Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC RAS how to import a river centerline GIS or automate digitizing
  • #16812
    1. I am trying to import an existing shapefile that represents the river centerline – I am sure there is a way to import it to the geometry section of HEC-RAS, but I have not figured it out yet. Can you please point me to the right direction?
    2. What if I don’t have an existing shapefile, and if the centerline that I need to digitize is a lot. Is there a way in HEC-RAS or maybe other GIS tools to automate the digitizing process?
    Thanks!
    #16910
    Luis Partida
    You can complete this in RAS Mapper as your first step in a geometry build.
    Open RAS Mapper and on the left expand Geometry. Then select your geometry right click and edit. Then expand the geometry until you see “Reach” then right-click on this and you will see and import option
    #16918
    Paul Durrell
    Hi I’ve had a similar problem and followed the above advice but unfortunately when i come to digitise the river string RAS mapper just hangs on me and freezes.
    I’ve tried loading an example dem from the tutorials and don’t have a problem.
    When I expand the geom tree for the river i can add flow lines etc but as soon as I try to add the river string it freezes. I can also add x sections without a problem.
    I’ve set the projection and the dem is 12,000kb so not sure what I’m doing wrong.
    Can anyone offer some advice please?
    Regards
    Paul
