Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC-RAS Help with file saving
- This topic has 0 replies, 103 voices, and was last updated 8 years ago by amcassa.
February 19, 2018 at 5:13 pm #6786amcassaParticipant
Return-Path:
by sloti1d2t14 (Cyrus 3.1.3-92-g33c0f93-fastmail) with LMTPA;
Mon, 19 Feb 2018 08:13:39 -0500
X-Cyrus-Session-Id: sloti1d2t14-3002574-1519046019-2-17654624110943849227
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: BAYES_00 -1.9, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001,
RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H3 -0.01,
RCVD_IN_MSPIKE_WL -0.01, SPF_PASS -0.001, LANGUAGES en,
BAYES_USED global, SA_VERSION 3.4.0
X-Spam-source: IP=’209.85.218.51′, Host=’mail-oi0-f51.google.com’, Country=’US’,
by compute1.internal (LMTPProxy); Mon, 19 Feb 2018 08:13:39 -0500
by mailmx.nyi.internal (Postfix) with ESMTP id A3D59C8602
for; Mon, 19 Feb 2018 08:13:38 -0500 (EST)
id 69A98AA9338;
ARC-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=arctest;
t=1519046018; b=DKdNsno5i6t9rBBLdgGQ65wPfkHGEXfm+Am/+UGTXKtdOog
mHSFBqM4O++yT6HVMqdSzemC+0TB13wvsmEexMO3g964FTz3A/IT/Y6Z+OHYC8q5
LfXRmoqBGqb9k2fU2sCgFeQYmCVbXgZ104z1DhaFNDrpAbmWWfe6urNzozUv3YSU
wIbbEPIXcOtfBhcNLZVCBye16b4AYS7zS8cj0dEzT34ro0/mc8n5CviNZbKDSLNQ
dNYOMEoeXmVh8MSP/xQIXxawbt0WX6l+wPpTVuBiH3ji+pkZkCm63dFyrxI08pdQ
KAA1JNCzT2vdH/jy86ak7LxAelz6f5bnDr2+6bg==
messagingengine.com; h=mime-version:from:date:message-id:subject
:to:content-type; s=arctest; t=1519046018; bh=9ScOlcAp9tpkihwgEH
/8VBnqxLDzwNPZ5KJ5rK6ET6Q=; b=PK+7TYYkSEDOd9Mrk/S50TtF6IyBWrndx8
DgyRteuIGRSERVOsM4vsl9yIhs6F3hpo4YEDoL+QCJ4FkGpUGKJg6zqg+WBsn/LO
rQhpNIT1F2OozSeGDT+dwg670EVvgc7fHv/GRPs4IiEnXYyZ+xUFKLwZNlopO2Z+
9uDFvcOmjcrqc9JfXZVwedHhReeWrJutDHOd3u2yMgUtYkK85MRjeKyjft2lvwOB
yWjuImCKddx3yUysq8Z/waYlRru2QDiyIG/8YtX2yThH4vVqf1llPxZVHPdgluMy
xmi/cluUDk9Pc4TijKSplgtAyoSZkdRZfauAYjpL20qMlE4OSeNw==
ARC-Authentication-Results: i=1; mx4.messagingengine.com; arc=none (no signatures found);
dkim=pass (2048-bit rsa key sha256) header.d=gmail.com [email protected] header.b=uxrvSokV x-bits=2048 x-keytype=rsa x-algorithm=sha256 x-selector=20161025;
dmarc=pass (p=none,d=none) header.from=gmail.com;
iprev=pass policy.iprev=209.85.218.51 (mail-oi0-f51.google.com);
spf=pass [email protected] smtp.helo=mail-oi0-f51.google.com;
x-aligned-from=pass;
x-google-dkim=pass (2048-bit rsa key) header.d=1e100.net [email protected] header.b=cLUqxdvo;
x-ptr=pass x-ptr-helo=mail-oi0-f51.google.com x-ptr-lookup=mail-oi0-f51.google.com;
x-return-mx=pass smtp.domain=gmail.com smtp.result=pass smtp_is_org_domain=yes header.domain=gmail.com header.result=pass header_is_org_domain=yes;
x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128
Received-SPF: pass
identity=mailfrom;
client-ip=209.85.218.51
Received: from mail-oi0-f51.google.com (mail-oi0-f51.google.com [209.85.218.51])
Received: by mail-oi0-f51.google.com with SMTP id e10so3660649oiy.8
for; Mon, 19 Feb 2018 05:13:38 -0800 (PST)
d=gmail.com; s=20161025;
h=mime-version:from:date:message-id:subject:to;
bh=9ScOlcAp9tpkihwgEH/8VBnqxLDzwNPZ5KJ5rK6ET6Q=;
b=uxrvSokVcuyHHBC3DgyNnmEUVPU/ilcwIQyohI1FxPYsZ1+4q28gXh6SQFZuBh/SfM
j8ejwdKxbE/Ou8Hsx8M8ZZwbQYTEhnk66w7dfMfUfqxeLQKRT3MaAQiot/uBMRU94asr
zR0Rf89WxZl4a1EP4vdwsMxB15JjOZJ6xwhu02jNC+tpIZGaUUswM2+uKGkruTL9PM/m
OQnt/fMFCGE8W4hi5AHm/0NxToPAGbpthcl06Z2BqRSLpmavV/WJ3yio9c9v7WYMvyQf
/in2tTquuXmblSL/vbEYG47Usvv+64Wta9yJZDmHpAJkDvK7YgLyecx8XOGDL+l4sIta
CPvQ==
d=1e100.net; s=20161025;
h=x-gm-message-state:mime-version:from:date:message-id:subject:to;
b=cLUqxdvopydOsaslenFHUHSCmumGy1zugeTX04LWgs9rJbHe/NfYamJ0X/eNjLRSqN
Fm/d4Ay53wXqhZpNa07RnbczTLRij4dVS742hTKdUzdwlGaQEZ5Kk8zU8aSAEkWncWjR
JE9aSJvtEhtKe/P5XH+jYxTQsVa01Fv4awi3n7lb19/HsN3zRs6W5ZjeDQIMtbgNPe1B
uuoMfRXiM6FGU3GMS66tUFqRneqB1f2aM5BexMPOALTUetaG9adb6zw/AlUp6zl0vxLA
sgNL0LsQ/hRkUHq09aZChh34syANU022TtNa0b9hDwm1aYDuX0uLPoJEIkF7l82w+Rt8
Gj5w==
X-Gm-Message-State: APf1xPC3jiAcDzlLUYJ5YxTD7SJP5riyuzPIgC3LH9SqGmn+124Ozufi
XJugIPU9Tl6rj2eX4wPS7NVLKoi7h1LmL2DnOw==
X-Google-Smtp-Source: AH8x227z4l+m09emfpLimuZawS3VEz/Ty2QhjCOOziI+W5PDHmRq2XebGZ5SQdBjJ+73kGXFKIHuh6wgOU9sVJg/Uw4=
X-Received: by 10.202.49.149 with SMTP id x143mr4367191oix.283.1519046016500;
Mon, 19 Feb 2018 05:13:36 -0800 (PST)
MIME-Version: 1.0
Received: by 10.74.148.6 with HTTP; Mon, 19 Feb 2018 05:13:35 -0800 (PST)
Date: Mon, 19 Feb 2018 15:13:35 +0200
Message-ID:
Subject: HEC-RAS Help with file saving
To: HEC-RAS Help
Content-Type: multipart/alternative; boundary=”001a113cdc8e360ad10565907671″–001a113cdc8e360ad10565907671
Content-Type: text/plain; charset=”UTF-8″Good day HEC-RAS
I would like to know is it possible to save a HEC-RAS project into one
file? As you create geometry, flow, plans, each file is created separately
thus if you need to send a project file you need to gather all the other
files with it. Is there a way to package this up into one file to making
moving this project from one computer to another easier?Best regards
Amanda Cassa
[email protected]
Design Engineer
(Pr Eng, PhD (Civil Engineering)
South Africa–001a113cdc8e360ad10565907671
Content-Transfer-Encoding: quoted-printableGood day HEC-RASI would lik=
e to know is it possible to save a HEC-RAS project into one file? As you cr=
eate geometry, flow, plans, each file is created separately thus if you nee=
d to send a project file you need to gather all the other files with it. Is=
there a way to package this up into one file to making moving this project=
from one computer to another easier?Best regardsAmanda Cassa
[email protected]=
Design Engineer(Pr Eng, PhD (Civil Engineering)=C2=A0=
South Africa–001a113cdc8e360ad10565907671–
