Welcome to the RAS Solution Forums HEC-RAS Help High flow analysis
  • #5756
    cuba28
    Hello everybody,
    Please, could any one help me ? I would like to know how to select just the high flow analysis as a bridge modeling approach for modeling bridges ?
    After trying, the model can’t be run because I received a message error telling that bridge coefficients must select at least one low flow method…
    Thanks in advance,
    Regards
    #9220
    Keymaster
    If you are only running under high flow conditions, just pick anything for low flow. It won’t be used, but at least you can get the model to run.
