when to apply DSS?
Working on a stream where uppermost section is beginning where very little flow is generated?
On a stream where the flow at uppermost section is receiving a strong flow?
Can you use it for both steady and unsteady in the same model?
I had a problem with adding the dss but fixed that (helps to read the help thoroughly ha). The beginning water surface elevation is decent, but the ending is much to low. I added the flow to the beginning section only. Should I add it to the end also? I am not sure the best practice of spreading the flows throughout the river.
