Welcome to the RAS Solution › Forums › HEC-RAS Help › HECRAS 2D
- This topic has 5 replies, 739 voices, and was last updated 9 years, 5 months ago by Sumaiya.
October 20, 2016 at 8:20 pm #6231SumaiyaParticipant
Return-Path:
Received: from mail-it0-f47.google.com (mail-it0-f47.google.com [209.85.214.47])
by mwork.nabble.com (Postfix) with ESMTP id A12B95E0DDC51
for; Thu, 20 Oct 2016 09:20:04 -0700 (MST)
Received: by mail-it0-f47.google.com with SMTP id e187so39378206itc.1
for; Thu, 20 Oct 2016 09:20:04 -0700 (PDT)
d=gmail.com; s=20120113;
h=mime-version:from:date:message-id:subject:to;
bh=OQ4lInDane7tlUCzbFpGa1L7J8Y8DOitGQXRPG0GmX4=;
b=HYVasjK5RsFM5OumiCK8+QbEE1BHzf1bv8cOINw+I6VitQ0+3vn5v2tSKyJGYLXs9i
qcVu1C/IXY2dQ8Q7yr38MXOEVXq1sJFFsHr9EGYBbD64Bp1pTq63soxgneEggtA1LLLD
NtLspTKA52RsAZkTUgIHf1orSLH6PErByDRH9n6geM/TK1gSw89v4xAMGr1g6s/6Z32F
hmg+zGsAfflnoaVGsWKg55CmHbPptPTRqwzemU66D6HV2SiM3pGyggv0DO5XF4F8RoVL
X7xdBHjWQW6jH9B+XVRYVZmnu85DMAseNxWMwuAbj8z1C/ZJuTdZyNWHLw5X5K9FO5hp
4rqw==
d=1e100.net; s=20130820;
h=x-gm-message-state:mime-version:from:date:message-id:subject:to;
b=gkKMB7cDJfsFE1ZD85brsox/mqyg2sC9w+M5cQ7rNz8I5/D0cNflS1qg5AkNPAwoDx
03MM/rOlPz2IksT1P81XwkiGDQc7sGJ5tIoFk1EfamP8blSL0tInCyR4Q4xqFD1DGm9w
+kHZEL2QkyChZ/+LAegvdvtOKq2G24CfdfX50gGYSo141VFrcL742jFXxqBWB9ngBgd0
mqYiCdDv1rc5DB/NQly4Mt0+AL/8VI5Od898TzUywDPAkO0+5r28JHqEK/FMD+cl0IAz
+Akd4IQ2SYpor+LBfHR8+kY197hN5Jn/5164S1/AYZ5J9bxa0B1+i1BlYVkMp/T37Tjh
c4Rw==
X-Gm-Message-State: AA6/9RkUF2iLwsQECBptf966ytXc55SipUDoQXOjQhSlNpKNEtizySIq5BP3CmphM1nP+oD7L8Qn1h0qqqd0Kw==
X-Received: by 10.36.2.211 with SMTP id 202mr1716791itu.35.1476980404043; Thu,
MIME-Version: 1.0
Received: by 10.107.47.140 with HTTP; Thu, 20 Oct 2016 09:20:03 -0700 (PDT)
Date: Thu, 20 Oct 2016 22:20:03 +0600
Message-ID:
Subject: HECRAS 2D
Content-Type: multipart/alternative; boundary=001a11447c8c52c6a6053f4e4c4d–001a11447c8c52c6a6053f4e4c4d
Content-Type: text/plain; charset=UTF-8Hi,
I am Sumaiya from Bangladesh.I am doing my undergrade thesis using HECRAS
2D. As to warm up i am doing a simple project. I have generated data of
X,Y,Z co-ordinate ( length, with and elevation). My questions are:1. Can HECRAS-2D simulate steady flow?
2. Can i run my project without using Ras Mapper?
3. I have data of Weir in my project, how i add the weir data in HECRAS 2D?
4. Is Terrain data is mandatory?I will be very much thankful if you answer my questions.
Have a nice day.
Regard,
Sumaiya–001a11447c8c52c6a6053f4e4c4d
Content-Transfer-Encoding: quoted-printableHi,I am Sumaiya from Bangladesh.I am d=
oing my undergrade thesis using HECRAS 2D. As to warm up i am doing a simpl=
e project. I have generated data of X,Y,Z co-ordinate ( length, with and el=
evation). My questions are:1. Can HECRAS-2D simul=
ate steady flow?2. Can i run my project without using Ras Mapper=
?3. I have data of Weir in my project, how i add the weir data i=
n HECRAS 2D?4. Is Terrain data is mandatory?I will be very much thankful if you answer my questions.Have a nice day.Regard,Su=
maiya=C2=A0–001a11447c8c52c6a6053f4e4c4d–
1. RAS 2D does not have steady flow. You could do an unsteady run with a constant flow and eventually it should settle down to a steady answer.
3. You can add a weir using the SA/2D Area connection option.
2 & 4. You need Terrain data and you need Ras Mapper to setup the terrain and look at output.
Return-Path:
Received: from mail-it0-f42.google.com (mail-it0-f42.google.com [209.85.214.42])
by mwork.nabble.com (Postfix) with ESMTP id 1169D5E97A40D
for
Received: by mail-it0-f42.google.com with SMTP id 139so223752932itm.1
for
h=mime-version:in-reply-to:references:from:date:message-id:subject:to;
bh=+kkBAQiPqMnkOaV4ORjlYdiPZbRJLChwLVHqCD4eaNU=;
b=PMfDYD38NCIMQlxa878vjEpdvmlY68ROGz1PSYb2r+liEcBMDiRCY6f13+ghZA+MeT
gQyyEy1Q/KMXk1RGENKIbw94celtRXfpuRnOG6hjE7DS0TFHMFWmhTF7aCmvQAbKWGvV
QMnNlYjWnNyairdBoFBw3tEd9fSzjOu1F+AhLIlUKIEgag3MnV/5odVXFv6U7Bw/VlFm
5338G7GS70csaVKXB5lbTEg+PZNWODBZjeA7Uz1yrDZp5MGl6+i+nJm01utRQTWyGGzL
QbU/gJ8JA3quXgcRk2TOZAViTIqfZFZosrOozn6hMyaAQxL57pBdPv3Oq1HgMzPRNTBo
Slyw==
h=x-gm-message-state:mime-version:in-reply-to:references:from:date
b=MKnsV3e24BsQ27X07O0IuTrEOyJLKeOleBSxax7DFE6K55CkDRl6U4Ec+nxSEbTMkx
E+K3i2femlrGI36GLC/eLqBLswXthYYmy1tMUCkpVvB80Ep43H2u0eDNHvkk5O3N0iFq
q/eX0EgTxcCeopEaN7U+x/4NnHY5/pY+Zbu6BCoA3XzngxRkQfvFEHPJCnrrFTfVHmuN
NVhHOp2y2Lbxq/VhF8AuxI4YcsstWMORBNzSiy29xM8jyB4mQ5Z2f6/xBEgZ8iz38TDz
9dqIs6lTi+yFUqItV4KAC7646IPMkISbJoF77eOaO0ot6Zhln6Vxt5rw+gkE5yqpclo2
31dg==
X-Gm-Message-State: AA6/9Rl9wEbw57NRIo55HXuwbUYxC8rU1wl6CXZWYC+6VFsvFQZ1S5vLW6KRrSIr1q27gqzFgHwnJ4qS0M2aFw==
X-Received: by 10.36.154.66 with SMTP id l63mr13509329ite.5.1477055001981;
Fri, 21 Oct 2016 06:03:21 -0700 (PDT)
MIME-Version: 1.0
Received: by 10.107.47.140 with HTTP; Fri, 21 Oct 2016 06:03:21 -0700 (PDT)
References:
<[email protected]>
Date: Fri, 21 Oct 2016 19:03:21 +0600
Message-ID:
Subject: Re: HECRAS 2D
To: “Jarvus [via HEC-RAS Help]”
Content-Type: multipart/alternative; boundary=94eb2c1142d6b4f7b4053f5faae8
–94eb2c1142d6b4f7b4053f5faae8
Thank you for your quick reply. I am doing my project as per your
instructions.
Regards,
Sumaiya
On Fri, Oct 21, 2016 at 3:46 AM, Jarvus [via HEC-RAS Help] < [email protected]> wrote:
> 1. RAS 2D does not have steady flow. You could do an unsteady run with =
a
> 2 & 4. You need Terrain data and you need Ras Mapper to setup the terrai=
n
> and look at output.
> below:
> http://hec-ras-help.1091112.n5.nabble.com/HECRAS-2D-tp3162p3163.html
> To start a new topic under HEC-RAS Help, email ml-node+s1091112n1h72@n5.
> nabble.com
> To unsubscribe from HEC-RAS Help, click here
=3Dunsubscribe_by_code&node=3D1&code=3Dc3VtYWl5YW5pc2hhdDIwMTNAZ21haWwuY29t=
fDF8LTE4ODQ4MTAxMQ=3D=3D>
> NAML
%3Aemail.naml>
er your instructions.=C2=A0
=C2=A0
1.=C2=A0 RAS 2D does not have steady flow.=C2=A0 You could do an unsteady =
run with a constant flow and eventually it should settle down to a steady a=
nswer.
3.=C2=A0 You can add a weir using the SA/2D Area connection option.
2 & 4.=C2=A0 You need Terrain data and you need Ras Mapper to s=
=09
=09
=09
CRAS-2D-
To start a new topic under HEC-RAS Help, email ml-node+s1091112n1h72@n5.<= wbr>nabble.com
To unsubscribe from HEC-RAS Help, click here.
NAML
–94eb2c1142d6b4f7b4053f5faae8–
Return-Path:
Received: from mail-it0-f44.google.com (mail-it0-f44.google.com [209.85.214.44])
by mbob.nabble.com (Postfix) with ESMTP id AA9B8343A3CB
for
Received: by mail-it0-f44.google.com with SMTP id e187so10871605itc.1
for
bh=qbM5hlTvimMJtEfQsEk+N5nb4B10Pj8kv3Kbv6b2xw4=;
b=xa3ueYgI/sI4zdSggdswp1q0fF6tIetRxv4cs9ZzqGNJqXmljtB1DQMC9nmr4gfjaf
+Q2qXWZbP0Y5uxWsr6IXpDApooubgm8/wdl9sMXhynfB2nAqKl+sL2pXj13HHf6deyHq
nympoNHSSyDNrrFJPBYITrK3RaUIxmPx+px3hv4+UCVGLb6H8KPf8ODOB6tlPDq8zWb2
tTxOnm01l0SmyTACAr/u21kL3dnfzSU/ulfzZ1GHYxbZDKP2SBq9SViRjz7Pwb7p0DX8
Fs+xWcVwwnQonlVUqBrLUja2vlM/9DU3294/XEMm7l1xqYlkcVnmcVi0OMgsXsgT/mpb
AKEQ==
b=jUPxktMvKJ0SrCZRZWJqRhtS4tNGTUf++mDCQPR2uBfun22oXyxwq+QkZb9IU24pG4
kBiWNq3pcmczCj6Ow6RrVvnXotdizxYgxzZGlap5nn9lpbFFyo9xyyurt6vNVlWuhYQQ
trz1lM/EuZsjZW6k8vz97+gjBN1QauRK42db5S6wD9f6tySBunHbkt5lxh6EwXrRH/l7
ooCtE+kQVRDk7StWSaMILasLCa5X4L50U6UpL2V13g3cpBX5bCyBI5eJGY+nqiBzcieX
fY3GQsYIgx8/znsQASC+6BjVVVRd9hCOKUASrUs4msOibjKPpCYPLcfXOuT8I3/X35p2
oORQ==
X-Gm-Message-State: ABUngvfDpfDdbbi6r6oKJmMSiu8aCjceCSJS72MBGjUq2DyZegaSliMWpcGx8q4F9Drw2E5EUYMv3p43E95idQ==
X-Received: by 10.36.74.143 with SMTP id k137mr640065itb.107.1477087566090;
Fri, 21 Oct 2016 15:06:06 -0700 (PDT)
MIME-Version: 1.0
Received: by 10.107.47.140 with HTTP; Fri, 21 Oct 2016 15:06:05 -0700 (PDT)
In-Reply-To:
References:
<[email protected]>
Date: Sat, 22 Oct 2016 04:06:05 +0600
Message-ID:
Content-Type: multipart/alternative; boundary=001a11405782add6c1053f673f2c
–001a11405782add6c1053f673f2c
Hi Jarvus,
Again i am thanking you for helping me out. But I am facing further
problems.
1. How can i make my projection file in BTM Geographic Co-ordinate System?
Is there any tutorial or manual?
2. How I can export my TIN as tif formet?
i am waiting for your reply.
Regards,
Sumaiya
On Fri, Oct 21, 2016 at 7:03 PM, sumaiya nishat
> instructions.
> Regards,
> Sumaiya
>> below:
>> [email protected]
>> <http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?macr=
o=3Dunsubscribe_by_code&node=3D1&code=3Dc3VtYWl5YW5pc2hhdDIwMTNAZ21haWwuY29=
tfDF8LTE4ODQ4MTAxMQ=3D=3D>
>> NAML
o=3Dmacro_viewer&id=3Dinstant_html%21nabble%3Aemail.naml&base=3Dnabble.naml=
.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.=
view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%3=
Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabbl=
e%3Aemail.naml>
m thanking you for helping me out. But I am facing further problems.=C2=A0<= /div>
em? Is there any tutorial or manual?
7:03 PM, sumaiya nishat <[email protected]> wrote:
border-left:1px #ccc solid;padding-left:1ex">Thank you for=
your quick reply. I am doing my project as per your instructions.=C2=A0Regards,Sumaiya=C2=A0
wrote:
er-left:1px #ccc solid;padding-left:1ex">1.=C2=A0 RAS 2D does not have steady flow.=C2=A0 You could do an unsteady =
nswer.3.=C2=A0 You can add a weir using the SA/2D Area connection option.
etup the terrain and look at output.=09
=09
=09
will be added to the discussion below:http://hec-ras-help.1091112.n5
.nabble.com/HE=
To start a new topic under HEC-RAS Help, email [email protected]=
abble.com
NAML
–001a11405782add6c1053f673f2c–
I am not an expert on terrain issues. There may be other posters on this site that can provide better answers.
To set the projection:
From Ras Mapper, select Tools and select Set Projection for Project…
You may want to look at the User’s manual for HEC-RAS 2D flow.
If you have a TIN in GIS, you need to convert it to a raster using one of the tools in ArcMap or similar. If you have a TIN in Microstation format, I generally convert it to a landxml file, import it into GIS as a TIN, and convert to a raster.
