Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS Error – Incomplete data
  • #5714
    UmarJamil
    Dear all I am new user of Hac Ras 4.1.
    I prepared the data in ArcGIS 10.1using Hac GeoRas toolbar (river channel, river bank, cross sections etc.). After preparation of data I exported the data in Hac ras 4.1 and want to generate flow of 160000 cusec.
    After giving the flow to the model, when I run the model an error is generated for all cross section stations. Which is as below. Please tell me how can I remove these type of errors.
    ERROR:
    HEC-RAS Error – Incomplete data, the following errors were found:
    River: “Suwan River” Reach: “Lower Reach” RS:19937.41
    – No Manning’s n data or friction heights k set.
    – Main channel length is less than or equal to zero, HEC-RAS requires a positive reach length.
    #9141
    markwood
    Return-Path:
    Received: from na01-bn1-obe.outbound.protection.outlook.com (mail-bn1on0065.outbound.protection.outlook.com [157.56.110.65])
    by mbob.nabble.com (Postfix) with ESMTP id 7B0D591796F
    for ; Mon, 23 Feb 2015 05:20:57 -0800 (PST)
    Received: from BY2PR03CA009.namprd03.prod.outlook.com (10.255.93.26) by
    BL2PR03MB195.namprd03.prod.outlook.com (10.255.230.153) with Microsoft SMTP
    Server (TLS) id 15.1.93.12; Mon, 23 Feb 2015 13:28:51 +0000
    Received: from BN1BFFO11FD036.protection.gbl (10.255.93.4) by
    BY2PR03CA009.outlook.office365.com (10.255.93.26) with Microsoft SMTP Server
    (TLS) id 15.1.93.16 via Frontend Transport; Mon, 23 Feb 2015 13:28:50 +0000
    Received: from USDEN3EXHT002.na.aecomnet.com (65.240.194.57) by
    BN1BFFO11FD036.mail.protection.outlook.com (10.58.144.99) with Microsoft SMTP
    Server (TLS) id 15.1.99.6 via Frontend Transport; Mon, 23 Feb 2015 13:28:49
    +0000
    Received: from USDEN3EXHT003.na.aecomnet.com (172.27.132.59) by
    USDEN3EXHT002.na.aecomnet.com (172.27.132.57) with Microsoft SMTP Server
    (TLS) id 14.3.210.2; Mon, 23 Feb 2015 05:28:48 -0800
    Received: from USDEN3EXMB002A.na.aecomnet.com ([169.254.13.78]) by
    USDEN3EXHT003.na.aecomnet.com ([172.27.132.59]) with mapi id 14.03.0210.002;
    Mon, 23 Feb 2015 05:28:47 -0800
    To: “UmarJamil [via HEC-RAS Help]”
    Subject: RE: HEC-RAS Error – Incomplete data
    Thread-Topic: HEC-RAS Error – Incomplete data
    Thread-Index: AQHQT0ci6g6IjVFKJ0iDrN+UIYCTLJz+OYVA
    Date: Mon, 23 Feb 2015 13:28:47 +0000
    Message-ID: <6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9@USDEN3EXMB002A.na.aecomnet.com>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach: yes
    X-MS-TNEF-Correlator:
    x-originating-ip: [172.27.154.245]
    x-aecom-disclaimer: Yes
    Content-Type: multipart/related;
    boundary=”_004_6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9USDEN3EXMB002An_”;
    type=”multipart/alternative”
    MIME-Version: 1.0
    X-EOPAttributedMessage: 0
    Received-SPF: None (protection.outlook.com: aecom.com does not designate
    permitted sender hosts)
    Authentication-Results: spf=none (sender IP is 65.240.194.57)
    [email protected]; n5.nabble.com; dkim=none (message not
    signed) header.d=none;
    X-Forefront-Antispam-Report:
    CIP:65.240.194.57;CTRY:US;IPV:NLI;EFV:NLI;SFV:NSPM;SFS:(10009020)(428002)(199003)(189002)(377454003)(17760045003)(50986999)(86362001)(77096005)(15975445007)(102836002)(2900100001)(2950100001)(2920100001)(76176999)(19300405004)(66926002)(64706001)(46102003)(54356999)(99936001)(19627595001)(18206015028)(6806004)(16796002)(19580395003)(14971765001)(55846006)(16236675004)(105586002)(106116001)(2656002)(84326002)(87936001)(19580405001)(5890100001)(110136001)(19617315012)(92566002)(106466001)(107886001)(62966003)(33656002)(77156002)(101416001)(67866002)(512954002)(19625215002)(450100001);DIR:OUT;SFP:1101;SCL:1;SRVR:BL2PR03MB195;H:USDEN3EXHT002.na.aecomnet.com;FPR:;SPF:None;PTR:ip-65-240-194-57.den3.us.aecom.com;A:1;MX:1;LANG:en;
    X-Microsoft-Antispam: UriScan:;
    X-Microsoft-Antispam: BCL:0;PCL:0;RULEID:;SRVR:BL2PR03MB195;
    X-Microsoft-Antispam-PRVS:
    X-Exchange-Antispam-Report-Test: UriScan:;
    X-Exchange-Antispam-Report-CFA-Test:
    BCL:0;PCL:0;RULEID:(601004)(5005003);SRVR:BL2PR03MB195;
    X-Forefront-PRVS: 0496DF6962
    X-Exchange-Antispam-Report-CFA-Test: BCL:0;PCL:0;RULEID:;SRVR:BL2PR03MB195;
    X-OriginatorOrg: aecom.com
    X-MS-Exchange-CrossTenant-OriginalArrivalTime: 23 Feb 2015 13:28:49.3924
    (UTC)
    X-MS-Exchange-CrossTenant-Id: f205a70a-ddf9-44aa-bf6c-2c222d9d1bfc
    X-MS-Exchange-CrossTenant-OriginalAttributedTenantConnectingIp: TenantId=f205a70a-ddf9-44aa-bf6c-2c222d9d1bfc;Ip=[65.240.194.57]
    X-MS-Exchange-CrossTenant-FromEntityHeader: HybridOnPrem
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BL2PR03MB195
    –_004_6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9USDEN3EXMB002An_
    boundary=”_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9USDEN3EXMB002An_”
    –_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9USDEN3EXMB002An_
    Umar,
    The errors appear to indicate that Manning’s n values, and Reach Lengths, h=
    ave not been specified for the XS’s
    [cid:[email protected]]
    Let me know if this isn’t helpful.
    David
    From: UmarJamil [via HEC-RAS Help] [mailto:[email protected]=
    le.com]
    Sent: Monday, February 23, 2015 4:00 AM
    To: Markwood, David
    Subject: HEC-RAS Error – Incomplete data
    I prepared the data in ArcGIS 10.1using Hac GeoRas toolbar (river channel, =
    river bank, cross sections etc.). After preparation of data I exported the =
    After giving the flow to the model, when I run the model an error is genera=
    ted for all cross section stations. Which is as below. Please tell me how=
    ERROR:
    – Main channel length is less than or equal to zero, HEC-RAS requires =
    low:
    http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-Error-Incomplete-data-tp1=
    348.html
    To start a new topic under HEC-RAS Help, email [email protected]=
    ble.com
    To unsubscribe from HEC-RAS Help, click here<http://hec-ras-help.1091112.n5=
    .nabble.com/template/NamlServlet.jtp?macro=3Dunsubscribe_by_code&node=3D1&c=
    ode=3DZGF2aWQubWFya3dvb2RAYWVjb20uY29tfDF8LTE3NzA3MjE4MzI=3D>.
    .view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%=
    3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabb=
    le%3Aemail.naml>
    This e-mail and any attachments contain AECOM confidential information that=
    may be proprietary or privileged. If you receive this message in error or =
    are not the intended recipient, you should not retain, distribute, disclose=
    or use any of this information and you should destroy the e-mail and any a=
    ttachments or copies.
    Umar,
    The errors appear to indicate=
    that Manning’s n values, and Reach Lengths, have not been specified =
    for the XS’s
    Let me know if this isn&#8217=
    ;t helpful.
    David
    l [via HEC-RAS Help] [mailto:ml-node+[email protected]]
    To: Markwood, David
    Dear all I am new use=
    r of Hac Ras 4.1.
    ted for all cross section stations. Which is as below.   Please tell m=
    ERROR:
    River: "Suwan River"   Reach: "Lower Reach"  =
    RS:19937.41                  =
         – Main channel length is less than or equal to zero, HE=
    If you reply to this ema=
    il, your message will be added to the discussion below:
    http:/=
    /hec-ras-help.1091112.n5.nabble.com/HEC-RAS-Error-Incomplete-data-tp1348.ht=
    ml
    ml-node+s109=
    [email protected]
    click here
    NAML
    This e-m=
    ail and any attachments contain AECOM confidential information that may be =
    proprietary or privileged. If you receive this message in error or are not =
    not retain, distribute, disclose or use any of this information and you sh=
    ould destroy the e-mail and any attachments or copies.
    –_000_6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9USDEN3EXMB002An_–
    Content-Type: image/jpeg; name=”image001.jpg”
    Content-Description: image001.jpg
    Content-Disposition: inline; filename=”image001.jpg”; size=28729;
    creation-date=”Mon, 23 Feb 2015 13:28:45 GMT”;
    modification-date=”Mon, 23 Feb 2015 13:28:45 GMT”
    Content-ID:
    /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwkHBgoJCAkLCwoMDxkQDw4ODx4WFxIZJCAmJSMg
    IyIoLTkwKCo2KyIjMkQyNjs9QEBAJjBGS0U+Sjk/QD3/2wBDAQsLCw8NDx0QEB09KSMpPT09PT09
    PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT3/wAARCAEgAWADASIA
    AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA
    AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3
    ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm
    p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA
    AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx
    BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK
    U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3
    uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDlfGDC
    21e2SH92rWUDYTgElOTx3NYRuZFGTK//AH0a6HxjbTS6tbNHBK6mwtxlUJH3BWAtjcqMfZrg/WJv
    8K9TDRpexjeOtvL/ACFia9X20/ee76vuaNvpk0mjjU7nUI7W1aYwIZN7F3C7iMKDjgjrTv7B10Oi
    mxvFLp5i7uAVwDnJOMfMv506C9mGhjSrzSZri3SdriNhvjZWZdpzgHI4FXpPEd/cXd1JcaXJJBdW
    cdnLDhwNqbcEHHByoNPkXZfgZe3qfzP72ZjaTrEccsklrcosLmN9/wApDDqoBOSeR0z1p66Nqv8A
    attpssbxXVzII0SSQDnOOcHj8a2rrxlq17DfJPpsjfbJvOPD4hOVwYxjKthR8wPXnGao6zrN7rmp
    2t5c6bKjW6hSUVhJLg5yzhQc+hxxSUe8UDr1P5397IrjQdQjvmtLVpbqZFLSBY5I9gzjJ3heCehp
    LbQdYuJkQwTQq04ty8x2hX3BSOeTgkZwDWy3jXV3XynsLpofs5gJaSUzH59+fNxnrx06VUm8QX1w
    lmZdMnknsbhri1mkaR2RmZWO/I+fle+KFD+6vwH7ep/O/vZBceGdXt5Jo/LklkiuTbbY8sGYAtkN
    0xgE84NRJ4e1x2dVsbolCobkdSMjHPORyMZrVh8WX1u1z5GilEurp7qVT5hyXRkdQccA7ifalHi3
    UQLNV0nEVnNbyQptc4EKFVUnHOckk0uV/wAqD29T+d/ezL0zRptRsprt76G1hinS3JnL/ffOOgOB
    xyT0pj6Nqscl0jW0u60YrOAwJQjrxnOOQc1bsdWntba7t7jR3uorm6W7Kt5iYZSSBwORzV+Dxfqq
    Q3Am00yzz+dvmVGTd5oAJZQMNjHGegpuGukV+Avb1P5397M6/wDDWq2GsyaZt8+4QAjypBhxxyMk
    dzjHWsp/NikaOTejoSrK2QQR1BFdLH4pvF1W61A6MfPu/LaZl3qS6EHKnGVBxgr3rMuNQ1SbU729
    hjurZ7yRpJFiVgOSTjpyOacYLrFA69TpN/eyxpXhq81eyhuILqFWnlkhhictud0TeRnGBx6mqP8A
    ZuofYBfG2n+ykbvN7YzjPrjPGelaeleINT0nS49PhsXe3EsjyqyOPOV1ClDgccDgjkVIfEN+2n21
    p9gnCW0YiRd0nlsituAdMYf0OetTya7IPb1LfG/vZWt/Dt89vey3Qkt1trVrlCRuEoVgCoIOO9Qy
    aW9vpdve3N5FELlGkgiIdmcKcdQMDn1NbV54v1C8sZ7X+ynRJ45oySXYr5jKxxxwBtGB6VlvfTT6
    bZ2tzpckj2SskEvzjALbvmXGG5oUO6X4A69TpN/eyJNC1aQoEs5m3qzqVIIIGMnOccZH50o0PVvN
    WP7Dcb3l8lRj7z7d20f8B5+lbU/i+/ntJrcaSVSZJlP3yF8xQp2jHAAHAoTxPeiz1PFvcRT3dvDb
    RokRKKFXaXyRkNt4/Gly/wB1B7ap/O/vZjJoeqyJC6WNwyzECMgfeJzjjtnBxnrUcunXVrdRQXif
    ZmlxtaVsLjOM56YFbtr4s1C0MTppeZVECyOQ/wC8WHOwYxx15PtWdLf3FwNMSfTDJFYbgIyrYlDO
    XIbjjrimoq+sUHt6n87+9lj/AIRaZbVrtr+1FosPn+cQ/K79mdu3d174wRyKzL+xn029e2uAN64I
    KnIZTyGB9COa131yWWS/aXSJpFv41jmVpX6K2VCnb8oGMYHas7Up73VL57qe3kVmAVVWJsIoGFUf
    QURgr6pfgDr1Okn97KVLTxbT/wDPCb/v2f8ACl+zT/8APCb/AL9n/Cr5IdkT7et/M/vYylAqT7NP
    /wA8Jv8Av2f8KUW0/wDzwm/79n/Cjkh2Qe3rfzP72MwPSlwPQU8W0/8Azwm/79mnfZ5/+eE3/fs0
    ckOyD29b+Z/eyPA9BShR6CpPs8//ADwm/wC/ZpRbz/8APCX/AL9mjkh2Qe3rfzP72M2r6D8qUIv9
    0flUgt5/+eEv/fBpRbzf88Jf++DRyQ7IPb1v5n97Iwi/3R+VO2L/AHR+VSC3m/54y/8AfBpfs83/
    ADxl/wC+DS5IdkHt638z+9kexP7q/lSiNP7q/lUgt5v+eMv/AHwacIJv+eMv/fBo5IdkL29b+Z/e
    yMRp/cX8qXy0/uL+VSCCb/njL/3waXyJv+eMv/fBo5IdkHt638z+9kflJ/cX8qXyk/uL+VS+RN/z
    xl/74NL5E3/PGX/vg0ckOyD29b+Z/eyLyo/7i/lSSRIInIRc7T2qfyJv+eMv/fBps0MogkJikACn
    kofSoqQhyPRG1CvV9rH3nuur7noNnc/ZPDUFwdxWGzEhVTycJnH6VHZeIormzW5uGjgjfOxlnEob
    AyRkDAPt1PapLKBbrw5b27khJrNY2I6gFMHH50z+x2ktkgudQuZkjIZDhEKlfun5QM4IyPevIjsj
    qr/xZerHWOuxX2oT2cYlDwjO7DFT8zDBOOD8vQ/0rRMjBSdzcDPWs+x0iOwupZ4ppS05LTK2MOSz
    MD04wWbp61eI3KQehGKZkZGm+KIr6xF3IvlRPtCCKXz3YkZ27UGQQOTSaP4oj1WSGExyJLJCJTt3
    MqnAO0nHHXv/ADp8OhPBbW8Q1K5JtcC2cpHmIBSv93BypxzmjS/D0GkSI9tcT5C7H3bT5i4AAPHG
    CM8Y/KnoBsBmJwCcn3rKbxDHGguZkeOwYsqXRbIYjOflHIHytg+3atMHByKx73w+lxY3FtHO4iZH
    8iBseXDIwI3cDJwWJwScZpAPk8T2iyqimZt0UkhzG6lNgU4YEZUENkEjFSt4jsEUlrl+MAbY3bcS
    QMLgfMQSAcZx3qA+HkcvJLeXD3MsbRTTYQF0KhSuMYHCjkDPFCeG7dHgPnzlLeTzIIztxGd4ducZ
    OSo69O2KegFyHWbW5nSGGd5JHGdqo2U6j5+Pk5BHzY6VdDMSBuPPvWVFoUEWoJdiWQlJHlC4UZZy
    ScsBuI+Y/KTj8a0wcEGkBhDxYN8IeDyklmMau04YBVk2MzAfdx1APUfSri+IbWS8treIzO0+7B8t
    wUxtIyCMgHdw3TjrTD4dsDYG08vCNL5sjqAryHczYYgcj5iKWDQ0gu47r7VO9ymFMjBfmjAA2EAY
    xgDkc+9PQDU3N/eP51jv4qsY5zBJOqTLdNbNG0gDKBnLkf3cDNa9Z1xodrdWkltM0hikuWuWAOMl
    s5H05NICBvFdl9ohVJmeF1bcwRy6uCgVdmM87/TtWrb3aXUCzQSFo26HkexBB5BB4waw5fCyj7M9
    rdNFPDMr+YIo1AAZScKq7c/IOo7nNbFlaJY2qwozNgszM3VmYlmPpySelMCxub+8fzo3N6n86Sik
    Au5vU/nRub1P50lFAC7m9T+dG5vU/nSUUALub1P50bm9T+dJRQAu5vU/nRuPqfzpKKAF3H1P50bj
    6n86SigBdx9T+dG4+p/OkooAXcfU/nRuPqfzpKKAF3H1P50bj6mkooAXcfU0bj6mkooAXcfU0bj6
    mkooAXcfU0bj6mkooAXcfU1U1Yn+xr7k/wDHvJ/6CatVU1b/AJA99/17yf8AoJpS2ZrR/ix9UGk/
    8gex/wCveP8A9BFW6wLsTN4X0tLdXZne2UqkrRFlOMguOVHvVaDUr6z2M0ckq20G64hbJdR5jDYG
    PBKgp82CWA96I7IK/wDFl6s6iiuTvNb120muImS182GEt5ewksfL3bwADwG+Xrjg10VtJMLp4J50
    kdIkZgsRXklsnPTHGMdRjnrVGQuo3RstNublVDGGMuFPQ4qqsutsisLfTsMAf9a//wATUmvf8i/q
    H/XBv5ViwSXsOqzXAjmMSzsiuZmZX/crti8vouWIww7jHegDX363/wA8NO/7+v8A/E0b9b/54ad/
    39f/AOJrDHiLVBpTzSNbCTcNsoHyIdpLRsduM5wBjJ65o066ScSy6zJLaWssrSQgSPGPMZiWBK4P
    A24B9/wANzfrf/PDTv8Av6//AMTRv1v/AJ4ad/39f/4mseXXtRk1r7FbskaSyhFLRbngG9VO5enI
    JIyelWYtW1RmWIQxyyPvKEJjIiZlfIznL4XGOm7jOKAL+/W/+eGnf9/X/wDiaN+t/wDPDTv+/r//
    ABNZUOr6ndTxxQXMZQxtK04tcgME3GLGcZBwM9earaXqjH7fezS/6Wd7x2wklLxg46oTs2KDnpnA
    oA3t+t/88NO/7+v/APE0b9b/AOeGnf8Af1//AImsEa9qd5bGFWRndZolNqu55WAOGGcYX/aXv2rp
    dKlM2l2ztcC5YoMyhdu49+Pbp+FAEG/W/wDnhp3/AH9f/wCJo363/wA8NO/7+v8A/E1pUUAZ6f24
    7YEGm9M8zOP/AGWnbNc/556T/wCBD/8AxNaUPV/9xv5Vg6ZpWsW2u3E95rctzp//AC725RAeeu8g
    du2OtAGjplzJe6clxKEVzLJGRGSV+VscZ5qzVDQP+QFH/wBfNx/6MNX6GAUUUUgCiiigCZ1iRtpE
    hIA5BHp9KbmH+7J/30P8KJ/9cfoP5Cs9Y5oyrSIyeeVaQxtufJYcYx12kDA9DTA0Mw/3ZP8Avof4
    UBoCMhZCD/tD/CqISZy6Hz9/y4UjhVJbluOu0D0qaEP5hVz8kSqPqSowp+nP6etFgLGYf7sn/fQ/
    wozD/dk/76H+FUY4mWFXjhZGVX3sV27yScc/xdj+FKkUyF5HWZm2FYxt25A7nIz39qLCLuYf7sn/
    AH0P8KqWl2LmTUsQuRaSCNEVhuf5Qep46mpIEkWImUufmIUspUkYHODz1JqtoX/H3rP/AF+L/wCg
    rQM0rVYLy1iuYC5ilUMpJwcH1GOD6ipfsif7X/fQ/wAKy3W/03U/slkbNLO9d3iknc5ikIyyKn8W
    fmYDtz+L4dRu4dXXTpbqwu32CRgA0UoQtt3d0ODxtHJqbsDMfUtSvdUaz0mO0Ty4EmY3O5idxYAD
    aR02/rUv2fxR/wBQj/v3L/8AFVW0RDJ4mvEWRoy1hAA6YyvzScjNXrjV9W0+R01AafDGN3l3DI5W
    YKM9FbIbH8OOvAzVpXdrgVLubxBpls13eJpr28ZXzFiWRWILAcEkjPNdAyRx7QwckjPBA71zmty6
    1eaFdvfxRWltFsO1B80xLgYIy2FGQeoOaveKJNUjsD/ZUNnLmCTzjcSMm1cHlcDk9f0oaswNPMP9
    2T/vof4UyWa1gUNMxjUnaC8iqCfTnvXLeC5dWk8KWn2yG1W3FiPs0kMjNK5xxuBGAfpXnC21neyM
    mt3t5EuxZMSSOA8x4Yktn5sAcdaFG5DnZpW3Pa9Suo7HTbm5WN2aGNnClhgkD6VFc30dnZJcTiQh
    iihYkLMWYgAADrya808My3Mltqe+e7li+wS+YZmfBYMoQkN0JUH9a9B1a0a80aKNUlk2vDIUiba7
    BWUkA5GDx1zQ1YcZcyuiS31uyuHmHmCIQ7Q7TEJhmLDac9GBQgimXt7b3elaokEqs8EcsUq55VgC
    OR/nNYU+nXS3rXFnpFyo8vyxHN5bg5DBmJ8zJb5sg+uc1JCt1pei6hbf2ZdmF4nKyt5QcZXkvhzk
    Dtiplszah/Fj6o6DSf8AkD2P/XvH/wCgirmT61kxX32Dw9p0ghaZ5EghRFYLlmAA5PAFSR67ZGGF
    55RA8pZdj87SrFTkjgDcCNx4NKOyHX/iy9WaWSBjJxSVSk1ixieZJLgK8LbXQo27OccDGW/DNQWv
    iCznN0JJPJa3eQEMrDKJ1bJHpyQORVGRdvoIrmxnhuJDHDIhV3GOB360LqelKqqL+PCjaP3qdPzq
    trxz4evyOht2/lTIEsGvBZf2fCHW2SfeYU2sCcYHvkUAXv7W0vOft6Z/66r/AI0f2tpYOft8ef8A
    rqn+NM/s+y/587b/AL8r/hR/Z9l/z523/flf8KAH/wBraXjH2+PHp5qf41H9v0bzjN9rh80psL+Y
    mduc469M0v8AZ9l/z523/flf8KP7Psv+fO2/78r/AIUAPOq6Wet/H/39T/Gj+1tL/wCggn/f1f8A
    Gmf2fZf8+dt/35X/AAo/s+y/587b/vyv+FADzq2lnrfp/wB/U/xpDqulHrfx/wDf1P8AGm/2fZf8
    +dt/35X/AAo/s+y/587b/vyv+FADv7U0r/n+j/7+J/jR/amlf8/0f/fxP8ab/Z9l/wA+dt/35X/C
    j+z7L/nztv8Avyv+FAEd1e6ZcRbE1drfnloZowxHpzniqfl6d/0Ml7/4Exf4VqQ6dZbmJsbQ4UkA
    wrj+VY2na/omp6zLpdvpQF1Bnzlk05VEf1PbPb1piNbT4rW302KGymeeFXdvNZgxZmOTyOO9T1j2
    N6NP8LLceSZMXcqLGhC5LTbR14AyRU9vrVvNNFDIPJmkdo9jMCd6sFKgjg8nr0pMZo0VQbXdNVtr
    XkYOCc4OBjOcnGAflPHU44pLvWre306K9ixPDKwVGDhEPXks2ABx1PXjHUUAaFFZsGuW8ouhMskL
    2u3zRtMgG5VIwVBB+8Bx/Krn223Fql15y/Z224kHIOSAP1IFAGdd6ldm6k23+jxqDgI7NuAHHPPW
    ohqV6CCNT0TI5HzN/jVaK60/T7K6mvLaKaVr6VVXy1ZyNwBPPYZGTU0OoafOb8ppNuyWQl37PJZz
    sJH3ByM4OM0xD/7SvcY/tPRMderf40f2le4x/aeiYzn7zf40SXumpLEv9mQlGWFpH8uMeX5pwgx1
    bnrjpT76406wujE+mwsqKjTSCNB5Ydtq8HlskHp0pAR/2je/9BPRP++m/wAaP7Rvf+gnon/fTf40
    wappv2WWdtJQBUjmVVjjYtG7bVbj7vPUHkVsnTrMEj7Ha8f9MV/woGZP9o3v/QT0T/vpv8aLO7ks
    4btk1LSWubmcSsS52KAAMAZznitX+z7L/nztv+/K/wCFH9n2X/Pnbf8Aflf8KLgYmqSzawluLy/0
    NjbTLcQsGYFHHQ9cHqetZg0K0Go/axc6HgciHe2wNv37uuc7vfHtXXf2fZf8+dt/35X/AAo/s+y/
    587b/vyv+FArGLDI1jqH2201HSZJZLdIZVmlIUFSxyuPXcevpVx9evpAA8/h1gCGAaZzgjoenWr3
    9n2X/Pnbf9+V/wAKo+INU0XwzbQTX+mxeRIAPMjslkAb0Y9s9qNwGXN5e65A2ny3Wj7Jyu77PI7S
    YDBuAeD0rRvJNVklH2TTIpYAuA7z7d3XPGOnNUoXt5tZ0Oe2s0tVm81tv2cRPjyzjcOo+lT+J72X
    TfDF5eWzBZ4LRpIyQDhhnHB60ARtJrNtCWbSbWKKMZJ+07VUf988U5m1u4Qb9ItpFByN1xuGfXla
    57S9Wutc+GX26/kWS5lDbyqhekmBwPYV03iG9udO0Ca7s4EnnhhdwjvtXAyST9MdO9MCnqaa7d6Z
    cwy6dBGjxMpka64UY69K0hIkFsjSyIqKoyxOB09a43w/r2o+Ivh9f3epxRhhHIizIQPNx1yo6Efk
    a6LWwD4dIIBB8oEH/eWkBa/tXT/+f62/7+r/AI1W1PU7F9JvFW9t2ZoHAAlGSdprrv7H03/oH2n/
    AH5X/CqOuaVp8eg6g6WNqrLbSEEQqCDtPtRJaM1oP97H1Rz8Onw6loGnQ3KhokSCUoVBDbQDgg9j
    UT+GLR5ICH+SBfLRWiR9se7cEUsDjBzz1xx2q/pIJ0exAGT9nj/9BFWulTHZDr/xZerMJPC0UV79
    riu5EnXmJ/KQlTknLHGXPJGWq3/YygKRdTLKsk0okAXIeVcE46cZyK0qKoyKWsxSTaHeRRK0kjws
    qqoyWOKfFpcy6it6Xmz9lW3MPljAwc5z1znNWxkcjNG5v7x/OgB3lSf883/75NHlSf8APN/++TTd
    zf3j+dLub+8350AL5Un/ADzf/vk0eVJ/zzf/AL5NZ+mxa1q8c81veWkUUc7xKrxMx+U4zkMKuf2L
    4g/6CNh/4Dv/APFU7CuSeVJ/zzf/AL5NHlSf883/AO+TUf8AYviD/oI2H/gO/wD8VR/YviD/AKCN
    h/4Dv/8AFUWC5J5Un/PN/wDvk0eVJ/zzf/vk1H/YviD/AKCNh/4Dv/8AFUf2L4g/6CNh/wCA7/8A
    xVFguSeVJ/zzf/vk0eVJ/wA83/75NR/2L4g/6CNh/wCA7/8AxVH9i+IP+gjYf+A7/wDxVFguE80l
    nE0n2S6nLAqEhjLNz3+lZ66hKsjOND1QM+NzC25bHTJzzitD+xfEH/QRsP8AwHf/AOKo/sXxB/0E
    bD/wHf8A+KosFzLtdKN14YitL+CSEPcvKY5E5IEocAg9jgfnSN4ctSjxLI6Q+S8MUagYhDMr/L9G
    UEZrUOia+euoaefrbt/8VR/Yevf9BDT/APwGb/4qizC5j3HhaymmZ1Plq0QiIESMQFTYuGIJXA7D
    ritKW3lNrHDbXJtzGFG/ylfIAxjB4qb+w9e/6CGn/wDgM3/xVH9h69/0ENP/APAZv/iqLMLmQvhq
    GK0a2huJFhLJJsdFkG9QFyQfvAgD5TxnmrNjpBsLCO0hvJhHGiqpCqNuHLEgYxznB9hxV7+w9e/6
    CGn/APgM3/xVH9h69/0ENP8A/AZv/iqLMLmNF4ej1TTLqG/s/v3Urxu0QZlUuDlcjocVcm0KWeWa
    R55/nikiiHlL+5D43dvm6DGelXv7F8Qf9BGw/wDAd/8A4qj+xfEH/QRsP/Ad/wD4qiwXKLeHkm/s
    /wC0o04sVUKWhUMxXG07sZHQHA4NLPoC3jWhvA9z9mbfmSFdzndkfNjIwQOBjOBmrv8AYviD/oI2
    H/gO/wD8VR/YviD/AKCNh/4Dv/8AFUWC5ly+FkkgvljLwzXrKZJo7dQdqtuC4xg89zyc1seVKeqO
    T3O01H/YviD/AKCNh/4Dv/8AFUf2L4g/6CNh/wCA7/8AxVFguSeVJ/zzf/vk0eVJ/wA83/75NR/2
    L4g/6CNh/wCA7/8AxVH9i+IP+gjYf+A7/wDxVFguSeVJ/wA83/75NHlSf883/wC+TUf9i+IP+gjY
    f+A7/wDxVH9i+IP+gjYf+A7/APxVFguSeTJ/zzf/AL5NZ93fvIxibRdSlRQFz9myrEdxn3HFXP7F
    8Qf9BGw/8B3/APiqP7F8Qf8AQRsP/Ad//iqLBczoXur7xBp0p02+gjgMpd54toGUIHP1pniMaHqd
    gdM1e4twrRjKtIAyHnDD0IrU/sXxB/0EbD/wHf8A+KqhPp2qxMxmvdJGMks1s3Qdzz7UWA5xLXQN
    B8JXGnaTdwSO4BZi4Lytkcn/AArptau9OeyksLy+hgM8DxsC4DKGyM4/GqyLdwahp0c8+nTw3c3l
    /uLcg42k5yfpUyQXOpXt4sNwkC28ix4+zJIWyitklj/tYx7UAc9bRaNoHgy70qx1SO4GyRlLuu4l
    u3H0rc1r/kXv+/X/AKEtJq1nf6XpF3fC9jlNtE0uxrKMBsDOCQcina2/maAXxjeYmwO2WU0gO6rP
    17/kXtS/69Zf/QDWhWfr3/Ival/16y/+gGnL4WaUP4sfVHFXkayeF9LEkUksIe2MyIjMSgxu4Xki
    qjSaxBPFHY74bFnLW6vCzMVyAEYYJUYyRuK4BHPGB0Ojoz6RYhRk/Z0P/joq75EnoP8Avof41Mdk
    VX/iy9WctBe6k0+LqW7W288iS4hg46ZVUQpuA7EkHtg1WuLvU7c6bNd3FzF9oZo5pI7cF4wZAAqj
    aeSoz0Oetdl5EnoP++h/jSG1dsbkU7TuGSDg+tMyONVtXDTT7Lh7qWSF4omi/duq5Ac8fK3C5GR1
    JwKsJPq88pWK4vRbpC8glaBVd5AinYQV6bsgcDPPJrq/Ik9B/wB9D/GjyJPQf99D/GgCvbO8lrC8
    q7ZHjVnXGMMQCR+dSDqKk8iT0H/fQ/xqOYi28vzmVTI4RAWHzN6UATeDf+QZd/8AX9N/6FXQVzun
    ummQNFbhwryNI2WByzHJ7Va/tST/AGvzH+FVdCsbFFY/9qSf7X5j/Cj+1JP9r8x/hRdBY2KKx/7U
    k/2vzH+FPS/ncZUHAOMllH9KLhY1aKy/ttx6f+Pr/hR9tuPT/wAfX/Ci4WNSisv7bcen/j6/4Ufb
    bj0/8fX/AAouFjUorL+23Hp/4+v+FH2249P/AB9f8KLhY1KK868QeNtYt7a5gjsJbSWPafOMittU
    tgHAHfBpZfiTd2zeVPpbJKoGQ06g9P8AdrL28b21+5ne8srqCneNn/ej5edup6JRXmw+KNyT/wAg
    1Pxul/8AiaP+FmXrN8tnbKP9q6X/AAp+1j2f3Mj+z6vVx/8AA4/5npNFeaf8LE1Rl+VdNU/7U4pG
    8d602dt1oqD3kz/Wj2q7P7g+oy6zj/4Ej0yivMv+Ey1p851nRY+O2TSnxTq5A/4qXSF+kf8A9jR7
    X+6x/Uo9asPvf6I9MorzJvEmqsc/8JXpo+kQ/wAKX/hIdR/6G6x/78j/AAo9o/5X+H+YvqlP/n9H
    /wAm/wDkT0yivM/+Eh1H/ob7H/vyP8KB4k1RSceLNOI/2oR/hR7R/wAr/D/MPqlP/n9H/wAm/wDk
    T0yivMx4q1dQf+Kl0hvrH/8AY0h8Y60nTWdFk478Ue1/usf1KL2qw+9/qj02ivNB8QNWh5mbSpx6
    RTbT+uamT4pov/HxYyL67Jkb+lHtY9br5C+oVX8DjL0lH/M9FrlNT0pXuZ5ptU1CNWJbYhBVRk8A
    bay1+KdgesN0v/fNZc3iTw5e3LzzyauryMWbbcMAPoB0FHtodx/2div5GbTWUdrrGjyNd39y0lxh
    BOwAT5Cc42g9Km0++t9Pu9UkupNiSXsUKnaTl2ijCjj1NYdtr3ha3vIboT6i8sLb086V3AOMdD9a
    ik8SQLdzz6Zri2qTsGkSWyMh3BQuQcjjCjj60nVpv7SD+zsWv+XUvuZt+Jtd0+48M6lbxXG6WaC5
    iRfLYZaIfOM47fr2zTNX/wCRbX/dh/8AQlrGm1eTVbSWzufFNqYLhTFIv2IoSp4ODu4+tbWt7P8A
    hH2ETB4wYgrA5yA6jrTjKL2Zz1aFWl/Ei16qx3dZ+vf8i9qX/XrL/wCgGtCs/Xv+Re1L/r1l/wDQ
    DVy+FiofxY+qMLQ/+QRaf9ei/wDoIqes61uHtvDltJHLBC32aNfMnzsXKjriqX9pXX/Qa0b/AL4P
    /wAVUx+FFV/4svVkUuoSw6nftFdyS3EN0kcdjvBDRlELEJjIxlm3e1R6VrV3quraaLiOKJWZ22xS
    hsgxE7WAY8jHfB9hU4v5xJvGsaIHIxuEZz+e6hb+dPu6xoi854jI59fvVRkUrPV722jnuZjcSLsm
    ZRcOpSQibavl45AVclgecYPvVr/hI7qO4aM28VzGhb9/b52SKhBkZeegUjuef0k/tG4xj+2dFx6e
    Wf8A4qkF/OqhV1jRAoGABGQB/wCPUAa+nTyXem29xPGI5JUDlR0Gen6Yqtq3/H3pP/X4P/QWql/a
    VyP+Y1o3/fB/+KppuftF3aSXms6W0dvL5u2MFSTgjqT70gOhoqn/AGxp3/P/AG3/AH8FH9sad/z/
    ANt/38FAFyiqf9sad/z/ANt/38FH9sad/wA/9t/38FAFypP+XYf7/wDSs/8AtjTv+f8Atv8Av4Kr
    3msI6IljqmmxqCWYyncSfbBoA1AAThjgdz6Vyel67drp6SCeK7hiSN5XkbdJIXmePAYHAwFHY1d/
    tK5/6DWjf98H/wCKpFvplGF1fQ1HoIyB/OiwDJdYurnw1qVwGWO5hKqPs+PkJK8B8lWOD94cewpo
    1i6soGikdUdZJj/pzZdFQArGxUgF2JJUgnjHXtKt/OqbF1fRFX+6IyB+W6hr+d/v6xojcg/NGT06
    fxUwGxeI7ySZE/s8pvmWHnPyszAgH38rLfXFdFisD+0bjOf7Z0XOc52Hr/31S/2ldf8AQa0b/vg/
    /FUrAZ3ir7ur/wDXG2/9DasTxPz4huP9yP8A9BFbWuwyyaDqN/Jd21z5vlRBrdSFG1s+p55pbvRj
    qur3bx2yyNGI1ZmuCnVARgbTRSko1m32X6mmPpSq5dCEd+aX5QOPwPQUYHoK67/hEZf+fKH/AMDW
    /wDiKQ+EpAQDZwAnoPtp5/8AHK7fbwPm/wCzK/kZkel290tvbRReXPJbLN55ckFicbSOgB4HFInh
    9JkEkV2BFuKkyIFIwSGOM9AQPrntWw+h3Txi0cRlIhvEJ1I/IPXbt4HPWg6Fc3waTbHcKy+WWGol
    wQDnbnb64OKj2yNvqE3ul95jyeH1ijjV7nFxIrME8v5V2oGYFs9snt2qX+wLYQopncvNPFFDMIwU
    cNuBIw3I469eMYrVPhy9LbjCCwJOft7Z5GD/AAdx1pt1pd3aQ3F7cq4CR7mZL5mZsdB90d6PbLuC
    y+X8q+8xRoSSWhmhu0d2LeTHtw0u04OBnPJ6cfXFT/8ACMxkIy3qssjBEKoG+fJBBw3GMe/0rUTw
    5erbtCsAWJzuZBftgn6bKS60+5jIN3PGrRgMBJqhBUDvjbn1o9su4LL5fyr7zGstLg+2zpKI5kW1
    E8fmP5SndtxuPbhvXrT5dBhJunS5SIJI8cUbj5nKqCw9e+AQDmtY+F7r5gbZOVEZ/wBOblR0X7nT
    gce1PHh6/WN4xFhHAVl/tBsEDoD8lHtl3BYCdrNL7zEl0COC1NzLdARRgiZVQM8bgqCuN2OrDqR3
    qPVNPt44WntWI8uODzIymAC8YOQcnPQk9OtdC+kajCiyyEotupIY6i+I1xz/AA8DA/SoT4auZkJN
    ujrIFJzfsQwA+X+DsOlNVkDy+drJL7zJ/sSCXVL6L7Qltb2zKNz4J54A5IoHh5S3lpdZkRFll/dY
    UKc/dOck8dCBWydPvjqCwKZWuUg3km/YBVLYwDt56Clj8O3scquLdCV28G/fBCnIB+XpS9su4/7P
    l2X3mda6Np6/YXeSWUXDkjdHjKbM4I3cEcn39qonRkNq88Vw0g8nzo4xGA5XnLMM8AEHkZro76wv
    nkae5EEAfav/ACEWReOg5Xnv3qBtBuo4Vt2SNI5MKsbaiQHx0AG3nr096FWQSwEtkkcdR+Arq08L
    +Y7Ilvas6feVb8kr9Rt4p/8AwiMv/PlD/wCBrf8AxFV7aBl/Z+IXX8TB0C2huvEFhDPGskUkyqyk
    cEVvMp00avpIJ8mOWOaAE9FLjireleGZrTVrSf7JCnlyq277UWxz6bRmq3ir9x4kRh/y8QhD+EgP
    9K48Q4uUZRPocphWjRq0Krumm1rfVWf5XPVaz9e/5F7Uv+vWX/0A1oVn69/yL2pf9esv/oBpy+Fh
    Q/ix9UcJrX/JP0/694f/AGWuFKLn7q/lXoF9Gk3gu3ikR3EkUCbUYKSTtA5PvWYfBk4JBtTkf9Py
    f/E1rh5xjHU8/NcNUrVnydG/zOR2L/dX8qNq/wB1fyrrf+EMm/59f/J5P/iait/Cr3SyNHaPhJHi
    O69QfMpwcfL0zW/toHl/2fiP6ZmDTLZryLTlQC5dVb7QzfIMru+6BnGOM5psehpKilbmAFlEvzrt
    URF9gYsenPaukj8P6lFCsUauqL90C+j4+h2ZpI/DeoxQpFHG4jRgyr9tjIB/746e3Sp9rE3+o1Oq
    /E5y40MW8E8u/d5WPk8nDYOPmYZ+VeeD0NS2ukW2oW0S2expuDM7vjyuucrjGOODu/Kt6Tw5qMsb
    xyI7LI25h9uj5P8A3x04HHSlHh7UlijjVHVIiCgF7GMY/wCAc/jR7WILA1L7aepgDQYI7mFZrqJ4
    ppljjMShvMzjIyMheCPWlbQYGjWSO4QQmUxLIYzlm3YUbe3Q8+1bx8P6k3mZVz5mN3+nR9umPk4/
    DFOGh6qHL/vNxz/y/R9/bZ7Ue1Xcf1Kfb8f+CcvfaKLKB382N5IQhljCY27umD3p8mm2wuxp6R/6
    QBuact8uNu44XHp71s32gXVtZXE9zHK0KRgyAXyMSqDjjbzirS+HdSijSFUdViPyj7bHlSPfZn8K
    PaxJ+o1b7fic8PD4ZY2WeMicZt/3Z/efLuOf7vH1qa30C2j1ER3VxFJEs3k4SM/O4GSvbHGOa3P+
    Ef1RvN+WT95w+L6P9Pk4/DFEWganC8skYkDSnc7fbozuPr9zrR7Vdylgpp/D+JgXPh0RuUhkV59n
    mCFYyTt3beD3Oe2KfJ4biS3UrcRSSTzRx27KAVfduBBwTjleua2m8O6k0nmMJd+3Zu+3pnbnOPu+
    vNPl0HVJc+YJD8oXAvowAAcjGE4570e1XcPqU/5fxOdfw8is4S6glCpuURAO7HnI2g9scntWRtX+
    6v5V3DaDqblywfLrtOL2Mce3ycdT0qp/whk3/Pr/AOTyf/E01Wj1M54Cs/hX4nJbF/ur+VGxf7q/
    lXRr4e36s2mpZzNcrGJSBdpt2nPfb7Grf/CFXX/QPk/8Dov8KftoGf8AZ+I/pjCAPhY4AwPtR6f7
    y10Okg/2lqhwcbof/RYrEv4hb/Dy6gVCgivChUuHO4Fc8gAVpxRab5mqXer3F1HFA8KIsMrrksg6
    KvU1wPWtL5fqfUwi4ZfSjLdSl+UTdwfQ1m6ms0eoaZdR2k9ykDyeYsIBYBkIBwSO9T2+k6Fc6k1k
    kmphwXVXNzIEdk4cKc9QetFxpGg299JZ+dqclzHCZmjiuJWOMgY4PUlhx756VfKc1zDvNJvJrGa1
    S0Y3m6WRr3jEqtu+TOd2SCFweBirvhyxmtI5zJBNEriMKJlRXJVcNlU+UDPQ9T3rW07w7o+pW7Sw
    vqSlHMbpJdSKyMOoIz1q1/whmm/89L//AMDJP8aLBchwfQ1m+IVP/CPX3B/1R7Vsf8IZpv8Az0v/
    APwMk/xrM8SeHbPSvD95d20l35yR/KXuXYA564J60WC5cUHavB6CucvtOnfTtQszp0s93OZGS7VV
    wQzZUbidwIXC49q0ruz8PWck0Jl1SaaExK6RXErHdIxVVBzgnIOfSrUmhaRBpi3s41aIMQqxNcye
    YWJ2quN3UnGPrRYLmBqdrrURmisftjRRTFraQOZHb5VwHywyud/LbvTGKI9M1YtYJJJfeXK5a9P2
    k5XEhxg5yo2notayWOguYcf2wEd/LdzNKFhfdsCuc8Hd8vGea1/+EM03/npf/wDgZJ/jTsFziZtP
    8QTiVJJLoqYnjjQYKsuHGHO7qeP4SeRyK6y3RktYVZSGWNQR6EAVa/4QzTf+el//AOBkn+NH/CGa
    b/z0v/8AwMk/xpWC5jop/wCEpl4P/Hkvb/bNaWD6Gsq40rTrTxBdw3c93HZWtksxIuH3Elj1IOWP
    YD8quWui6HfTQx20mpyGSJZiRdSYjDAFQ3PBIPSiwXKWuafc38lh9lWHdFM7lp4RKi/u2AyuRnkg
    cVRXTJ4rZopNPluDJapbwFyrG2ZQQSWJ4BOG3DnjpWtJpejR6nNZLHrMjQY82SOeQpHkbhk7s9PQ
    VNp2g6PqRmWM6rFLCQHimuZFZc8g4z3osFzB0PSby01XfPFMSkk5kmkVAr7j8rKR8zZ6nd07V02D
    6Gpv+EM03/npf/8AgZJ/jR/whmm/89L/AP8AAyT/ABosFyOIHzo+D94fzrjfGw/4nOmHvkj/AMeF
    dsPCmn2jpPG94XjYMA907DOe4J5rifGh8zXdPQclAWb2+cVnVWi9V+Z3YB/vJP8Auy/9JZ6rWfr3
    /Ival/16y/8AoBrQrP17/kXtS/69Zf8A0A1pL4WctD+LH1Rxs/8AyKth/wBuv/oSVvS/61/941hT
    /wDIq2H/AG6/+hJWhLpmZn/4mWqfePSZPX/cqY/Ch1/4svVluqWk/wDHtc/9ftx/6MNQvbwx3kNq
    2q6oJ5lZkTzk5C4yf9X7iobG3torJhcalq6u99cxRpbL5jyEOSSQEPOO/AppGZs1zuuA/wBpYhka
    4uWjCx2qmRWTII3KVIX/AGjuz04xWpHa2U0kqRap4jcw53lYCQCACVz5XXnp1qxZ6ZaXtlNcR65r
    McMLFJPOKx7SOTkNGPWnYVzmJtX1C3tNPht5nuGaJEkMkRUzMx2kLheqdzkdjzSW2o31ulukl5II
    vssSzXjW5Zo3AkyhXGCdwC5xnvnmuhlgsIY43l13XEEil8MoBVAcF2Hl/Kv+0cCtT/hFf+o1q3/f
    2P8A+IosFzmdLv8AVZriCS9BRZp3he38nAhAj3Z3dT82RzxW/U//AAig/wCgzq3/AH9j/wDiKP8A
    hEx/0GdW/wC/kf8A8RRYLmR4g/5F7UP+uDfyrTm/18n+8f50y88IRSWUyTarqkkbIQyNKmGHofkq
    K5sLE6s1q+t6skzyYwpXy1dhuCbtmAcHIBOcYosFzC1Mx/8ACVwC6m2QC3jKq3m4Zt7Z27CBnp97
    PaqGjXmtlLeyi8qHZbhY45IyWwIwQ5+XAy3y8tj2rp/sumDSU1L/AISTVBZyvsSTevztu24A2ZPI
    qbUNIttNjVrnWtaw2TiPa5AHViBGcAdzRYLnOX+valBZxXccXk+azSxxSISCgwBGSFJLE5P8PB68
    VBbXt/ai2je4l48xLmV4CxtB5o/BsAjrnr7V0lvZWdxqC2kWta6JZFLozKFSRRjlXMeCOR3rR/4R
    Xp/xOtW4/wCmsf8A8RRYLnK2OpatNKssxPlC4hh8ryMB0fOZM9Rxg46DNdHU/wDwin/UZ1b/AL+x
    /wDxFH/CJj/oM6t/38j/APiKLBc56z/5KFc/9eCf+z0Wl5r7+IZY7nSo49JI2xSidDIpH8RGeQfT
    t+dRNo4h8eXNp9vv2DWMbmbzFEnV+AQoGOPStEaJB/0EdX/8CB/hQwMLVv8AkRtS/wCwlJ/6Etas
    PhyHWo9VS8R4jIUFvN8wxmNQ2MEZHArJ1RBH4D1BFLsF1FwC5yx+Zep9at3/AIwi0q6Nm9tPI0aL
    lkYAcjNRFN1Xbsv1OytKMcFBydlzS/KJ0MWgtbalPd217FHIRL5UhgJcl+gkOfnVf4RxxReeHYf7
    Sm1DS7n7HdyQyIWIdhvdlJbG7HRSOPXPauW/4WBB/wA+V1/32tH/AAsCD/nyuv8Avta25Z9jzfrF
    H+dfed9pSmysI7eZoNyZA8iNlXH0JJz6nPNXPtEf979DXmv/AAsCD/nyuv8AvtaT/hYEH/Pldf8A
    fa0cs+wfWKP86+89L+0R/wB79DWP4t3Xfhm8htleSV1AVFUkk5FcZ/wsCD/nyuv++1pf+FgQf8+V
    1/32tHLPsH1ij/OvvOmfwrYpdXVxaCBTcRKphuImmi3B2diVJxyT2xjHHWpho8q6ZFaLfRhYWWaN
    fIO1ZVl8wADOdg4UL2A61yf/AAsCD/nyuv8AvtaP+E/hIJ+w3eB1O8Ucs+wfWKP86+86i20e7tr+
    CY31tLErtM0b27/LI7szsmG/2sDOcfia6L7RH/e/Q15r/wALAg/58rr/AL7Wk/4WBB/z5XX/AH2t
    HLPsH1ij/OvvPS/tEf8Ae/Q0faI/736GvNR4/hOcWN2cDPDij/hYEH/Pldf99rRyz7B9Yo/zr7zo
    77SYdW8T3n2uJzbG0QRyjcoEgLYwRg5AJpLDwpDp95ayw3MeIREWk8k+axSMJtD5+4cZKnP1rnf+
    FgQf8+V1/wB9rR/wsCD/AJ8rr/vtaOWfYPrFH+dfedVdaLNc3cF19rtFuY1QtcrZ4lLqMcMD9wnq
    pzxkZq/okEun2rRXc0ErltxkiiZS5PVmyTkn/wCtXDf8LAg/58rr/vtaP+FgQf8APldf99rRyz7B
    9Yo/zr7z0r7RH/e/Q0faI/736GuA0rxhHq2p29lHazxtM20MzjA71uteWccVzLLeiKO2cJK8g2hW
    IBA5POQw6etS7rdGkJxmrxdzfmmR4yqkknGBg+teY6n/AKbrer3PVLXyoFPvvUmunutasLe1WdLz
    7QskckkXlfMHEeNwznAxkda5fTgZfCF3eOMPd3YkP/fa/wD16ynrOK/rQ78N7lCrU8lH73f8kz1e
    s/Xv+Re1L/r1l/8AQDWhWfr3/Ival/16y/8AoBrSXws5qH8WPqjjp/8AkVbD/t1/9CSrsuv6SJpA
    dRtchj/y0HrVGf8A5FWw/wC3X/0JK6GSaQSv+8f7x/iNTH4UOv8AxZerOdudVsJdVsLmPVLAQ24k
    EitJ8x3ADjtxjvVrTra31nQ5mh/s65C6jcOn2nJUgsRlWXkf1qe8v9Qiv7eK2kR1cjMXzFyufmYt
    nCgD2OTxxTLK+1O00+Q6dCZQ+p3ImcQGYou44O3euecDrVIyZattGls79biC8shKkRBuNpEly+za
    PNGcEZwxI5JAqzdaUk2gf2RHeQC3kgdJnfl3diDuz7ncT65pmleJ31LUHhTaYipigkMRVLmUIHJD
    ZOBjPy4JwDz2q7bareT+EYdSS2WW8ktVm8lM4LEAkDviqEYEnheSVEzd2KA7gIlLFLXOPnizyW4J
    weMsa7H7XB/z2T/vqs7w9qz6rb3RkZJGt5zD5iwtEH+VWzsblcbsde2e9a9AEP2uD/nsn/fVH2uD
    /nsn/fVTUUAVLm5ha1lAlQkqeM1i3GkibxKuordWwQSLJvJPmKAu3yx22nrnrkmt+7/49Jf901iX
    Gv3UXiVbJY4zaiZIGYqfvMm7l84Dcj5dpyMHIzigDPm8NLf+HktL28iS8jkkZJbeZ1UB5N5BGRn0
    5rS1aC51CxmtRc2DxSOVCyhuEwMHIPLBgT6Hj0qBtc1Q+GV1IR2qyxmUzoqM4OxyuByMDjJY9P7p
    q/rF/e22kreWQhO1PMkBQyEjA4ABHHPLZ4A6GgBNPtYrW8lubi7jmk8tIImJwVjVRn8S2Sf+A+la
    X2uD/nsn/fVYmi+JTqt+Y5EMEb7lgBjJEpQ4cq+cEZ7YHHOew6GgCH7XB/z2T/vqj7XB/wA9k/76
    qaigDg9Rv7W1+IdzcTzokI0+Nd3XkmTA4qQeI9K4/wBMT/vlv8Knl/5Kdcf9g+P/ANCet7JpMZ5/
    qUiy+Ab+RDlH1F2U+oLLWF4nI/4SG4/3I/8A0EV3Hj7/AJFaf/ron8xVGPTzqOp3265kiERiACIh
    zlAeSwJqKcuWs35L9TbGUfbZfCF7e9L8onAZHrRketejf8I4P+f+4/79Rf8AxNRSaLFFcQQNf3Pm
    XBYRgQxc7Rk/w+ldf1hdjwP7Kl/N+B59ketbGn31rbaMyXCJITcGQJ/FlUBU+uM5H4+1b8tvZQmQ
    vf3oijDfv/s8XlsyjJVW28twePUY61LYadBqKOYry9Rk27klgiVgGGVP3ehFDrp9CoZZKLupfgZ5
    t9Iu7y4mupbd98/mb1lVB95QUxuzjGTkDHvxVCIaXJa28jxWyyXEqRyJ5rfuVy4LAbuOAp5yK6n/
    AIRxf+f+f/v1F/8AE1W1LSf7P0u6uku5ZHjiJUPHHjPrwtSqyNXgG9br7jFnj0h5ooneLY0RaScS
    kupUDA646Z4xSzQQW7WkMlvDHFcF2kjjmG19mfLJLNx1ORkZroh4cUgH7fccj/nlF/8AE1n6j5US
    XE815qdylup3ziGJkG3qu8jt+VHtg+oPuvuOfhFhFNfGRbacLIixfMypgsQxUZzwPUmn2M1nbXN5
    G7qYrebz4GODvKEgDPcHI4710w0yxZInXWtyStsjYeTh26YU7eTUf2LTQkj/ANvJsiYK7ZgwhPQH
    5eDwaft0SsuktmvuMywi0qC0WWWaIO0ZSRxIB5ispLDbksMdOg/Gorax0qKMfavKkmJY7EuVxs3c
    EndgEDHGc89DWxcafZ20DyHVXdhC06ooh3SKATlRt54HWrMfh9JIkkF9cAOoYAxRdxn+7S9sV9Qf
    dfccdqMVnHY27WvlqxPzAvvdv9okHAHsQDWZketd7/ZO7WDZC7lVEthKXEce5mLY5+XHT0qz/wAI
    4P8An/uP+/UX/wATVLEJdDKWVuTvzfgec5HrRketd7e6ZFY+SGub+Z53KRxwW8TsSFLHjb6A1C1v
    ZBI5I9QvJo3jErPFbxsI0PRn+Xgf4Gj6wuxP9lP+b8DC8HH/AIqzT/8Arof/AEE118t9Zaa+qJqK
    OJZpluLM/ZmlG5YkCsCFIBDKevpWfZQW9xemK21LUI5AzqkohiUOU4bYwXt61YHhTH/MZ1X/AL/D
    /CsK0lUZ6GEw7w8HG99TO1FLE2cCaWxmFtZXE14/JIkmCHLHGNzENwOmOgqxboE8A2wA67D+cgqL
    U/C8dlpd7cLqOoOQhd1aQYkOP4sDmrRXb4GtR/sQn/x5awX8T5fqeutME/OS/BP/ADPSKz9e/wCR
    e1L/AK9Zf/QDWhWfr3/Ival/16y/+gGtZfCzlofxY+qOOn/5FWw/7df/AEJK0JX1Xznxbafjcet1
    J6/9c6zp/wDkVbD/ALdf/Qkrel/1r/7xqY/Ch1/4svVmLLp13Nei8exsPtACjet/MuQpJGQEwcZP
    UVo+HrAanpFyl9bRMy6hcN8k7Dad5zhgAcflmszWLfzdRtGht5muVkjIkEZK7N3zAP8A8s8DJPTd
    05px05L7SzI6yuINUuW2paC5U5LD5k69+COlUjJnUpolrFcNPHYwJIUKfJKwAGMZAAwDjjI5x3p1
    tpEFnDbxW9nEiW0bRQjzmJRWxkA4z2H5VyJtNaJvA9i4mli8vykiwLeEKpCpKOGG4Y2DrzXS+FLe
    W20yVHjdIzOxiDRGLKYHIj/gGc8fj3qhGja27WVusNvbxJGvQeYST6kkjJPual3T/wDPOP8A7+H/
    AAqaigCHdP8A884/+/h/wo3T/wDPOP8A7+H/AAqaigCpctP9llzHGBtPRz/hUD6XDJqC3z2cJuB0
    bzWxkcA4xgnHGcZq5d/8ekv+6a5i8srtvGiXCwTECZCrhCR5WzDHzP4Ruz+779e9AGmPDlitnHai
    wj8mNmdV+0P1Y5YE9SCeoPB9KkuNDtblWWWxhIaTzDtlZSWwFPIHQgAEdDgVzSwq3hywtLjTtQJM
    txiV7aWR4F8wkNt5O8gjax6cnPY6niFo7m2htZNPvZQrmMTm3eURgKp8wKuctzhSRwQ3pyAalvpM
    FreNdQWUCTMMZEjYX1wuMLnvgDNXd0//ADzj/wC/h/wrnrKzMfiqKW2trpI1iZbiSZCpc4G1i5/1
    mey/w+g6V09AEO6f/nnH/wB/D/hRun/55x/9/D/hU1FAHGMWPxMuN4AP9nx8A5/ieugrBl/5Kdcf
    9g+P/wBCet6kwOZ8ff8AIrT/APXRP5iq9rfWlhqV/wDa7uCEymIqruASAgB4qx4+/wCRWn/66J/M
    VBZX8tnqOopbwW8kjATEzgkBI4kJAx3O4Y+lZL+I/Rfqd1T/AHOn/il+US1/b+lf9BG1/wC/gqlq
    Gp2U9xZ3Fpq+nxy2zu2JiWVgy7exBror/UykGnmys7YS3kLT/vlyqqqhiOO/NM02+ub7U7Zfstj9
    kntRdEKh8yFWHyBj0JJz6fdPpWtjiucpcf2bPZvY/wBtWa2WXkjXPzq5yRls4KhmJxjPbNWNGutL
    0uKUNqenAybBst/3ca7RjIXJ5PUn6V6F9mg/54x/98ij7NB/zxj/AO+RRYLnHf2/pX/QRtf+/gqp
    q+qWF7o93b217bySvEQFDj/OK7z7NB/zxj/75FYnjKCJfCl+UjRSUxkKPUUWC5krr2lAD/iY2vA/
    56Csi5mspLO5sYda09LKcu2HBaRSzbjg5xjcT1Heuq0fUzf3scctnbLBcJM8G1fmUROEbd2OS2Rj
    piok1a5nujHDY2W2czi33A5TyXCMXwPmznIA+lFgucnqkOm6hJdMmt2SJcSF/LZjtTKquRtYZb5e
    +Rz0p8cWkxzaY/8AbNmRYkkjj95l9/rx6V0EHiSSW5gjawtgodY5iI26tIUznGI+Rna/J+6Oa6z7
    NB/zxj/75FFgueUHTNHLSk6zZN5oYlmJyhO7G0BtuPmHUE8cYrpItb0qKGOP+0rU7EC58wc4GK7P
    7NB/zxj/AO+RR9mg/wCeMf8A3yKLBc4IapYLrr3TXtuIHtVjVzIMMd5JxVz+39K/6CNr/wB/BUmo
    TNaeNnjtYYGlngihj81fkQks2SBz0U9PWr/9reboVjdQWVstzeTCBQ4yitkgk45I+U/nRYLnPapc
    6LqxtRNqkCxwuzkJMUY5Rl4YEEY3Z/Cq4msYo3SDWrBFniWCf5RyigqpUA4VtpIPUZ5xXR2up3l3
    cad5drp/l3MjpJHsbeojYrI4PTGQMZH8Siuk+zQf88Y/++RRYLnmmlJpOmXxmTVNPEatIUEY2u4c
    8CRs/Nt7Vtf2/pX/AEEbX/v4K7H7NB/zxj/75FH2aD/njH/3yKLBc4HWtZ0240S9ihvrd5HhYKqu
    CSajY58DWp/6Zw/+hLXX+JbWI+GtR2xIG+zvghRnpXGq27wJan/YiH5OKytar8ju3wX/AG/+h6VW
    fr3/ACL2pf8AXrL/AOgGtCs/Xv8AkXtS/wCvWX/0A1pL4WctD+LH1Rx0/wDyKth/26/+hJWhLpFs
    Zn/eX33j/wAv03r/AL1Z8/8AyKth/wBuv/oSVfl1qzEz83P3j/y6Tev+5Ux+FDr/AMWXqyrcW+nW
    11bW0k2oedcvsRVvZz2Jyfm4HBqfRdQttG05oXS8mefUbmOJI5cscMSclmHYdzWdfLpF9qFreulw
    LiCVZN4s58uFDYU/L6tmtHSII9X0Wfy2hx/aFw4FzZGVSCx6qcEH8RVIyZrza5bWl0sN7b6hbIyN
    J50jDYAACc4YnjIHTqQO4q2Ly3XSDqM32qGFULlWclgB7Ams6XQLaeyntpruaUPbR2sbSRFiiJg8
    /wB7cwyemenYURaKE0yey+3GOK48wyrBbFFDMFA2DnaBtPGTksaoQreJ9ORRvW+VgT5qFsmIDGWO
    GwRyPuknnpW79mX+/L/38b/GuVfwrFIMm7jVn3B1jsyscYOBmFc/u3+X73PJJxXVfaovVv8Avhv8
    KAD7Mv8Afl/7+N/jR9mX+/L/AN/G/wAaPtUXq3/fDf4UfaovVv8Avhv8KAIrm3UWsp3y8KeshqlL
    qtnFqy6exuvMLBC4Y7Q5GQvXPTnOMe9Xbm5ja2lALZKn+A/4Vkz6PFNrw1H7SQBIsuPIJkBVdu0P
    2Q9SuOTnnmgCQ67ZnS4tQjj1CS3feSVDAxqhIZmBIwBjp19qsahfW+n2qXDLeTRsN2YiTtXGdxJI
    A7cdT2BrLTRrqOwtLYalC4glkldZLFykjM25cqHH3ST3I6ccVd1K0m1G1mt2vk8uVzlZLPeoQgcD
    kHcCCQ2e/Q4FAEltqlpc6gtoovFMil4pHLBZQOuOc9+4Ge2a0vsy/wB+X/v43+NY9rpog1WG7lvG
    lW3iMUf7giRlIHDv/EB24HXvWx9qi9W/74b/AAoAPsy/35f+/jf40fZl/vy/9/G/xo+1Rerf98N/
    hR9qi9W/74b/AAoA5JkCfE24ALH/AIl8f3iT/E9dBXPs6yfEy4K5x/Z8fUEfxPXQUmBzPj7/AJFa
    f/ron8xViy0i2ke5mvTuE5RkEcrIyrsCspI7HHI6cCpfFGmvq2jSWkcio7uCGbpxg15/q1/rGnah
    JZvqszmILyvA5HpWSU/aPlV9Dvc8P9TiqtRRtJ9G91Hsn2PTZ7DTLhcGJk+bcDHM6FflCYBHQFVA
    IHHFWbZ7GwaQ28ccXmbQwD8YVQoAHYAAcCvFnv8AUJPvX9wf+Bn/ABqIyzv/AKyZ3/3mb/GteSv/
    AC/icX1nLVvX+6D/AFse5Sa5aRDMk8Cf70oFU5fGeiwcPqFtn/Zk3fyFeS2un3cgt2hsYpRcuUhL
    KTvYdRyalg1O6hYiKz09SASc2w7depo9nXfRD+uZZHeU38rf5npUnxE0JDhbhpP9xGP9KyNf8c6V
    q2i3NlCbhHlGAzRHA5rlF8U6ohARbRT2AtgDV2TWvEMMLySLaBYwCwEakjJx0B45Pel7Gv3X9fMa
    zHLOkZP5/wD2pvJ4m8KL5jbbpfMBG3MgCZYMwUZ+XLAE4xnFSr4g8JTyyyGeSN5CSMySr5ZY7mKY
    +4SwySMZNcgfFmrMBn7MQembcUxvEuovnfFZNjrm1U0/Y1+6/r5k/wBpZW/sy+//AO1O5g1Hwn5s
    bx3cIZSGbdcuBKwbcGcH75DEkFs8810EWv2M/wDqbm3f/dlBryIahd3aSk2mnERR+Y2bYD5cgcfi
    RUF1a3Jt0uJLK3jjcBgY1wcHocBsjPvS9nXXRD+uZZLaU18r/wCR7WNSjIyNpHs3/wBaj+04/wDZ
    /wC+v/rV4Wk95FzFczRgf3Wbj9a0hqWvWt41mt9M0yuY9g+YE+1HLWW8fxQKtl8vhr/fGS/JM9Hu
    bCC912a9uHHlPCiII5GSRHUk7gw5HBxx6mrDWOlmAQiIoqqiqUmZSm0sQVI6Nl25HJzzXncuv+I7
    OPfLLCyAhdwVGGTzjI+lNHivxAyF1WEoHCFvKGAx6Dr7Gp5pLeL/AK9DVUqc9KdWDfrb/wBKsem2
    aafYOr28Sqyx+UCXJ+XcWPXuSxJPU96uf2nH/s/99f8A1q8h/wCE01rjmLnp+56/rSf8JrrXODFx
    1/c//Xo9ou4/qlbfl09Vb77nr/8Aacf+z/31/wDWo/tOP/Z/76/+tXkA8aa2ehg/79f/AF6cPGet
    etv/AN+xRzN7J/cxOgo/FUgv+34/5nqWqXkdzpN3CNuZIXUfN7H2rh7R9/gCD1VlU/hKKzbHxRrt
    9fQW0YtneVwgUqAGz2z2rWTT7jS/CMttdhFkFwGwjZABde9R73tE2mdH7tYSUVOLfMno0+jvt6o9
    MrP17/kXtS/69Zf/AEA1oVn69/yL2pf9esv/AKAa1l8LOSh/Fj6o42f/AJFWw/7df/QkroJHbzX+
    ZvvHvWBP/wAirYf9uv8A6ElaEqat5z4n0zG49YZfX/eqY/Ch1/4svVlK+vtQt9ZGZ5I9OHkqTGsb
    fMzEYYE7gCdoBA9fSp7WbU47FhpjMN2p3XnbPLMhUFiNokIB56+1RzWd291DPM2im4UkRO8Em76L
    81WtEhgl0S6TWP7OdP7Qnz5wwhbeem41SMmF3rN9GPtdjqnn24s1uGWS3UAb8CMZHO4klsdsDPBz
    WppF/c3enXUN5dCC8ikeMO6pvTCqcsBlSRuHTIxjvmrYFu5mjU6eTLGHlUY+dMYBI7jGBmm21hai
    0j+ywaebdUdUKICoVvvAdsHHP0qhGEdT1eHQm1D7esqozTKrQIrNCDgM4yDt4JO0bvmA7V2NZEsN
    jdJaPKNNlRGAtmYAgEcAJ+Xb0rR/0n1h/I0ATUVD/pPrD+Ro/wBJ9YfyNABd/wDHpL/umsC51m+j
    8TiBHH2NbiO2YbBt3Mm7BP3t3PGBtx1Oc1tXP2j7NLuMWNpzgGoHtoG1RJZEsTfhPlYr+82+3fHW
    gDHTVNUudDtJEuohqEksyCOKEHzmV2UDk/KgA+Y9enOeupq1/cW1ravbSQeYbyCG4GN3DOqsBzwf
    mHXtUTaBpj20UTafpZhjZvLXyRtVmPzY9yQM/SrNxpkE0LC5tbFo/MExDx8bwMBvqABzQBQs9du7
    nxjNpstrLDbJAzJviI3lXA3bumCDwB+PoOhqkuHvWKtaNdRptbH31U84PcCp/wDSfWH8jQBNRUP+
    k+sP5Gj/AEn1h/I0AcpL/wAlOuP+wfH/AOhPW9XPtv8A+FmXHmbc/wBnx/d/3nroKTArXf3R/vf0
    Feb+JNOu7nxDdyQwM6HaNwI6ha9Iu/uj/e/oK5u30+0vNa1Zrq1hmZXjCmRA2BspwlyyuZ16KrQ5
    GcR/Y1//AM+zfmP8aP7Gv/8An2b8x/jXof8AYel/9A60/wC/QqtqOm6bY6ZdXS6ZZu0ELyBTEMEg
    E4/StfrD7HD/AGVT7s5yyk1Czt7SFLSTbGf3vK/89N3y89duR+NXYLhobcIbG4O1sqpVTsyG3fMW
    5ySDjA/HFXL6Tw/p15b2txp0BlmVXwkCnaCcA+p5z0z0qroi299Nbx3OiW/7+3+07xDGBGCxAHBO
    V44PX1AqfbPsbLAxX2mZ07ahJdW119lllmguHlzKwOVJBVc5zxg/TNNgtbjT4bgWK3oknCjcdqFc
    MCRkNzx9K0YZ9P8AtlytzpFisETTqrCHaT5Zx95sKxPoOnepIb/QLlC8OkI0aqPMl8hNsRLFADzk
    /MOwNP2z7E/UI3vzMZDcmDzPLsLhFMhkRAq/IxYncDu44OMAcetV47i9FvaxyW90zK2bo7lPnDBH
    PPzdR19K1tDttL1bSYLr+zbUsyLvcQqFZ9oLbfYHitD+w9L/AOgdaf8AfoUvbeRf1JfzM5q8mubm
    zkhWykXfCUVQqgR/d4zuOR8p9PpSK0v2a2je0uH8tIlKhUXYU/iDBstz2OK6ddE0sMD/AGda5z/z
    yFZ+j6XY3NrPLcWdvLIbqYFnjBP3zR7byF9Rje/MzNuLq4keEJa3BjyTOMKom+Tbyu4559Sao38V
    3e6glzHBcW5WQkbNp2rnO4Dd9719fWuv/sPS/wDoHWn/AH6FYmrnT9N1OK1j0zTW3wiQRvF+8mYv
    t2JjjP1oVZ9glgYy3kylIJWt/I+y3JQyI8hQJH9oxnhlU4XgjGM9Ksy3c7mHEF0NrxySuqqvnbWY
    7SN54ww5JPTpUs9xo0S3IXSIpDBKYndIE2xkuUQtk5OSO2fwqKzuLCdtMgfQIvtFyitKhijBClCw
    decbchuM5wOlHtX2D6lH+ZkXn3SRSmK3ulkePbGAVAtzsK/Id3cnJxjp3qG7Fzc6dLD9luPMfZ0I
    UFgF3MxDfPkg8EcZzmtCYWMOvvZHSbD7MkkUZkMBBy65zv8AujHoeT2psWo+H7glYNGWV13F1SGM
    7FUAlic4xg9iT7Ue2fYTwEWrczOY/sa//wCfZvzH+NH9jX//AD7N+Y/xrr9Fj0nVVuNun2j+VM67
    1gAULuIQeudoBrU/sPS/+gdaf9+hVfWH2Mv7Kp92cb4e0y7t/EWnyywFI0nUsxI45+tdf4j/AOQT
    P/10T/0MVYtdI06G7hkisbZHVwVZYwCDmq/iP/kEz/8AXRP/AEMVlObm02dmHw8aEXGLO3rP17/k
    XtS/69Zf/QDWhWfr3/Ival/16y/+gGpl8LOuh/Fj6o42f/kVbD/t1/8AQkroJUbzX+U/ePasCf8A
    5FWw/wC3X/0JKvy6FpZmcmwiJ3Hnc/r/AL1TH4UOv/Fl6so3tjqH/CRJdQRzOm2JI/lQxIAx83dn
    5lJBGNvUgZqaLTftmmtL9nupXt9TumX7OsTMuWI5WQFSOfqKrXtlp9nc28f9hLLHPIsYkWcjDHP8
    JbJwASfYVY07UrPw/pZj+yqyzalcxRgzrEi4YnlnOO1UjJjrbRdQTUBLeaYspBaSWNNghdTHjCE/
    Nu3fwt8uPQ4rU0m1uLbTbm3l0uSWG4kllCSGNWxhAFdR8oJO7G3jA55JqKXxPY29xNDPZSq0S/MB
    ICwbAONuchecb/uk960rK8hvLG4mFlKJrdzHJArhm3AA4BBweGHeqEc9No1xJp1xHHpU/mXErG3d
    liDINqjbIBwikg8x4OAD1JNdzXPWut2lwtrmzlDXF0bUlHDojBS2d4OCMDHHfI7Gtr7JD/c/U0AT
    0VB9kh/ufqaPskP9z9TQAt3/AMekv+6a5u70q7fxctytu5j8+OUSDbs2BNpyfvhs5wo+UjBIzmt+
    5tYVtpSE5CnuazJtXs4deTSzbOXYhd28ZyRnIXO4r6sBgHjtQBlQabcR+HNIhGlTrJa6mJRF8mYk
    81m3fexjafUnmrvi3TNR17SLiG1LQmFiFhdQ4ueFKt94Ywc9e46dKG8Q2h0+G6j0+5bzEmleNmCt
    HHE212OT1BI4HPPtVzVtU07SNNW8mR3DrujiQ/Ow4ycZ6AHJPagClY6HdQeLDcqf9Fi8x2d4grSv
    JgkBgxLKDnggY4AzjNdPWPHeRNrH2CSxmj3KzRSFwQ4XgkgHKj0J61o/ZIf7n6mgCeioPskP9z9T
    R9kh/ufqaAOVl/5Kdcf9g+P/ANCet6ueaNY/iZcBBgf2fH3/ANp66GkwK1390f739BXPWz3CavqY
    tNPubsmSPeY2QBfk4HJFdDd/dH+9/QVytxNd21xqstrK6gTKvlxTCJ5JDEPLAJ+90b5e+R6UluM1
    fO1T/oA3v/fyL/4qo7hdQuraW3m8P3rRSoUcebGMgjB/iqi+t6xBPKwuh9pbKTRyPxAAyrvdMERK
    ASQwzuAyRXRWOq2t1oLx3NxLD5cUjGVJ2ctHGQGkWTGSvI575p2QXMFdMulKH+wtVYoMZa8UlwDk
    Kx3/ADAHoD0yakhsrq3a3aHw9fobePyk2zp9z+63zfMO/Pemt9u0ySylvr+5cSIriza8dZstIflG
    BiQhSoIzxg9iK72iwrnnx0eVnkdvDuosZGZ/mulIRmO4sg3/ACnIByPSiPR5Y4p0/wCEd1FxcEGV
    pLlGZyGLgkl8/eJNeg0UWC5w1rbXlkMW3h29QbFQgTR4IUYB+91xxnrwKsedqn/QBvf+/kX/AMVX
    Y0UWQ7nHibU9w/4kN51/56Rf/FVQ0eS8W0lFrpV3cx/aJSZFeMDduOQMkHg8V3x6GuG0S+e1k0qF
    bvy1nu70GHI/ekbiD6nB9PWiwXLPnap/0Ab3/v5F/wDFVBNb3lw8jzeHbxmki8lsyx/dzuH8XXPO
    etVrbVJpJrKO41adLKeKOS/m8/b5E5SQsm//AJZ/MqDbxjOO9T6LrN49xaT6heyi5Mm2e3Y4C24t
    95kMfb5xjd+FFkFzPu/D93czRlNG1GGLf5k6LMmZzu3jcd/qT1B6nGKuf2bOJIZF8O36yQokcbrc
    ICqpkAZ39MEg+vetXUJkfWDdwaleQWkFqbq5dZCY1QqQgCEEc4LdP4av+F5vtGnySLei5iMn7tTO
    JniGB8rODy3fHbOO1FhXObm0ye5u5Libw7fu0mN6NcJ5bEDAJTfgkDvimQ6RNDK8g8P6k8jxmItL
    dK52EbdvL9MDHtXoNFFgucJa2NzYlDbeHL2MoGAImj5BOSD83PPIz0q152qf9AG9/wC/kX/xVdjR
    RZDuclby6ibmISaLdRIXGXeSPCjPU4bNVfEf/IJn/wCuif8AoYrsrj/Ut+H8643xH/yCZ/8Aron/
    AKGKTA7G6uY7O3eaYkIvoCSSeAAB1JPGKwtV1sTaNfw3Fhe2ZktpVja4RdrNsPy5Vjz9cVo+IY3l
    0K6SO5ntnKjE0AJZORzxzj1xzjOK5CzSOx0i7STxAmsXDafJCEgleUR/JkscuwA46kD+lEvhZpQ/
    ix9UE/8AyKth/wBuv/oSVoy6k3nP/wAS3VD8x5Fo3rWbP/yKth/26/8AoSVvSj96/wDvGpj8KHX/
    AIsvVmS8/mX8V02nauWiRkRPshwC2Mt9cDFWtBSW+0e58mW7tHN/cN/qATgueGVgaytTv7mDW0ji
    m2RIYAUyBu3uQflIy/HoRt6nNWUkvItNY2d6lsv9p3XmA3CwmQZbADMrDrzjFUjJmtbeGrWzkUQv
    deRGGMcLxBgrlPLLEkZYbT908VYsdHh020EFnJdW6kOZPJhVA7tj58AYBG3gDjmsRtU1qS4jWzln
    Y3ERkTzTFtjg8sMGcfeWTPBJ+XJq5a6rd3Hhu/QXht7omUWU126BmRQuXLLlSAzEZAI6VQi2uikN
    byNd3Zmjuxdyv5CgSsE2YxjCjbxx35rc+0j/AJ5Tf98GszwzdPcWMyyzSzSRTFHd5VlBO1T8rqqg
    jBHbrkdq2aAIftI/55Tf98Gj7SP+eU3/AHwamooAqXNwGtpR5coyp6oazZtIim1f7aXugplWdoRH
    wZFXaGzjIGAOOla93/x6S/7prj/EOu6jYavdm1uPlg+RISAcnyt/3Mbm5/jBAHTBxmgC8PDaiwjt
    jeXhZRNG8nkLl45W3OuMYHIGCORVnUNCstU06azvYpZ0b/VNJArNAMKMISP9nP41g3ur6lbw3htb
    +e6trY/upI3iMkkpQMqknAZc7gQvzdK09d1+eBLOK3kQcO12yyrGyMio2wEgjcd/TqR6daAL9hYS
    WGpXFyLm4kimJPlNbqNo/hUMBnCjgCtX7SP+eU3/AHwa5+y1SWbxLAsV601vdRO7QttJiI6KVAym
    Bjkk5PYV01AEP2kf88pv++DR9pH/ADym/wC+DU1FAHGM+/4mXB2sP+JfHwwx/E9dBWDL/wAlOuP+
    wfH/AOhPW9SYFa7+6P8Ae/oKr2IjsZbiaNXMlw4dySCMgYGOOOKsXf3R/vf0FeYeKppV8SXSrNKq
    gJgK5A+77UQi5SsjOtWjRhzyPVP7Rbk7Tk9eBz+lA1JgMBTjp0H+FeN2iT3Mj5upkjjUySP5jHao
    wM4zz1HHvU32O5mDPZ3M80Q4UvIUZyBkhV3EnHfFa+xl3ORZjTauov8AD/M9eOpMSCVJI6cDj9KX
    +05PRv0/wryY6RqCJctLdbPIUkn7TlSQwBXIbAYZ6VM+kOsN1P8AbrzyInwpUMxKlQwY/MMZBFL2
    L7lfXofyv8P8z1P+05PRv0/wo/tOT0b9P8K8hTTtRfP75lULv3PdbV28c5J6cjn3psdrc+bOtzcz
    wJbgGVt7MRk4GBnnORT9jLuL+0Ifyv8Ar5nsH9pyejfp/hR/acno36f4V5B9ivJVMlrPcTRE/JmQ
    q7gcEhN2cA1ci0S9RZTeXE8RG1Y8T8MWJHXPOMcgc0exfcax8H9l/wBfM9T/ALTf0b9P8KqaeY9M
    tvIt1kK72kyxBOWOT29TXmd5pdzFJJ5F1KYUZlMklyAoK4/i3Y5J6Uh0XViT5ZuGXcFBMpBOcDOM
    9MnGaPYvuDx8L25X/XzPVv7ROCNhwTkjA5/Sl/tJs52nOMZwP8K8kk029is5riS7IWMqBi5yHzuz
    tIOCQV6Dmn2unyXCwK17cLLKjS7FYsdgOBgZGSTk9eADR7GXcX1+F7cr/D/M9Y/tJ/7rfp/hSLqL
    KMKpA9gP8K8pfSL4tCLa5ml81WfDSlGQBipLKTwOOvvioRpmqkS7RcFon2OglO4Hjtn3H50exfcP
    r8P5X/XzPXv7Tk9G/T/Cj+05PRv0/wAK8mn0q9igtXjuJJXmO1hHcbgpLEDkH259KzWlnVipnmyD
    g/vW/wAaFRk+opZjTjvF/wBfM9r/ALUf0b9P8KT+1X/2v0/wry3wjJJJ4q09ZJZXXzOjOSOh7V3S
    3epTQ6sba4jVre4QCSYFhFF5aM5Cj7x5YgHuazqRdPdnTh68a8eaKNdtTZxhgxHpx/hWB4iOdHmP
    rJH/AOhiszVdW1n+yrYXrtA1zbXjlVGwui7PLYrk7WwxyM96v61/yL3/AH6/9CWp6m53EzmKGRwp
    cqpYKO+O1clBrMmq6DqbPLa/NYSSeRHbSRvHlejMxwcZxwBXT386W9jLJI5RAuC4ZV254zkkDjOa
    4TSnVrDUxmFCdLlK+VJGTcDA/eSbXbLe+P4mol8LNKH8WPqh8/8AyKth/wBuv/oSVoS2uoec/wDx
    NYx8x4+wj1/66VnT/wDIq2H/AG6/+hJW5LJH5r/vE+8f4h61MfhQ6/8AFl6sypkkS8gjn1m0F02f
    JD2K7/fb+8z+VXtAEcOg3ranc2phS/n8x5ogEJ8w84JwOazNT05rzUInt5/KjkaJrlt6FWETblGD
    znr0IHrUsGnXGoWImtfNcW+qXTtHDP5TtksAQ3TjNUjJnUie1a+mthd2ZuimZY9o3lR/eGc457+t
    SwosttFJBNbtBs/dskYK7COxzjGMVz9jo2pRXkX22KGcRzyXckqsAszPCUKBT05OeeMVpaFDeWOg
    6bZXFnGPKtTHMvmg7WUAKB2IPP0qhE6XtlZ29ssd/YwwznEAUKqvn+7g4P4Ve2T/APPZP+/f/wBe
    uQHhm8n8OWNptazuzbtZzskkbIkROTkEHPTjbg+4rtNw9RQBFsn/AOeyf9+//r0bJ/8Ansn/AH7/
    APr1LuHqKNw9RQBVuUmFtLmVSNp42f8A16gkmtU1NY5LuzW+8vKhlHmbPbnOOtW7oj7JLyPumuV1
    7w5fapqV2IQixXPzCRpP3a/utnzJ1L56N2GB2oA1o77SUtYZI77TVt/N2xMqqF8z2561cuookt2k
    vJLUQqwctLGNoPQHJPX3rmrvQNR1D7bcqjWd1ej7ONssbeXEYwrFsggglQfl59xzVzxDoF3rWiPa
    pKYXt8rAqsrJMNq4ZgwOCDnHp1oA21REvnVZrYXboGYCMb2UcAnnOO1T7J/+eyf9+/8A69YdloM9
    l4ul1L7ZJNDLbsr+YEzuLghcgA7QBxzxXQ7h6igCLZP/AM9k/wC/f/16Nk//AD2T/v3/APXqXcPU
    Ubh6igDjWDD4mXG9gx/s+PkDH8T10FYEvPxOuP8AsHx/+hPW/SYFa7+6P97+grzzXtM+2+ILyRZJ
    cjYCsdu8mPl7kV6Hd/dH+9/QVh6d/wAhjV/+ukX/AKBRGTi7ompSjVjyy2OPttJltpCytcMGG10a
    xl2uvoatJbzRDEMLRgEmPFjMfLLDaxGT3AHXPtiu4zWPPcIdXlS+vpLURsn2WJZ/KE4IBP8Av/Nl
    ce3Tnm/bSZzrA0VsjnzBctHcRuJGjuJHkkU2MuCWwfrwVBH9adLbmW1jhe3klwq7mksps7wNuRgj
    +EKPwrQtte1G9ubS3gktA9yAzP5TMICUdjEw3ffG0Z5HXpTNM1zUbySMrJbhry7VVhlBLQxmHcWB
    zyMqccDnPNHtZD+p0uxTggZEkSaB5EMJhRPsMoCgkHBxgkZBPrk/WoPsdw11NNJ50gmwJI2sZdrA
    dBxzxgd81p/8JVcPfywKbaKFmBWeX/l3XcR+9UNkHgDkr1pr65e2kjk3EVwftUyhMEeWmPlc88pg
    7h7Dr3o9rIPqdLsU0iuIVAgR4imRGy2MxMYJyQM54J9c0Sx3Up6SqN6Sf8eUx+ZSSOSSe/8A+qtI
    eIb7fcurWssFoqsXSM4uQZCm5Duwo/766GumbhiM9DS9rIf1OkcMLe4aF4JEeSKR2dkaxmALMQc5
    GDwRUvnXbuGEjSNDJgMtpKyqVIyvB2nkdevvXaA8isvQP+PCb/r6m/8AQzR7WQfU6X9M5Y2c7WP2
    RxK0QyRmxlyDknd9RuPtzS/2crQQLNBNM8KmP95ZzbSucjpg5BJ/Ou7zWD4juZIr7To/totYZBKZ
    C10YA2NmPmAOTycCj2shfUqPYyP9MabzZPNaQqyFvsUykoTnbwRgZ54596dE99CrBDKGOdrfYZvl
    yQ3TODyOpBPvWlf69Pa+esU1qscTIqTyhirhnVT3AygbLc85HTnFe58VXNv5O0W8gEpR2yEWdfM2
    K8WWye5IG7t60e1kP6pS/plRY5VRhGk8BELRRiKzmwNzZJOcn1x74rL/ALAb+9c/+AUn+Fb7+I9Q
    gtIWna03SwRXBkCEbFfd8qxlsyNlegIPPTikXxLdxxzHEWY5GCwyBvMmBdwWXnICBRkYP4U1VmiZ
    YGjLdFDRbH+yNYt76RbyVYGLFEspMngjjNW7nV7uR5jZ2uu2a3H+vRLVHEh2hc/MCRwAOPStvR76
    6uWkivDE0iwwzB4kKDEgJ24JPTb1z3rTzUTlz/Eb0aMKMeWBxL3Wo6nvhuNP1CaQW5tbEfZxGsYY
    AMW9ztHfAxxiui1xSmgsrDBUxAj33LWvEf30f+8P51l+I/8AkEz/APXRP/QxUqy0RodheQJc2c0M
    iI6uhGHTcvtkd64DRNNkstM1dlkjaL+z5lcCU5RsZVRGQCmBnOf9nGOa9CnYpBIyjJCnAzjJ9M1w
    mlXLT6Pq4ksgs32O48+d0fzARwqln5bIz04ypPenL4WaUP4sfVDZ/wDkVbD/ALdf/Qkq7qNhp1rb
    3dwNIsZWiV5NgtowWxk4yRVKf/kVbD/t1/8AQkq5fTXN1HcwNpV8qyhkLJLACAeDjL1MfhQ6/wDF
    l6szXl05ZI9uh6eYtlu0rGCMFfOOE2jb82D1yR+NaGnalZaBpEqG2g3S6lcRQoV2oMMSclVOAAOw
    NURYNmHOmamRGkaMpuLfEvl8pv8An5IPpj3rU0Gy/tPTZpJI7y2ni1C5ZHidA8ZLEEdSOnHerRky
    6NcSW8MVvpkM0bSvbwusi5eRU3njGAuAeck+1WLHV7KfRrjULuCC3itmYSuPmTC9SCQDjnuB3+pj
    i8NWdu4+zxXsUaAmOJJQFifbt3qc53beOSR7VZs9Ljs23BbyVmLtKZJFPnMwUZcDAJAUAccUxGWv
    ieCbSl1CHTYGgE7wyDzlLAqxUAbQQWIGcEgc8tXTfZoP+eMf/fIrGk8P2z27W6R3kUEjyNLFHIoW
    UOxZlYenOOMHHGa2POf/AJ95fzX/ABoAX7NB/wA8Y/8AvkUfZoP+eMf/AHyKTzn/AOfeX81/xo85
    /wDn3l/Nf8aAI7q3hFrKRFGCFPIUVhap4ktdK1Ka3k09HjhXcxUjefk35C4xjAxywOe2Oa3LmZza
    yjyJB8p5JX/Gs690C01C7kmuLe6aOU7pIN6iN327Ax5znbgcHHHSgDNu/FMdh50d3ptpFNbqXlLT
    gR7QobCsVGXIbhcDoeeK0dV1mx0yOy3QQiS85jEo2qqjBYsQpxjI7dfbJCf8I9btbvDOL2cTSB52
    kdCZgBtCt7Y9MH3p93okN5ncL5Gy2Cki/KjBQ0YzkBTtHH5GgAi1BH1wafJYQqsiGSKRWDEqP4iM
    YAPbBJ9QK1vs0H/PGP8A75FZltpENrfR3Kx3jCFSsETyKUhBAB2855x3J9sVpec//PvL+a/40AL9
    mg/54x/98ij7NB/zxj/75FJ5z/8APvL+a/40ec//AD7y/mv+NAHJMix/E24CKFH9nx8AY/ieugrn
    2Yt8TbglGX/iXx8HH9566CkwK1390f739BXPQRTyapqbRahZWEazRoWnj3GRinAyWH5V0N390f73
    9BXMpY3F3q+qPBam5ChoSgK5VniQK3zEDA2nPfngUluM2n0LWI13PrFkoyBk2mOScD+P1pT4e1k4
    zqlmcdM2Z/8AiqfqNldy6BbWrae1xNaXFqUKuh3CMozONxGOjD1/Oukp2Ecx/wAI9rI6arZ+v/Hm
    f/i6P+Ee1rOf7Vs8/wDXmf8A4uunoosBy/8Awjus8/8AE0suev8AoXX/AMepf+Ee1n/oKWfp/wAe
    Z/8Aiq6eiiwHMf8ACPa0Bj+1bPH/AF5n/wCLo/4R/Wv+gtaf+AZ/+Lrp6KLAcwdA1pef7WtOP+nM
    /wDxdULXTrkSyQ2uqWVoj3EqxQyw7nkIPzH7wyc88Diu0f7jfSuJGl3V3dXxhtvNW4uUVZty4gMc
    zO2cnIyCANoOcc4osBcl0nU4JYo5tc0+OSU4jVrbBc+gG/mpT4e1lvvapZH62X/2VO1y0vNUiiVN
    MKTs4/eeZGQArnhz12kfMNvOTjjv0tFgOUm8L6rcxiObUrJ0DBtpszjIIIP3/UA1J/wj2snH/E0s
    uOn+hdP/AB6unoosBzB8PaycZ1SyOP8Apy/+yo/4R7Ws5/tWzz6/Yz/8XXT0UWA5j/hH9a/6Ctn/
    AOAZ/wDi6P8AhH9a/wCgtaf+AZ/+Lrp6KLAc1HomrQSxyzanbPGjAsq2u0kZ6A7jis3xH/yCZ/8A
    ron/AKGK7K4/1Lfh/OuN8R/8gmf/AK6J/wChik9xnS+IN39kPttRdr5sXmQmIS7k8xd/y9ztyfwr
    lbQyHTL7/iSiw/4llz57/YhBl8/IAR1+XPFd5Wfr3/Ival/16y/+gGiXws0ofxY+qONn/wCRVsP+
    3X/0JK1NZkMWm6hIJTCUikYSLjKnBwRmsSbULM+GbGMXduZF+zZXzVyMMucjPars1zbB5HPiZwAS
    eGtzx/3xWcZLlWptWo1Pay917voQxX+6+8P/AOlki5tXLR7uJDsUhj3Jzn9aeby6tdKKQzR28Euq
    XInmkkaMKoLEDevK5OBx16VG2o2SyxRnxRNvmGUwsBB+p8vA/HFX/Dus6dpmj3j3mtRALeTsWZkL
    OC5w21Rzn2FWpR7mTo1f5X9xSuNb1P8AfXNrJcR6gzuTaSkkQweWCrNH0GGI+bH59K1E1mX/AIRO
    5S2kc3iJIIJUdphMF2lnR25IG/HPcHHStA+J9HW4kgOuQb44/MblcY9jjBPsOadB4j0i4tRcR65b
    +WQT8zop4/2SM/pT5o9xewq/yv7jn7i/1ZYC2jyyXWlx6hEqT/acvIpaLK7mBLIWZwTnI6dBXd1g
    J4q0WS3inXXIfLlcIudoOSccjGQPc8Va/tnTf+g5af8Af6Kjmj3D2FX+V/catFZX9s6b/wBBy0/7
    /RUf2zpv/QctP+/0VHNHuHsKv8r+4v3f/HpL/umuN8Q6hqcGuXS2M83nIMQQKSWYeVncI/usm7qx
    5BBHTFb9xrGmm3kA1q0b5Tx50fNMbxJpC3i2p1y381l3jDJtx/vYxn2zmjmj3D2FX+V/cczd3l79
    nuX0y+nurVG2WgF2weSZowRh+TIAwYFOnPtXfQeZ9nj87/WbBu+uOawR4v0M28c41yPy5JPLXgZz
    7jGQPc8U+98VaLp6objXIcOSB5e2T/0EHFHNHuHsKv8AK/uN+isKLxNo81w8Ca5B5iKGOWUDB6YJ
    GD17VY/tnTf+g5af9/oqOaPcPYVf5X9xq0Vlf2zpv/QctP8Av9FR/bOm/wDQctP+/wBFRzR7h7Cr
    /K/uMKX/AJKdcf8AYPj/APQnrfrlTqVkPiJPOdQt3hNjGolMq7c7n4yOM/41u/2zpn/QSsv+/wCv
    +NLmj3D2FX+V/cSXf3R/vf0FV45PJ3eWqKWOWIUZJ9z3qO61jTWUbdQsz83adfQe9Vv7W0//AJ/7
    T/v8v+NLmXcfsKn8r+40ftMn+z/3yKPtMn+z/wB8is7+1tP/AOf+0/7/AC/40f2tp/8Az/2n/f5f
    8aXMu4/YVP5X9xo/aZP9n/vkUfaZP9n/AL5FZ39raf8A8/8Aaf8Af5f8aP7W0/8A5/7T/v8AL/jR
    zLuHsKn8r+40ftMn+z/3yKPtMn+z/wB8is7+1tP/AOf+0/7/AC/40f2tp/8Az/2n/f5f8aOZdw9h
    U/lf3Gj9pk/2f++RR9pk/wBn/vkVnf2tp/8Az/2n/f5f8aP7W0//AJ/7T/v8v+NHMu4ewqfyv7jQ
    +0yf7P8A3yKPtLjOAgzycKKz/wC1tP8A+f8AtP8Av8v+NH9raf8A8/8Aaf8Af5f8aOZdw9hU/lf3
    Gj9pk/2f++RR9pk/2f8AvkVnf2tp/wDz/wBp/wB/l/xo/tbT/wDn/tP+/wAv+NHMu4ewqfyv7jR+
    0yf7P/fIo+0yf7P/AHyKzv7W0/8A5/7T/v8AL/jR/a2n/wDP/af9/l/xo5l3D2FT+V/caP2mT/Z/
    75FH2mT/AGf++RWd/a2n/wDP/af9/l/xo/tbT/8An/tP+/y/40cy7h7Cp/K/uNH7TJ/s/wDfIo+0
    yf7P/fIrO/tbT/8An/tP+/y/40f2tp//AD/2n/f5f8aOZdw9hU/lf3Gj9qk/2f8AvkVj+ITnRpT/
    ALcf/oYqf+1tP/5/7T/v8v8AjWfrupWMukSLHe2zsXThZVJ++PenzLuL2FT+V/ceg1n69/yL2pf9
    esv/AKAaP7e0n/oKWP8A4EJ/jVLW9b0uXQdQSPUrNna2kCqs6kk7TwBmnKUbPU0oUantY+6910P/
    2Q==
    –_004_6E5E1A75787CA14E9AB482FF2FFE6A715A71D5E9USDEN3EXMB002An_–
    #9142
    I am having an issue where many (no particular pattern except for two reaches this issue is mainly concentrated in) of by reach lengths (not for channel) are negative numbers. Obviously, this causes an issue after I import into hecras from hecgeoras in arcgis. I tried making sure everything had been digitized in the right direction, XS cutlines, etc. Everything seems fine, just miscalculating RR left and right reach lengths!
    Any suggestions?
    #9143
    Vince Moody
    Karl,
    Did you follow the cross-section attributing procedure outlined in the HEC-GeoRAS User’s Manual? My guess is that you added some cross sections or moved cross sections after generating river stations/reach lengths. Try re-attributing cross sections properties in GIS and export again to HEC-RAS.
    #9144
    This usually happens if the flowpaths are digitized in the wrong direction.
    #9145
    If you go back into GIS and go to the XSCutLines attribute table you can right click on LLength and RLength and calculate geometry length. Then export all your data again.
    #9146
    Thank you..it works
    Thanks a lot.
