Welcome to the RAS Solution › Forums › HEC-RAS Help › HELP!!! HEC Ras Error Subroutine HDF_OPEN_LAT
- This topic has 3 replies, 965 voices, and was last updated 8 years, 2 months ago by Anonymous.
December 19, 2017 at 9:37 am #6735AnonymousGuest
While computing unsteady simulation, i have having this error, please help if any body know about this.
#000: ..\..\src\H5G.c line 310 in H5Gcreate2(): unable to create group
major: Symbol table
#001: ..\..\src\H5Gint.c line 194 in H5G__create_named(): unable to create and link to group
major: Symbol table
#002: ..\..\src\H5L.c line 1638 in H5L_link_object(): unable to create new link to object
major: Links
#003: ..\..\src\H5L.c line 1882 in H5L_create_real(): can’t insert link
major: Symbol table
#004: ..\..\src\H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal failed
major: Symbol table
minor: Object not found
#005: ..\..\src\H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator failed
major: Symbol table
minor: Callback failed
#006: ..\..\src\H5L.c line 1674 in H5L_link_cb(): name already exists
major: Symbol table
minor: Object already exists
#000: ..\..\src\H5D.c line 170 in H5Dcreate2(): unable to create datasetWriting Results to DSS
major: DatasetComputations Summary
Completing Geometry 14
Preprocessing Geometry(64) <1
Writing to DSS(64) <1
Complete Process 15January 2, 2018 at 5:53 pm #11123AnonymousGuestI have same issue while simulating an unsteady flow analysis. Can anyone guide me on this?
Subroutine HDF_OPEN_LATHDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0:
major: Symbol table
major: Symbol table
major: Links
major: Symbol table
major: Symbol table
major: Symbol table
major: Symbol table
major: Dataset
#001: ..\..\src\H5Dint.c line 439 in H5D__create_named(): unable to create and link to dataset
major: Dataset
major: Links
major: Symbol table
major: Symbol table
major: Symbol table
major: Symbol table
minor: Object already existsJanuary 3, 2018 at 11:19 am #11124AnonymousGuestCan we just remove this error by turning HDF5 compression to none? Or by installing HDF5 1.8.20 extension to the back end of setup files? Either directory is missing for HDF_OPEN_LAT or some other issue related to program which makes it unable to call the HDF output file. Is there any way in which we can edit these codes in the back end of the HEC-RAS module?
December 1, 2018 at 9:22 pm #11125AnonymousGuestHas anyone been able to fix this I have the same issue!
