Dear RAS Solution users,
Is there a maximum terrain file size (*.FLT) that RAS Mapper in HEC-RAS 4.1 can import? My FLT surface is approximately 2.15 GB and I receive the following error when importing:
“Floodplain Mapping
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Arithmetic operation resulted in an overflow.”
I have applied the appropriate projection, so I’m at a loss for what is causing the problem. Any help or insight as to what’s causing this would be greatly appreciated.
Thank you,
Denver, CO
