Welcome to the RAS Solution › Forums › HEC-RAS Help › HELP error hec ras
- This topic has 29 replies, 21,111 voices, and was last updated 10 years, 1 month ago by Anonymous.
March 3, 2016 at 3:45 pm #6007AnonymousGuest
Hi everybody
I’m trying to do an Unsteady Flow analysis in Hec-Ras 5.0 (August 2015 version) and I don’t understand why I have this error.Performing Unsteady Flow Simulation HEC-RAS 5.0.0 Beta August 2015
+STOP! Error in the time window.
HDF_ERROR trying to close HDF output file:
#000: ..\..\src\H5F.c line 2044 in H5Fclose(): invalid file identifier
minor: Inappropriate type
#000: ..\..\src\H5T.c line 1761 in H5Tclose(): not a datatype
minor: Inappropriate typeI’ve inserted a simple rectangular geometry and meshed it; with an initially condition added with a SA/2D Area BC Lines (the condition is the stage in fuction with the time).
Help me please
🙂March 4, 2016 at 12:21 am #9708Vince MoodyParticipantThe very first line of this error message states that there is an error with the time window. Often this error is a results of an improper date format being used. You may also want to make sure that you’re using “US English” regional settings on your PC. Please review page 8-25 of the User’s Manual for discussion of appropriate date formats.
March 21, 2016 at 8:40 pm #9709AnonymousGuestThaaaaaaaaaaaaaank Yoooooooooouuuuuuuuuu!!!!!
stupid time format cost me two days of staring at an error message!!!
🙂June 22, 2016 at 12:21 pm #9719AnonymousGuestsorry
I have the same problem, could you tell me step by step how you solved the problem? pleaseJune 23, 2016 at 11:10 am #9710AnonymousGuestsorry
I have the same problem, could you tell me step by step how you solved the problem? pleaseJuly 3, 2016 at 1:32 am #9711AnonymousGuestChange date and time setings in control panel to US calendar.
November 28, 2016 at 12:45 am #9712Dimitrios199ParticipantDecember 7, 2016 at 4:54 am #9713[email protected]ParticipantDecember 8, 2016 at 2:09 pm #9714boraParticipantDecember 8, 2016 at 2:30 pm #9715AnonymousGuestYes. The problem is that you are none a US citizen. So, go to your control panel and change the : Region and Language to : English US.
Mine was Greek and i had the same problem.
Hope it is ok!!February 14, 2017 at 5:44 am #9716AnonymousGuestThank you
February 18, 2017 at 2:50 pm #9717boraParticipantJune 27, 2017 at 10:35 am #9732AnonymousGuestHi All,
Any help with this error?
Sediment Transport Capacity HEC-RAS 5.0.0 February 2016
Subroutine HDF_HTAB
#000: ..\..\src\H5G.c line 450 in H5Gopen2(): not a locationComputations Summary
Completing Geometry <1
Sediment Computations(64) <1
Complete Process <1
#001: ..\..\src\H5Gloc.c line 253 in H5G_loc(): invalid object ID
minor: Bad valueJuly 3, 2017 at 5:17 am #9718cameronParticipantThese tell you if the results are converging or diverging.
July 3, 2017 at 5:17 am #9733cameronParticipantAre you using the latest version of HEC-RAS?
