Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS unstable WSE_ EG over height
  • #7084
    DEL
    Hello.. I wanna ask about instability WSE, especially of EG of unsteady flow in HECRAS. The results models are success with some warning. I had change Htab parameters in number of points and increments. I had increase and decrease. But it’s not works for my model. Any one can help me please…
    #11830
    Scott Miller
    The model is 1D only, right? What are the low end flows? How long does it run in model time? How well does the initial flow match the first flows to enter the reach?
    The steep downstream end may be contributing to instability. If the model runs for long enough to output a few minutes of data, take a look at what the profile does during that time.
    #11831
    DEL
    Return-Path:
    by sloti1d2t14 (Cyrus 3.1.5-551-g079e021-fmstable-20181002v2) with LMTPA;
    Mon, 15 Oct 2018 19:53:28 -0400
    X-Cyrus-Session-Id: sloti1d2t14-598792-1539647608-2-3732788568818263233
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 1.3
    X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
    RCVD_IN_MSPIKE_H2 -0.001, SPF_PASS -0.001, URI_HEX 1.313, LANGUAGES en,
    BAYES_USED none, SA_VERSION 3.4.0
    X-Spam-source: IP=’209.85.128.54′, Host=’mail-wm1-f54.google.com’, Country=’US’,
    by compute1.internal (LMTPProxy); Mon, 15 Oct 2018 19:53:28 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id 180CBC661A
    for ; Mon, 15 Oct 2018 19:53:28 -0400 (EDT)
    id 5E04BEECCF7;
    ARC-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=fm1; t=
    1539647608; b=lXTxiiS3sk0ZcgPMCDZVzdhyM+BcBiuEDUtgXR4fHkw08xeO80
    4OpJj6B7hVjII1oTGCeIheFp6ctfBs1IkiXVx1BIZP6Z8xFELSI9T6vzZsdQtb7A
    JR+Kc/knBrS6EsA+uX1lKj2x2H8CP4dlCafq55up++K6IGcEp5CxXOKCerbxtZdy
    2/+AZqCX/QGlpFmxD5xMTINhy68d5t2A3l0w1FrMmEc5ibvb71rxX0kLz3dS6jiz
    6kpRxHwRkiQ4SDslfWj/YWv/R/YsEpB6/umxzrrUxKEiACYoutlqLKP0ZnU8ZbuS
    rsbneuU+Ov8Z8yEmw4leLo36ID3qklSVBj6Q==
    :date:message-id:subject:to:content-type; s=fm1; t=1539647608;
    bh=VFTnjbfa0Vm9Y+fPMvURkjFqImdloCvKi7fptB53FvQ=; b=d2o+zdrknb5q
    bYBMgegFJFTDoMeQLgI/BLLTGDqxtpIJl6XLxtwJ0cFqXFaTlt/m/FsCtlNpU652
    ZyvCUhTt+IoCkviiASaicUOg5RUtCWsxarthlv/iCeyu0MUBbX+mQ4xWdA5ZY6xw
    z7NdN1Qc8FIlLQdsPxqtr07JZISNeClk+J68tQAhasYVd80cLJAIqRVRWomfIiuT
    qMo5WHfM8OgokWSmB8WET2n5vH2kWTvay5bWhfG+hpym/jCarPdfGwm/WgnHf/5r
    80p9SOMcDW13kbgaZet85djfVtCYvEgXqChvWXew9L4DSki0rs1WxbAXMmAv73nx
    QUvK/UK6bw==
    [email protected] header.b=Jzt2cUvy header.a=rsa-sha256
    (p=none,sp=quarantine,d=none,d.eval=none) header.from=gmail.com;
    iprev=pass policy.iprev=209.85.128.54 (mail-wm1-f54.google.com);
    spf=pass [email protected]
    smtp.helo=mail-wm1-f54.google.com;
    x-cm=none score=0;
    [email protected] header.b=LFQzBTvp;
    x-ptr=pass smtp.helo=mail-wm1-f54.google.com
    policy.ptr=mail-wm1-f54.google.com;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-vs=clean score=0 state=0
    x-cm=none score=0;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT02
    NTE2JmNvZGU9Wm1Ga1pXeHJhR0ZzYVdaaGFFQm5iV0ZwYkM1amIyMThOalV4Tm53eE5ERT
    RORGN6T1RBeg
    X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedtkedrvdelgdegtdculddtuddrgedtjedrtddtmd
    cutefuodetggdotefrodftvfcurfhrohhfihhlvgemucfhrghsthforghilhdpggftfghn
    shhusghstghrihgsvgenuceurghilhhouhhtmecufedttdenucenucfjughrpeggfhgjhf
    ffkffuvfgtsegrtderredttdejnecuhfhrohhmpefhrgguvghlucfmhhgrlhhifhgrhhcu
    kfgsrhgrhhhimhcuoehfrgguvghlkhhhrghlihhfrghhsehgmhgrihhlrdgtohhmqeenuc
    ffohhmrghinhepnhgrsggslhgvrdgtohhmnecukfhppedvtdelrdekhedruddvkedrheeg
    necurfgrrhgrmhepihhnvghtpedvtdelrdekhedruddvkedrheegpdhhvghlohepmhgrih
    hlqdifmhduqdhfheegrdhgohhoghhlvgdrtghomhdpmhgrihhlfhhrohhmpeeofhgruggv
    lhhkhhgrlhhifhgrhhesghhmrghilhdrtghomhequcfukfgkgfepkeeiheehnecuvehluh
    hsthgvrhfuihiivgeptd
    X-ME-VSCategory: clean
    X-CM-Envelope: MS4wfKVAnp1WCrvk5mgMTbTGDC3ZG89d7lwETtuqmPy/W0o90wZg83rxNvfm5V7KBMBH1U2LySM8velTuMHNX6SSTbZI6j6btUK0f4cahg407vBuRdYnEk1a
    8eg+Crzy04O/qMMIUwbuLksNiNzHUzBX630Lh4lmHl6ikQCMW6UpPGuz8pd+HTap9VsygyMeiCVmoKiJ+0cMnge7JtJlEzHnDLaGmfEWqWN6/cC9gexc041W
    X-CM-Analysis: v=2.3 cv=KuKcJleN c=1 sm=1 tr=0 a=cmaO/NQVMQV80KAlR7/03A==:117
    a=x7bEGLp0ZPQA:10 a=xl9-TOw3_ukA:10 a=smKx5t2vBNcA:10 a=9I5xiGouAAAA:8
    a=pwpK1ih8XUmrh6vQvpkA:9 a=QEXdDO2ut3YA:10 a=gTdTXleexGMA:10
    a=1NErMrZjlsuGfkWsudIA:9 a=Mv8KPRQCieznh37o:21 a=ARFN2YZ7Uv8kHtb7LS-q:22
    X-ME-CMScore: 0
    X-ME-CMCategory: none
    Received-SPF: pass
    (gmail.com … _spf.google.com: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:_netblocks.google.com’ matched))
    identity=mailfrom;
    client-ip=209.85.128.54
    Received: from mail-wm1-f54.google.com (mail-wm1-f54.google.com [209.85.128.54])
    for ; Mon, 15 Oct 2018 19:53:27 -0400 (EDT)
    Received: by mail-wm1-f54.google.com with SMTP id 206-v6so20579913wmb.5
    for ; Mon, 15 Oct 2018 16:53:27 -0700 (PDT)
    d=gmail.com; s=20161025;
    b=Jzt2cUvyFSl0Bn1d9+3hMUTyb+OOcKX48bQD6pKLLQXK4CIX2U0B80nlt2AwOAhZbV
    5qIBR6DlR6URzf0Li3/WKelBI6YxB0MpWao2+TfH7wTdyStqbBWj7NOnrney89a0ESik
    USjOoTwTLuO0Gf+6E0G/iR7z4F0ddUFEj137+cXP62p96F5Pa281Va4sIHWP4oJM2pKa
    GPiqzgmq6OCPvCnPXMB1dxaaUm+pJW9ZEIxtdtXKPw5fnGtmVnB0ZLse5c+f8hCK+PxD
    yEs8f8Wh4B1j7jeiPNgYpSlrWpgcddvRobH3ujjoWk998Mm/gPfTc9NAQ2zmBNM3z4vg
    G4XQ==
    d=1e100.net; s=20161025;
    b=LFQzBTvpkydobyNnlEVHzNnj9du5ZUAmq230VlksDtS2GNAvM5VK2HxWT5o8ptqJkl
    xMt2XjF55QwaKmV5Rafcu9kBjjPciqzXlOLEPLPR0v6t2q+ENJbXYSyuUb5leTX1ZYl0
    H6NEJ6BGtM+7jQ40IFsK9fCly2b966cRMiTM5WS65vwpW1A1O9ebdWAKlVznznJW27W7
    kjs7ebXz1xaJrFNg38FnmBW2Uwh/v8B9M7XOuC1Ngyy0QMks8lk78asIIF3cEMsKMu4T
    0TU9ePL8+qcdBaI+9X38I7u+HH1Ib5UfQziGwaj43D15+oyN6euv8ORrihecoOXrA+6I
    lGEA==
    X-Gm-Message-State: ABuFfogp8nSZTrxfTfeqfOu2AooAtVvwuNiOa3xVlt+DL6V5rpDnNLEQ
    NFnLlUTmmGjwsClOKouiZCmS4p2mBFXeKKp/GPe8+8SG
    X-Google-Smtp-Source: ACcGV631U/P52jctm6bKONS0oQJmgpMJsoVVa/AiyUIv0bF6FzPtQMOjojfI/D0Mf+9T6a4XKyj7QUkgNau2BaJI9YA=
    X-Received: by 2002:a1c:824b:: with SMTP id e72-v6mr15108581wmd.92.1539647605171;
    Mon, 15 Oct 2018 16:53:25 -0700 (PDT)
    MIME-Version: 1.0
    Date: Tue, 16 Oct 2018 06:53:11 +0700
    Message-ID:
    Subject: Re: HEC-RAS unstable WSE_ EG over height
    To: [email protected]
    Content-Type: multipart/alternative; boundary=”00000000000095ec6b05784d2452″
    –00000000000095ec6b05784d2452
    Thank you very much Scott. That’s right the model is 1D. Actually i would
    like to make 2D model. but first, i started from 1D model and then continue
    to 2D. I set unsteady model and running for 3 days.
    the initial flow that I use seems very influential. as an example. if I use
    the value 5. The model will immediately error. If I use 40, it will error
    too, but if I use 36 (recently), the flow will tend to be stable.
    As information a few meters before the downstream, there is a downstream
    that is quite steep, but sometimes the results of the model will be fine.
    when I change the hydrograph, the flow model will then tend to be error.
    Overall, the geometry of the river has no significant contraction and
    expansion and the too steep cross section. I confused what should i do now.
    Best regards.
    *FADEL KHALIFAH IBRAHIM, S.T.*
    ENVIRONMENTAL AND CIVIL ENGINEER
    On Tue, Oct 16, 2018 at 6:11 AM Scott Miller [via HEC-RAS Help] < [email protected]> wrote:
    > run in model time? How well does the initial flow match the first flows t=
    o
    > enter the reach?
    > below:
    > http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-unstable-WSE-EG-over-he=
    ight-tp6516p6522.html
    > To unsubscribe from HEC-RAS unstable WSE_ EG over height, click here
    =3Dunsubscribe_by_code&node=3D6516&code=3DZmFkZWxraGFsaWZhaEBnbWFpbC5jb218N=
    jUxNnwxNDE4NDczOTAz>
    > NAML
    %3Aemail.naml>
    Thank you very much Scot=
    t. That's right the model is 1D. Actually i would like to make 2D model=
    . but first, i started from 1D model and then continue to 2D. I set unstead=
    y model and running for 3 days.=C2=A0
    the initial flow that I use =
    seems very influential. as an example. if I use the value 5. The model will=
    immediately error. If I use 40, it will error too, but if I use 36 (recent=
    As informati=
    on a few meters before the downstream, there is a downstream that is quite =
    steep, but sometimes the results of the model will be fine. when I change t=
    he hydrograph, the flow model will then tend to be error. Overall, the geom=
    etry of the river has no significant contraction and expansion and the too =
    steep cross section. I confused what should i do now.=C2=A0
    <= /div>
    Best regards.
    On Tue, Oct 16, 2018 at 6:11 AM=
    Scott Miller [via HEC-RAS Help] <[email protected]> wrote:
    The model is 1D only, right? What are the low end flows? How long does it =
    run in model time? How well does the initial flow match the first flows to =
    enter the reach?
    The steep downstream end may be contributing to instability. If the=
    model runs for long enough to output a few minutes of data, take a look at=
    =09
    =09
    =09
    http://hec-ras-help.109=
    1112.n5.nabble.com/HEC-RAS-unstable-WSE-EG-over-height-tp6516p6522.html
    =09
    To unsubscribe from HEC-RAS unstable WSE_ EG over height, click here.
    NAML
    –00000000000095ec6b05784d2452–
    #11832
    Scott Miller
    Does the model go unstable every run, regardless what the initial flow is? Set the output intervals to 1 minute. Then run the unsteady model and look at the animation of the profile. This can reveal where instabilities start.
    (Click on the animation/”play” button, then right click the profile plot for “full extent”… the view ought to zoom in to the channel profile. Click on animation again to get the animation tool bar back.)
    The initial flow should almost always match the initial flow in the hydrograph. It may be useful to set a minimum flow in the boundary conditions. Make it a small fraction of typical flows, but not so small the channel goes dry anywhere.
    Low flows can be problematic where they arrive at a steep reach. A cross-section may dewater in a time step. It may help to put more cross sections in where the bed slope is steep or the channel changes rapidly. Make sure the distance between cross sections and the time step make sense for velocities in the channel, and that the velocities are reasonable.
