Welcome to the RAS Solution › Forums › HEC-RAS Help › HECRAS 5.0 Beta , Land Classification (Corrupted Shapefile)
  • This topic has 1 reply, 234 voices, and was last updated 11 years ago by Anonymous.
  • #5868
    Hello Forum,
    I developed my first 2D Model and wanted to associate a spatially varying land use to the simulation. The problem is that I create Polygons in ARCGIS, exported them with .shp extension, including a column with text as the landuse, but i always get the message:
    Error: Corrupted Shapefile
    What does that mean? Any hints for a solution??
    Thanks!
    #9493
    Mikell Warms
    Hey MrBarca,
    Can you load the exported shapefile correctly into ArcGIS? Is it in the right projection (i.e. the same one used in RASMapper)?. Sometimes shapefiles can be corrupted due to improper saving, an ArcMap crash, or illegal geometric features.
    There is some ESRI support for corrupted shapefiles here: http://support.esri.com/es/knowledgebase/techarticles/detail/27429
    I’ve also had some luck with this tool:
    http://arcscripts.esri.com/details.asp?dbid=10806
    Good luck!
    -Mikell
