Welcome to the RAS Solution › Forums › HEC-RAS Help › High water columns. Why?
  • #6200
    amgeda
    I got very high water columns (>50m difference to main channel) at the border to 1D/2D Elements. The Simulation was stable and there was no error detected. Do u have any idea of the reason behind these columns?
    Thanks for your help.
    #10080
    Lonnie A
    I’m assuming you ran V5.0.2 and used the 2D equation on the lateral weirs. There is a bug that HEC has confirmed. If you use the weir equation with a low C-value you’ll not have these “boils”. Hopefully they will have the bug fixed in the upcoming 5.0.3 release.
