Welcome to the RAS Solution Forums HEC-RAS Help Hec Ras to Google Earth
  • This topic has 4 replies, 367 voices, and was last updated 6 years ago by Anonymous.
  • #7320
    is there a way to export the 2d dynamic flooding maps of Ras Mapper into google earth (possibly creating a kml file)?
    Thank you
    #12275
    There is not an automatic way to do this.
    What I have done is created rasters of each of the output intervals and used some scripts to create the KMZ file.
    #12276
    Hi Cameron,
    Thanks for the reply.
    Did you create a code to automatically read the extracted rasters or did you just manually edit the KML file?
    #12277
    code that would read the rasters. I also use similar code to create animations in ArcMap.
    #12278
    Cool! Would you like sharing it?
