01 with steady.exe
    #9575
    I try to run the *.b01 file with Unsteasy.exe by cmd. But It terminate strangely with a file(this file has the same name like the project name, but without any extension,and I checked the file, it is 0 kb)
    If you are good at this field can you contact me by email?
    [email protected]
