Welcome to the RAS Solution › Forums › HECRAS Controller › Help using “Output_NodeOutput”
- This topic has 1 reply, 65 voices, and was last updated 5 years, 7 months ago by SILVIA HEREDIA.
August 12, 2020 at 8:19 am #8251SILVIA HEREDIAParticipant
Hi Everyone
I’m new using the HeCRASController, I would like to use it to retrieve the result of a node section (the elevation) after running an unsteady file model but I don’t understand how to get the node ID number “n”.
for this function.
Does anyone know how to do that?
Thank you!!August 15, 2020 at 9:11 am #13621Chris G.KeymasterReturn-Path:
by sloti21d1t10 (Cyrus 3.3.0-185-g038a4a3-fm-20200813.001-g038a4a3b) with LMTPA;
Sat, 15 Aug 2020 01:11:16 -0400
X-Cyrus-Session-Id: sloti21d1t10-1597468276-2938420-2-13895329716945736874
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-sender-reputation: 500 (none)
X-Spam-score: 0.1
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_SENDERREP_NEUTRAL 0.001,
MIME_QP_LONG_LINE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
RCVD_IN_MSPIKE_H3 0.001, RCVD_IN_MSPIKE_WL 0.001, SPF_HELO_NONE 0.001,
SPF_PASS -0.001, URI_HEX 0.1, LANGUAGES en, BAYES_USED none,
SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.216.49′, Host=’mail-pj1-f49.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
by compute1.internal (LMTPProxy); Sat, 15 Aug 2020 01:11:19 -0400
by mailmx.nyi.internal (Postfix) with ESMTP id 8DC343C00E4
for; Sat, 15 Aug 2020 01:11:18 -0400 (EDT)
id BED1B042E0D;
1597468278; b=BT8qwwzAMu2yFOaFSv+D0TDzRzMnHmKPxbtrRqQsEWNkN11oR7
qd9Lo1HhOOc6NFeEPsDW720dlI+99gkPetoATdy99DwHOLCqrpMRSK7MUejVAivC
QxBypbLVlSVydRjlgjO0lRjlVZXjZiLzg0gAmfmvNHBA6PMjDpZsoyCGivzJsxrs
7NKxFl2O0c9VaMqqZOGa98VCZt5VWPsW1wRU0yjJVn4jqFVaintTVmg0L1bmflKI
80iOSrzXCQBk0lwNENbe7kqlsOlBSOf4SGKRjRYhg1hOI5S2zu+rV6pMbHdB3G33
tQoCAYu1X2N86KngojWw8Jz7Ad+zoy/B8sXQ==
messagingengine.com; h=content-type:content-transfer-encoding
:from:mime-version:date:message-id:references:in-reply-to
:subject:to; s=fm3; t=1597468278; bh=HrVZRltaE8uPlcD+VboAzitwXM3
DRxhSxk6NAypaqNY=; b=arU7aqNgC2YTBvbSLwItQQHag2+EgQ2MaQ6PJ8oMJdy
8pu5aXwXgw4GE11/9YgPJ9M4LTdSJGzDKDQHKkl/UAXX50vi0L4rpuiRF36aUDq2
P1ortASVCaeMfjv+73A9MxyNI35xos6/T0xcsdw4ryg70TiK2Dx+npsSrmbAsO8m
DiiGr+1BaDAgt9k+1XxAfWVPu9mYX2qtUc55Cj+TAZowkvNnNmM4E1d+0lj4nX3B
0BkGvkJh0PSPcEkIuTh2COlI6sugG8UtNUfIjfKPkZK72TTFMVPMp81oigI/txtS
UO2C8EiQTtYrXw3+PoXYOUptObllirTiQxMxd6rrvaw==
bimi=none (Domain is not BIMI enabled);
[email protected] header.b=QuUW2o+a header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.216.49 (mail-pj1-f49.google.com);
spf=pass [email protected]
smtp.helo=mail-pj1-f49.google.com;
[email protected] header.b=clkOa0oT;
x-ptr=pass smtp.helo=mail-pj1-f49.google.com
policy.ptr=mail-pj1-f49.google.com;
(MX Records found: alt3.gmail-smtp-in.l.google.com,alt4.gmail-smtp-in.l.google.com,alt1.gmail-smtp-in.l.google.com,alt2.gmail-smtp-in.l.google.com,gmail-smtp-in.l.google.com);
smtp.bits=128/128;
x-vs=clean score=0 state=0
smtp.bits=128/128;
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0x
MTg0JmNvZGU9ZEdobGNtRnpjMjlzZFhScGIyNUFaMjFoYVd3dVkyOXRmREV4T0RSOE1URT
NORGc1TkRneE5RPT0
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgeduiedrleekgdelgecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgdpuffr
tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecunecujfgurheptgfghfggff
fkfhgjuffvofesrgejmherhhdtjeenucfhrhhomhepvfhhvgcutfetufcuufholhhuthhi
ohhnuceothhhvghrrghsshholhhuthhiohhnsehgmhgrihhlrdgtohhmqeenucggtffrrg
htthgvrhhnpeefudetvdegkeelgeffvdekueduheeftdeuvddtheeitdehudelgfegheek
teeuueenucffohhmrghinhepnhgrsggslhgvrdgtohhmnecukfhppedvtdelrdekhedrvd
duiedrgeelpdejuddrudelfedrvdefiedruddufeenucevlhhushhtvghrufhiiigvpedt
necurfgrrhgrmhepihhnvghtpedvtdelrdekhedrvdduiedrgeelpdhhvghlohepmhgrih
hlqdhpjhduqdhfgeelrdhgohhoghhlvgdrtghomhdpmhgrihhlfhhrohhmpeeothhhvghr
rghsshholhhuthhiohhnsehgmhgrihhlrdgtohhmqecuuffkkgfgpeeijedvfe
X-ME-VSScore: 0
X-ME-VSCategory: clean
Received-SPF: pass
identity=mailfrom;
client-ip=209.85.216.49
Received: from mail-pj1-f49.google.com (mail-pj1-f49.google.com [209.85.216.49])
Received: by mail-pj1-f49.google.com with SMTP id mt12so5337932pjb.4
for; Fri, 14 Aug 2020 22:11:18 -0700 (PDT)
d=gmail.com; s=20161025;
h=content-transfer-encoding:from:mime-version:date:message-id
:references:in-reply-to:subject:to;
bh=HrVZRltaE8uPlcD+VboAzitwXM3DRxhSxk6NAypaqNY=;
b=QuUW2o+aTnVVsELBNXDjs9gFMc57RcvRLNQPWCGj9k+dXSnI4esKU/zckqUX7p9V+i
Pz4HdVi9hi+cXbtvJS6evNrl3LWvPRVgRdiOnoN9QYs5/lQVfnBCGKBwHKcgyPflpaof
VIfit+DiowzwcmlTS4Ay8zoXx3gJrvWwH/p7ft0EeGdSOCgnNNo7H8kgotgPoudbxg2x
x1MHP05h4UxWX94qemEIgQ/Iut2oe3XqZMK6CFlEDopRfwjkllw51kh3/QPVqrpkfBu4
zwzNoTgAHEfXk3Q1zufk1axO9zlwDzANcgD8H2FHxje5WKbrcm6vz2NnhFHOh8bzBet4
qKJA==
d=1e100.net; s=20161025;
h=x-gm-message-state:content-transfer-encoding:from:mime-version:date
:message-id:references:in-reply-to:subject:to;
b=clkOa0oTnCxfoqQckCuSslF69i0qgaWGPmpqo+XyizXW0nbjWWrK9dhnwBhWk4QFhH
lB+PU1Qu8kv/zMPyAIJ6MDGYZaJ3AcAeO5/s75PZebsLDGpCOyHZL3KSB4iSkYHX5u/+
BfG1ItpcPqrp9bHuz7xgPB0sNc2qLnesD3dQoJej1Kpgoar1O+PpTsThtrBUdwZulPUP
E6ZAiFye5pn5BYZD4Fo7ojgdKsOE8CCe1SHcyXH9Aj8HOQbsmKTxRzhg/RW1p2UrjCda
RL197GRBswvSYGIM2ya2f+n54HnXDg4urCWCxob9J42ndyvA2Eq5jIzm6HOcEvqONjTQ
BdPg==
X-Gm-Message-State: AOAM532TU+HZytqLNAVQAFzDJ6jcxR44z/Iv72vaelaI8z6+L5rVGfCH
dJQ7+jjpR+McA/t0MogDFwjJc/XB3b3vrg==
X-Google-Smtp-Source: ABdhPJx/cTgIg7iRvW54FCGDLVmVNZrbz6iZ697DYPD+2dqpV6xQJOyrhg2CE1z8uziVPYABQxtkIg==
X-Received: by 2002:a17:902:ba8e:: with SMTP id k14mr3288668pls.256.1597468275866;
Fri, 14 Aug 2020 22:11:15 -0700 (PDT)
Received: from [192.168.1.29] (c-71-193-236-113.hsd1.or.comcast.net. [71.193.236.113])
by smtp.gmail.com with ESMTPSA id j13sm10896067pfa.149.2020.08.14.22.11.15
for
(version=TLS1_3 cipher=TLS_AES_128_GCM_SHA256 bits=128/128);
Content-Type: multipart/alternative; boundary=Apple-Mail-6D8C547F-E3FB-4D6A-9945-85C203200F6D
Date: Fri, 14 Aug 2020 22:11:14 -0700
Message-Id:
Subject: Re: Help using “Output_NodeOutput”
To: “SILVIA HEREDIA [via HEC-RAS Help]”
X-Mailer: iPhone Mail (17G68)–Apple-Mail-6D8C547F-E3FB-4D6A-9945-85C203200F6D
Content-Type: text/plain;
charset=utf-8
Content-Transfer-Encoding: quoted-printable=46rom the profile table, if you select Options, define table, you=E2=80=99l=
l see a list of variables you can select. The number next to the variables i=
n this list is the number to use for n.=20Sent from my iPhone
>> On Aug 11, 2020, at 9:19 PM, SILVIA HEREDIA [via HEC-RAS Help]
wrote:
> =EF=BB=BF Hi Everyone=20
> I’m new using the HeCRASController, I would like to use it to retrieve the=
result of a node section (the elevation) after running an unsteady file mod=
el but I don’t understand how to get the node ID number “n”.=20
> for this function.=20
> Does anyone know how to do that?=20
> Thank you!!=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Help-using-Output-NodeOutput-tp9=
119.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-6D8C547F-E3FB-4D6A-9945-85C203200F6D
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: quoted-printable=46rom the profile table, if y=
ou select Options, define table, you=E2=80=99ll see a list of variables you c=
an select. The number next to the variables in this list is the number to us=
e for n.Sent from my iPhoneOn Aug 11, 2020, at 9:19 PM, SILVIA HERED=
IA [via HEC-RAS Help] <[email protected]> wrote:=EF=BB=BFHi Everyone
I’m new using the HeCRASController, I would like to use it to retrieve t=
he result of a node section (the elevation) after running an unsteady file m=
for this function.
Thank you!!=09
=09
=09
If you reply to this email,=
your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.co=
m/Help-using-Output-NodeOutput-tp9119.html
To start a new topic under HECRAS Controller, email ml+s109=
[email protected]
NAML=
–Apple-Mail-6D8C547F-E3FB-4D6A-9945-85C203200F6D–
