Welcome to the RAS Solution Forums HEC-RAS Help HEC_RAS 2D modeling
  • This topic has 2 replies, 918 voices, and was last updated 8 years ago by Anonymous.
  • #6409
    I’m trying to run a 2D with unsteady flow simulation of the HariRud river in 2D with the HEC-RAS 5.0.1. So, I was working with the geometry, and getting used to the RAS Mapper, but when I try to run the 2D simulation I get this error:
    Writing Geometry
    Computing 2D Flow Area tables: Property tables do not exist.
    Computing 2D Flow Area ‘Downstream-area’ tables: Property tables do not exist.
    Error computing 2D Flow area tables:
    Unable to compute face tables: The terrain associated with this geometry does not completely cover the 2D Flow Area. See face #113556
    #10482
    Chad Ballard
    Seems like your terrain does not cover your entire 2D flow area. Double check that you did not digitize past your elevation extents. If you select a 2D flow area by left clicking there is a “Find Face” tool. You can use it to look for #113556.
    Chad
    #10483
    Try adding points to the mesh at the face point where the error occurs.
