Welcome to the RAS Solution › Forums › HEC-RAS Help › how can i calculate the necesary flow to reach a given water table?
- This topic has 1 reply, 236 voices, and was last updated 11 years, 2 months ago by David Corta.
February 3, 2015 at 2:04 pm #5691David CortaParticipant
I need to do the inverse of the tipical hec ras calculation, I need to find a proper flow that reach a given water table height. Do anyone knows i could do it? Thanks.
February 3, 2015 at 2:20 pm #9095Chris G.KeymasterReturn-Path:
Received: from mail-we0-f170.google.com (mail-we0-f170.google.com [74.125.82.170])
by mwork.nabble.com (Postfix) with ESMTP id AF9A812A8ECE
for; Tue, 3 Feb 2015 02:21:11 -0800 (PST)
Received: by mail-we0-f170.google.com with SMTP id w55so38603672wes.1
for; Tue, 03 Feb 2015 02:21:03 -0800 (PST)
d=gmail.com; s=20120113;
bh=7r3D6KDqx9IXVEoebvKtQEpUsqX94V0R/919ezcgA7w=;
b=v9CEtCuRrRBHINAwNDtXmyjyBugpi82Plnwp33AlGfSDWIZyt2nws3uaHLBFQIUE8U
Xk/YCxs3RFqs3t0PVKFO74Hu7ba3UpKdDGkclwELcd9lLZAz9w2kNkbD25AA15s6Fm8I
Xf+Ky3ghqt/8AdbHzAdZhbTuC4IBaETurzkBJrUgD7+NjPqDrFpCAar1eZTsBwkJeWZ8
47uy7NtJygZJIcAgKU2YyhUbGBeNQSMYKNkrRc00j7gVP5YSz/Z+kUaNxNlsM3mwshIl
bu4hFtOn6h3lj7Hv6Ax/xMmxd3920tkL7o+9f1dG0UCra4o3c3vTDshR79RVRYDGpxe2
sp9w==
X-Received: by 10.180.210.203 with SMTP id mw11mr19072374wic.53.1422958863539;
Received: from [196.249.0.236] ([196.249.0.236])
by mx.google.com with ESMTPSA id mx4sm23907429wic.24.2015.02.03.02.21.02
for
Tue, 03 Feb 2015 02:21:02 -0800 (PST)
Subject: Re: how can i calculate the necesary flow to reach a given water table?
boundary=Apple-Mail-712AAFC4-E33D-4AB2-B24C-61F35B9E7493
X-Mailer: iPhone Mail (12A405)
Date: Tue, 3 Feb 2015 12:20:59 +0200
To: “David Corta [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-712AAFC4-E33D-4AB2-B24C-61F35B9E7493
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableTrial and error. That’s the only way.=20
Sent from my iPhone
> On Feb 3, 2015, at 12:04 PM, David Corta [via HEC-RAS Help]
wrote:
>=20
> I need to do the inverse of the tipical hec ras calculation, I need to fin=
d a proper flow that reach a given water table height. Do anyone knows i cou=
ld do it? Thanks.=20
>=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/how-can-i-calculate-the-necesary=
-flow-to-reach-a-given-water-table-tp1284.html
> NAML–Apple-Mail-712AAFC4-E33D-4AB2-B24C-61F35B9E7493
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitTrial and error. That’s the only way.Sent from my iPhone
On Feb 3, 2015, at 12:04 PM, David Corta [via HEC-RAS Help] <[email protected]> wrote:I need to do the inverse of the tipical hec ras calculation, I need to find a proper flow that reach a given water table height. Do anyone knows i could do it? Thanks.
If you reply to this email, your message will be added to the discussion below:To unsubscribe from HEC-RAS Help, click here.
NAML
–Apple-Mail-712AAFC4-E33D-4AB2-B24C-61F35B9E7493– -
