Welcome to the RAS Solution Forums HEC-RAS Help HEC – RAS multiplier M in computing dispersion coefficient
  • #6306
    SiriusBlack
    I am trying to understand and perform a water quality analysis in HEC – RAS. In dispersion coefficient section, I have found a user defined multiplier M which is used to compute the coefficient. The user manual suggests to use positive value of this multiplier. My ques is why this multiplier? what is it’s significance ? what type of value should I use? And what will be it’s effect on the dispersion coefficient?
    Thank You
