Welcome to the RAS Solution Forums HEC-RAS Help HEC RAS defining a bridge geometry
  • #5745
    cuba28
    After running the model, I’ve an error message concerning a bridge geometry :
    “Deck width + distance is >= the length between bounding cross sections. HEC RAS requires a positive distance from the end of the bridge to the next cross section downstream.
    Bridge doesn’t contain an opening at downstream and upstream.”
    Could any one explain me what is the deck width, for low chord and high cord and how to do to fix the error ?
    Thanks a lot,
    Hearily
    #9208
    Bobsteele
    Return-Path:
    Received: from na01-by2-obe.outbound.protection.outlook.com (mail-by2on0146.outbound.protection.outlook.com [207.46.100.146])
    by mwork.nabble.com (Postfix) with ESMTP id 6AA4117C82D2
    for ; Wed, 18 Mar 2015 13:19:43 -0700 (PDT)
    Received: from SN2PR0601MB0927.namprd06.prod.outlook.com (25.160.17.27) by
    SN2PR0601MB0926.namprd06.prod.outlook.com (25.160.17.26) with Microsoft SMTP
    Server (TLS) id 15.1.112.19; Wed, 18 Mar 2015 20:19:23 +0000
    Received: from SN2PR0601MB0926.namprd06.prod.outlook.com (25.160.17.26) by
    SN2PR0601MB0927.namprd06.prod.outlook.com (25.160.17.27) with Microsoft SMTP
    Server (TLS) id 15.1.118.21; Wed, 18 Mar 2015 20:19:21 +0000
    Received: from SN2PR0601MB0926.namprd06.prod.outlook.com ([25.160.17.26]) by
    SN2PR0601MB0926.namprd06.prod.outlook.com ([25.160.17.26]) with mapi id
    15.01.0112.000; Wed, 18 Mar 2015 20:19:21 +0000
    To: “cuba28 [via HEC-RAS Help]”
    Subject: RE: HEC RAS defining a bridge geometry
    Thread-Topic: HEC RAS defining a bridge geometry
    Thread-Index: AQHQYbKlqzZNZ97n7U2bL0S1fU1y250irhzQ
    Date: Wed, 18 Mar 2015 20:19:20 +0000
    Message-ID:
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach: yes
    X-MS-TNEF-Correlator:
    x-originating-ip: [65.188.37.128]
    authentication-results: n5.nabble.com; dkim=none (message not signed)
    header.d=none;
    x-microsoft-antispam:
    UriScan:;BCL:0;PCL:0;RULEID:;SRVR:SN2PR0601MB0927;UriScan:;BCL:0;PCL:0;RULEID:;SRVR:SN2PR0601MB0926;
    x-forefront-antispam-report: BMV:1;SFV:NSPM;SFS:(10019020)(377454003)(38414003)(110136001)(33656002)(2900100001)(74316001)(107886001)(14971765001)(92566002)(86362001)(16236675004)(2950100001)(19625215002)(76576001)(66066001)(62966003)(106116001)(46102003)(77156002)(450100001)(102836002)(15975445007)(19580405001)(19617315012)(87936001)(19627595001)(40100003)(76176999)(18206015028)(2656002)(99936001)(99286002)(54356999)(19300405004)(50986999)(19580395003)(122556002)(217873001);DIR:OUT;SFP:1102;SCL:1;SRVR:SN2PR0601MB0927;H:SN2PR0601MB0926.namprd06.prod.outlook.com;FPR:;SPF:None;MLV:sfv;LANG:en;
    x-microsoft-antispam-prvs:
    x-exchange-antispam-report-test: UriScan:;
    x-exchange-antispam-report-cfa-test: BCL:0;PCL:0;RULEID:(601004)(5002010)(5005006);SRVR:SN2PR0601MB0927;BCL:0;PCL:0;RULEID:;SRVR:SN2PR0601MB0927;
    x-forefront-prvs: 051900244E
    Content-Type: multipart/related;
    boundary=”_005_SN2PR0601MB0926336071E348A5E0E902F4D4000SN2PR0601MB0926_”;
    type=”multipart/alternative”
    MIME-Version: 1.0
    X-MS-Exchange-CrossTenant-originalarrivaltime: 18 Mar 2015 20:19:20.7885
    (UTC)
    X-MS-Exchange-CrossTenant-fromentityheader: Hosted
    X-MS-Exchange-CrossTenant-id: 66e73705-8f88-4af4-a8f9-747007b892e9
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: SN2PR0601MB0927
    X-OriginatorOrg: ice-eng.com
    –_005_SN2PR0601MB0926336071E348A5E0E902F4D4000SN2PR0601MB0926_
    boundary=”_000_SN2PR0601MB0926336071E348A5E0E902F4D4000SN2PR0601MB0926_”
    –_000_SN2PR0601MB0926336071E348A5E0E902F4D4000SN2PR0601MB0926_
    Check Page 6-35 of Users Manual (Help)
    Thanks and Have a Great Day,
    Bob
    Robert M. Steele, SET | Senior Hydrologist
    [email protected] | 803-603-1686 (C)
    [cid:[email protected]]
    1021 Briargate Circle | Columbia, SC 29120
    803-822-0333 Ext. 3015 (W) | 803-822-0034 (F)
    http://www.ice-eng.com<http://www.ice-eng.com/>
    PLEASE CONSIDER THE ENVIRONMENT BEFORE PRINTING THIS EMAIL.
    CONFIDENTIALITY NOTICE: This electronic mail transmission and any accompan=
    ying documents contain information belonging to the sender which may be con=
    fidential and legally privileged. This information is intended only for the=
    use of the individual or entity to whom it is addressed. If you are not th=
    e intended recipient, any disclosure, copying, distribution, or action take=
    n in reliance on the contents of the information contained in this transmis=
    sion is strictly prohibited. If you have received this transmission in erro=
    r, please immediately notify us by telephone and permanently delete the mes=
    sage.
    From: cuba28 [via HEC-RAS Help] [mailto:[email protected].=
    com]
    Sent: Wednesday, March 18, 2015 3:35 PM
    To: Bob Steele
    Subject: HEC RAS defining a bridge geometry
    After running the model, I’ve an error message concerning a bridge geometry=
    “Deck width + distance is >=3D the length between bounding cross sections. =
    HEC RAS requires a positive distance from the end of the bridge to the next=
    Could any one explain me what is the deck width, for low chord and high cor=
    d ?
    Thanks a lot,
    Hearily
    low:
    http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-defining-a-bridge-geometr=
    y-tp1444.html
    To start a new topic under HEC-RAS Help, email [email protected]=
    ble.com
    To unsubscribe from HEC-RAS Help, click here<http://hec-ras-help.1091112.n5=
    .nabble.com/template/NamlServlet.jtp?macro=3Dunsubscribe_by_code&node=3D1&c=
    ode=3DYm9iLnN0ZWVsZUBpY2UtZW5nLmNvbXwxfC01ODQyNzkzNjY=3D>.
    .naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
    bble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nab=
    ble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21=
    nabble%3Aemail.naml>
    Check Page 6-35 of Use=
    rs Manual (Help)
    Bob
    Senior Hydrologist
    [email protected]
    | 803-603-1686 (C)
     <= /p>
    3D"cid:image004.png@01CE7175.C7F88B70"/
    1021 Briargate Circle | Co=
    lumbia, SC  29120
    803-822-0333 Ext. 3015 (W)=
    | 803-822-0034 (F)
    3D"cid:image006.png@01CC6951.5DB915A0"/
    PLEASE CONSIDER THE ENV=
    CONFIDENTIALITY NOTICE:  This electronic mail transmission and any =
    accompanying documents contain information belonging to the sender
    which may be confidential and legally privileged. This information is inte=
    nded only for the use of the individual or entity to whom it is addressed. =
    If you are not the intended recipient, any disclosure, copying, distributio=
    n, or action taken in reliance on
    the contents of the information contained in this transmission is strictly=
    prohibited. If you have received this transmission in error, please immedi=
    ately notify us by telephone and permanently delete the message.=
    via HEC-RAS Help] [mailto:ml-node+[email protected]]
    To: Bob Steele
    "Deck width + distance is >=3D the length between bounding cros=
    s sections. HEC RAS requires a positive distance from the end of the bridge=
    Bridge doesn’t contain an opening at downstream and upstream."
    d ?
    Thanks a lot,
    Hearily
    If you reply to this ema=
    il, your message will be added to the discussion below:
    h=
    ttp://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-defining-a-bridge-geometry=
    -tp1444.html
    ml-node+s109=
    [email protected]
    click here
    NAML
    –_000_SN2PR0601MB0926336071E348A5E0E902F4D4000SN2PR0601MB0926_–
    Content-Type: image/png; name=”image001.png”
    Content-Description: image001.png
    Content-Disposition: inline; filename=”image001.png”; size=9028;
    creation-date=”Wed, 18 Mar 2015 20:19:19 GMT”;
    modification-date=”Wed, 18 Mar 2015 20:19:19 GMT”
    Content-ID:
    iVBORw0KGgoAAAANSUhEUgAAAPYAAAAsCAYAAABWt0WBAAAAAXNSR0IArs4c6QAAAAlwSFlzAAAO
    xAAADsQBlSsOGwAAABl0RVh0U29mdHdhcmUATWljcm9zb2Z0IE9mZmljZX/tNXEAACLESURBVHhe
    7Z0JmFxFtcenO50NRSYIT0GEIIvgAw1gAFmDCy4PlC2ghJDIosiOgIAsIUAQkSUgyhZ2AyggAUFQ
    BAKJAoIQMOxLEowKojBhyzbT/f6/S53+TtfU7e6ZDLy8Yc73na/vreVU1ak6S52q7i6NHz++pQ/6
    ONDHgd7FgVLvGk7faPo40McBOFCa/J/W/i0vDFlPzwVhpYfYAq2W9gWDnh6z5ZNvXfHg6h+RBvm4
    kjp6iH5LqX+p2L54/lujhs99KqY5bty4gjyRnhpLT3W5R+lojANhscbZNE9VZyXVWUH4qur93Tqk
    9KLeyz3awR4k1tX5VPn+ap6xrhjW3Esa30tuvD22Pprt23vN41L7C4NWLBUr9xUK/QqVSg/NbaGY
    6YhByy4YoYf7SsXynsX+y0woL17QY8JWbikWKsX+D4+bue7m49d7Ml7c64uRF6jtf4aFfLsm9kdu
    Yj+n51OEDPhk5d1bbx2K1s7KP0D4gMoeQ9kgWNfocRXhv4Xzhf0CLq9PFterwtGq84rK76Lno4WL
    QlvL6hMF2C6cJ5wpvEZlp9frS2ibsXxLeIPw8CbKb68yRwk3Dv1arP78Vc+/EF4o7NC7jYU5YjwL
    HF36CbYKPySk7rcDrSv0+QloCAcIBwvhK/z4h3Cq8HyNa6Hvp9o7Te8bCd8KdL/phS8a0yCVv1xp
    QwKtG6P87FVlvqKP3YRbCVcTMh/AfOXB35uF0FkUxsscwP//kOZo2nhpjzJT1beMz6EfKA3KM84x
    wrac/tAH1iFrYYLw7kBjmD5/LjRjukwoQ1/eFD5PX9Xm9Z6u2l5f75OE8PqV8ImwoeRbhfD/NtU7
    Dle8KKEeKAztpLrYxbQg2O2L242x/QvFUv932ugZKBRK4spCFlEKBikR4TV4MCqE4H0+pK0rhm0t
    ZsDMPPiIMrYRwnQDmPvfwrUbjMj6+DGVYyEbTNMD/P+MkIllMe6FAlBfbs2jqfwPKG934arCPfSO
    YmqrU35f5V0U8lnYjwrhzReFGwpvEz4t3FYI7WYASwgwoVsIUW7Av4QI/UeFw0PaN/T5BfVzV/UT
    YTfAS6QPwNvCekofAfqycDnh1XEHRXtlpZ0rRAEb3KWHPwtZC4yN/oDQQKnY/MfkUu/0D6FGEDcR
    rhMKzdWnVwhxXcrTNsJ3pstEYfj1+YTeUaZrCT8t3Ew4Wu0dI57RVwPqoZzrwWtkamENrshSw9Se
    s9jZHGXzFCarWK6UO1oqlaa9xgZ9F2HRqrQU0HApQACZDAQGwCp48B1B4K4TE7cRE7GcKcDyAFX3
    NYwtm/AACMx3hCxCtPwHhVg3rAGA9+BhjNqbpXaHKvEO4ZpCFuFEpU1T3uupjihtayFCDfyXEOGo
    0exWT3QQ3PPD+9Gi+WOXh6XGwj0jRNN/T4iHwQJjDFgGFhlAGSw0fEOosRDmbWA5TLBvURt7U0Ft
    j9PHiaH+dvoc6/pCsvcI4NFi61vik3aZA4TyZZ8fhPp2pWHNAPLxkuBpBipj45uo19lC5o3xUNbm
    B8/DBPYePR8hRPGi1CtBqCHn1xIuvl8DcddZh2wBUDzwyQAFyPiZbwDlfK3aYN38WmgK72SlYbkR
    fIA6mayG93P0ideF4oA3GKxsPHRchlTGFGvaDVe8UtZ8VJbAw5Z1f8eSd41GoSjvpryQCUsBzMY6
    mGCzWOvBBsq8SkzcSUxMKQtzI9scETrsJ/kF1cVC5EFMN5tU1ZmtdrFCJ4SKCDiewH05hHA1PfCe
    FGyljxbCXPppVtvq0t4dYW/N+K7yRNWnWXo3wX5R5f6U6E9Z5d5w6d4lO0/phwlZcAAW15RMTIr2
    85Q0PGpXO6boWMQZKI31e6nQhJo5H6nyeENV0DtW9RyVRzAeDp7D5dF4vSJ9RWUeSoyXNttcuglY
    qihp5tLz7C07z9644KozzjdE/6d6NMFmfF8QmmDDa3hlCuG5vH6WBrXMb2/vqMxuYY9d7sYeu4BG
    K6ihrgnmO5zQuCvl+fIY0GzVCcvjkk+vFBYX5GJ4LeizPUNJr6dVrR77UBbjfon2bQKrrjgCEU1y
    IwbEi8C/e0+A5pMusdrDQn8t6h9u7srqj3kVPhsFAbBwPim83zJVHmuVpxAo5t3memPz4/DPKBOs
    lQk21igP8JR8e6lypjS8Mt1JBVEYBpfGQu0JKQ8vpROIf6w9r5QyQcsBL5DNrCsjE/Mpj29Ycw/G
    P0vzc4HnlITSE7d89+W1Dz5n7UarMneYs5e/s1gatGW5vdG8dKbQr/8yLR3tb00qdbRMkCpFOzUP
    AxcWWkqFRYnAWYpGHm321QQ4LP+7muQ5WgDVQFtELA4SdEkZ1RmceRYUQbuaexhXQfmsILxRiCbH
    1Wff9XUhQZoYbFx4NpdrbLiocbwhr1t+bI0sU4oGvGI7YlCNSicKx4o4Rc/64AV7lCuIxced7gnI
    9qk54HmRN0+pqs2ulVhYY6Xvaeda4pImWjLdVm9/U5dRV88e0g0zH0gW4FHxtd2GP1+zb+qJmYlo
    tOXQxO0huOUF+VQJwGzxhSixgU1mvQlP8oG92Ts87gRe8xNgMcAFJACVgrFKxBU7VHilkP02MFLt
    XJho51nlbRPKYLHvVDmCTGeqbL2x5DTfMNmPk0Ahe0uDXzWs3VyBTEA0DiyZDyTN0ftjzZFoWMrv
    /+sVbkbhUQa+1LPufu18yTXYpuff1+kAwbskdM1KJkgogJWJZ/ehssR9aKJtXD0Ppj3naYGz9/qM
    Mr/pCkxS2j+VNzWkpawFWX4hf051JisNi4oFJg8rRQQ7uX9UeSzaIcKvhnZwpw9M7fNVligyEegb
    lP+i3olmm2CT/inh49E4b9I7AT0D3OFjhTur/jjRqSds3VLYIoulJmiH0jS+nae26IuHZi1YVK36
    itKw6DyJz6uNmiO1vIpNpC/Zkq5tAFoo8XrWvSK+sW/eQXhQqM5YDtCY6lnsQ1VvR5Xj+A2+I0vX
    qs6574VQNcHHd71I3iKy4Ns+gTkmKAjmNWLaVmISVs8mOqbj34muI8Qe0Kh5RwF4BLjRQ4XsY3Cl
    f6b28o7dzO00dxN3fLwQ141x7CocF7WP8BOwIuLtgejvLxmfPg8mXpCYAdz8rgIK6gHhMCELjSDW
    z0X/2gShvKh/ozZtLlpV0Avgu+31pfrVlR1sPUVGIPOHQpQzQKQbvuUFUK0vHIuBHv7Iy/tFsOtO
    gBj4lhY50eWpQjvy4CyWYzDOLatBM+NgCLh82HH0Tj0zQfAUQUFosdTminnmo40/IbTACFuhs9SP
    pGulttgujBESnf4NhPT5jNJ/p0f21wBW+BSlV7dVwTXfX+lE69luMCYPXLrB7U8FlVqjss28MnZc
    cINHc4Sa/DZXrisCYnOBQvPCUi/g1ajvtN8dD6WR1wFdsJ4HgOInKGr8pvwvmxBqxnS0cHrgA23g
    LT5HxvtFsBEyD50Wkhj5shNuK4+L/nPhdYmVASP9YuKaZupIKLWoOO44SjhRiAuGdTxbODJnBbIH
    x916Un1kMrHQKAdvVYmAbynkYkYNqF8EzjjX/b5w/9CmlRmjvIsTVrs7C50zWJSVjWNf0b5ctP+S
    GJcXCqx77uIPShS6KErb/+La0kejEyutHFYmk5GDZi/n+H76rUCKMH1jruhr3r6dMqcKuUjEBRXo
    /1hjvlN8axSRfkplMgsdQ28VbNOUNt74qCV5/i0mPSaGjlWlG4TGm730PCwQihWCf+8KL9lb4yaz
    N94j0N5FbW+rPqSCJWwVgHWFeRF78nHXOwk2GWGvdrjaYGyXCM0zWVXPXGxodNafWj9xGguRvTXH
    UAgrVvU0oQ8IWR0v2LSPgsvbI+OxYI2IiNu5+d/0zNGQCfQnNbZlNU5/rt5MnynDeqAPzYBXeHn3
    KIwO89wq5IJPnmAjyMRGJgp/Firikh8qjOeasl6x2Hl2p353ZTE2M+ilpQyLyh9NxcEr07Qpy32z
    FsiRqo8FNSAY1Ai64k4yOSwQ9sjsjW2BoKm5l1y9zKD3tZXPWS17fZSAnd0jGGwFuE02InTu6yq/
    ournne8j4H9SGRQFWwcEL89V7I7F/lBQjuz/dwl9+iKekNJ/GTHwVfeOcCK4cZDTigzVA94J8YdM
    AYlem+jeo0e2UAA0iJHcErXTzGtXXHF/X2Bl9eHD6kteYGx1Nc48zfVzmugQhudiIeuOsQI/EG2+
    OzDblYcHucLs6fZWwcZt81banxMz/rxgWMYbMZNrnVhHH1FutECGqE4h7GtTZWPB/6DKPqU6RKbN
    ag/TM67yREeAaD0u/69Unr2yh+dVn2DaiJCIcLDnxiJzJLSNPpZRvVujeo/q/TUhwsC+vsZaB9e3
    WQvmx2V8JYjHmbudyU4QTb6I4wV3husTio2LN1j7FBBfQEDYs/tg5HlKw+0nj7Z/IOyuYPt26ylp
    thVjQ2H4t6kw5q/RsnLx8WVMf4DGxRdzMCbnhMqt+jxZONp1LL5HkdvP3irYscsS74Xsvd4e6RAx
    FOFm35oHnrFo0lSgzOrGgRabpJ+ExWlCcKwm+NeaaI60LGgGjZtyOoHVIqBkl0H4Ygg3sOjbCGgH
    ofICwZk2yg+4PqGMGIe/XJJ3Rs+YfJwh44foPaE2sdB7hjbW0CdCx1GbwR/0MEuIVQOOVp17VRel
    UwWlfV4vB4aEST5PZacr/4xAm6wtEQ6lH+bL2XPwVMrKvzTKRw78/BhvUmSYh1OElIFPp4kuCqcm
    8Km0bykPhY33dVlEKO905XKVO9TxhLm8UrTt3ns8D1XPDvphvTC+hb1VsLHWnnkxI23R5kZSxZwF
    YhQL817hx8PE+P0Ndb1Vi/f18aLAmnogEvp4cF1ZaHYkRTmCKSwKXHCi5zOFM2KCvKv+LPWT22RY
    Z4AjrE8LEZANhCinm4IAzNbz+sIzhSgNAi8XJeiygLzSWk71ucwUb2mgMcTV98+nKx032RTWkaLB
    GWtmvfT5ut6JyrPnhw7n0ncpbaI+KYMVxxoeKoTvRPw5BYiBYyKE7Lshg7NdAokoAfNwPqNnYiV4
    M/6+gtFiHn3wLDeQpj78TfQJQmZekYD7BfcojSAr2yXWFrcCaQ/gODG22Myx9yIzAxN4wtzjlhuc
    IdqbKo/4RbyOjwrKCh7DAzwIYjT79FbBtgVGMIZBc8bsAaECYkbVFBIz+YIGrtBvw0T48gh2q5DF
    TjqTRVt5QRKLYFufvLeAEBD4QiGhhUdhdfW5Q+gQEdJ6twPZLyPYRps99EHCtlD/f/QJesCK/EB0
    U8Em+MdCwcojVLwjaCnBNh7ggSCcGYju42EMKCzGRP2fKO0bWJRQ5ja9E1g7SYhlRsB49vDiO+Q6
    WVlrhz7uJzqcSBwhRHFBMxWwY9Gb9fNtIAfMJzzmM1fhh35fqvbYVx8v5HgP5Yvn4OEJ8tVvTgpi
    iNfCR1wBtlbMHcoZPvGJ90gQ0vhLP1G8KL4YViFhqRHsK2auvlq/hZXxhZbigEr8NbOCrrdVioWW
    cvmsUcNnPZQYTJzEwT6DJoqKNYgXL1oRS/VSI1qaGLTxcJVD6Oa48mhQLCrMN5c0XviePEdm04Wv
    C5nY2ZYZFMjmemfxIwS0RZ8JjBEpZXHXAy6hEA2nDuM1l429KePEiuN1sBiwKnfFLm9E/G29owhQ
    UualpCLWbAF2FMKLOGAJyWOEVwqZB/KxZt7rQWLxGvgiy2f1iYeBkKBU/i58TMhXWNui/nV6VZkr
    RQMebyhkq4GLj/JEABnzI3XGTEBs6zBelDPjrwuihRfEyQZrA6tNv7H0rJEZwunByqboPKxE5pu1
    wFxXA4kocJRf6Dt89fOJ90g/24TMpfHSvCsUYxYvWWoEW0tjxWL/gWOK/QZ2/t62Lq3ywwod7fOm
    qM8NBVvMQWBzhVb5LygfbApUHu1bA8EtjYNZufRwmZUJJkH5uNvdAtVlYaDM4j4y4SgTsGkQPQT6
    /kYVGpVT/rxm6NCOyjKvDee2Xp+CIKEowKYh1Gt6Lo2w6qGEu9Pey6oHJgFFrwwwns+69XzhpUaw
    1ZGOSseiReVyx4BOP8gQBLulXKznjjY9kX0F+zjQ2zmw1Ah2b2d03/j6OPBecmApEuxSST+LNkDf
    7dYOO9qqFvmVlVJL+/z/WIT1veRRX1t9HPh/x4GlRrBLg9vnti9oP6nSsVhBljgGpdhUUV0tlwim
    9EEfB/o40IADS41g77berH+qr+P6ZqyPA30cWHIOLDWCveRD6aPQx4E+DhgH3heCrXPBzTRgDvo5
    fuFctOb6H8xQGc5j1xJy1MPVxhl+mSifywFvp85Ulce5NDezqueR3BZSGpcl+FVM7hfTBreNOOt8
    LRyXVZtQHme83Ov+l5458+Xcma+CctaZQajPZQbSOMribJmrrJx/M5eMq1XYQT2VJ48fOux0tBfa
    4KLOvzk7jcbKN784n+WixkzlN30URB9VvuE5cBgPY+a2FP3nTJYx/QMeiw7nwvyKDWe5NaA8LgPx
    LyhtUb85/95CyCUNzqb/pDKcY9tvgtNeRWlvigbxmpXC0VJMH/5zBg5v+IVU5p66dnGFSzHwFL7R
    FnNqV4Tnw2/VYUzMod2CZM6rx52B/+RRfqHeW/UM7/yXTLJ+hXlkjfHrqf5GIHmsM27asW7/rHzO
    7Jeic+wa1vbMiwbNAuWqHxOAcHFnmZ9C4kcNuMkDY7hyyRU+FgBXM7llNVnp3PY62PVkWz1zaWNk
    onfcruJbWHsHmtye4vLKU8KzRGt/0bpKz3zRgRtKWwr52qGHnfTClcddQh84Hz1O6O8Zo5yuFb4i
    RJBZfJzXozBoa2fhL4QIPneVudzAxY2D1P4jUXssKmjT92zBqRzfFuOyy1Dh3UIWET/wiBAcIhr3
    RDRqXlWO23Pb65NLEqerfKOLNShTvvjBZRSEhT6xHeNSC1dEGRe3sGI4XAmv0YZlqE3K7y/kLJxt
    Hdc6z1c6N/hOVF/4Vdmr9cxZMDfz4N+FSjtCefGVT/oxRQgP4Q1r5StCeI0AozB5Zw65zQaf4Tnp
    Twu3F3KNlQssXBxC6PjprOf1uYfagz+ssweEjJc5W014tsp8Tfnx7UUupXD7rHp7UOW48Xa2ED4Q
    e0LZ8Tvkz+lzVK+12Bog1miqkOuWe6EV9cniZVKHhmcWMhNzq/L3Iy2kX6BPvmCAFWaxANzq4jvT
    uyuNBeIBC8XkQp8FhYBvrHJ/1zt3tu2GEGVWEpp29zRYxCxugJtjWB8WigcuyqAc/iXkNhmCyVVM
    FNdAtHkQQquDtUOZXaD0zZRv9C2/ehNM+bQPL1hUX1fZ7IKP0lkw1wtRRrmCrXLDlH+kcDshPEYg
    ea8HjJE1SB3GxJzhVQHMF19d5EsQKFwPWMMqb1Tm+3pHYSIUt1vBkL6H3i12A33jAeOENwj35pEl
    pE/ww7wlrCVXVlFcplARaviHNT9FiAHhPVsH4RkLf6Roz1Ebn9Uz44Av9Ic1gbWnDsD64lrwicKj
    Q5p9ZLfPrI+ihYWeJpwkPMzmVencgOMKK/+V12sBq8mC39MvaD3zQ4UmWFwt5dZTVajDOxOxl55/
    HxbW/Xq2UD1W4I9MluMc1t5cKASPX7bACgFoVe/CsWBr3KlQjrS28IwW5jm+fslCy27BqQ9v6oN2
    +aMCf4zAMzeiAK66YqE2FrJYJrg+80g5W+gIB1sH3NPMfQWwLmoL64S7WQ+wKriKc1V+pp5HNChv
    2Qg031dmrqquqp7Nnb8CoVC+d+8ZY7Z9UB5XR88U4lFUhTr0HW9pshNaxpsprABt+vycEAVUtf4h
    D6VofGRu3hAdrsYCmfIR7dbQD1x28izf6Nud7uxmncqjOFH8pmhQLrZ9s2vAfLGDf1SZ7vpJ+572
    RXqfoTLeo6SNmaq7ifLe7pWCrcGhYXGjfpKwUjCAP6GjzGjKOAb6xz/oBZduTyGCzcKeIsRSohz4
    tRMTUATIJgYhRhNnEMrYAkFgmOwagXWNZgqHOqKPAmjL6RvJtEn71EmcD2Y1sWq4aSzmU0STf/6w
    /TL1UA62p8czmeSF2o2BBRi7h3HXoLWO2qBfCHkz+3L4UF38EUHGhvVhi4LQHejyqYNCAJhDrB0u
    dyfQePzVTS8gWMEZQtxifuCC+/O48Qbwx88T44qBOWLcKOI88PV4prwB/TEPhf7cIiTOw7/SrK/+
    +LIZHdL1sZlwh1SDqpP1pVcKtsbF4BFcr/ViPrAHgpkIbScIwvWIMjYNmbhmuD+4vzcJDxOe5Sqa
    F3C30g7SBPxIn/wnk7c0CDhWl4WYgkxAVZcFxXNsAXwd9mjsfWPr7xcvfULh4JHgRrPf3tD1ibII
    7JpCtghTc/rVTPLvGC9tCNlLXtNEpSxg5j0Oxh6UIYqULQ/u64+Uzr9I3hpo0m/zNNiK8AUPLwT1
    mjZBQwEjVMcKZwjNM8BS0y94b8raFFBMF8EGq0rP9Z+y9DNz55U+TB8YBRSRB+sPa5E9N54mSnGi
    kC2NgbWB9wV4JRT3q9cKNu4ZUO+LHuy3YLx3zWIGMfHsWwDKtmoB8dNJU/R8ZrCABF685iVgwp4U
    15cfOThcdVAEgH09L9vvR4AQEhQDWEhgykpYNRQNijkl2NXovPIHq32+fornMVX4YyH7vKxeUGAf
    C0St/UT36ieJDi44/GYfOkTv5ioT4Jund/NaPCGU3iqq99swXoJWY4UEgBg/wk1/ockPMq4rOljY
    TCEEQvQdBdxVoP4HsOiii7DdIWRrhsKGPjzMxiBAOLdVORQLXtDfVI9+IozMA94QPF1OyNxPFKKY
    2T8fpjzGTmD0BNX7VU5H6Q8/LfWgyrNnPy4osxv07NcG6xar7Oe4E8klt9gVBp/nWeYMoZqsb2JW
    Ck0djTSiFOUTXAFM46aq02m0fiNN7wXH+IUFRPtinTYQot0zl0oTww80sA0gqo32naJ3/uzvRj1j
    YVOBM6p6K9TMcBlbLNRWr2ZC1P7yap+vn+JhfF+fv9E78QMrV3cdqFwWsItc1WofA52JSnhKiLf0
    PSFWFvrnCRGYRxODYp7g28+E9GF5oQWsKD4oKB4ED+ElYs+pBIJiigJ+Jvmg9vn65jpCrH1KsRRU
    pr/y/qDPc1WOH2mYok/mzitVhJloN2NB+Zj1pAztI/B4fgRjZ7txsi7YlhB4HKV24qCrK5o9Wpus
    G+IaF6s/7MtZo35OURqdxqyyraHeHaUrpn102dKggQcVdWWz3J0/5StW1sj+cbMbUOlYKK6UvzT5
    wdXzFmgu1eLAAS3tixe89NzNYy4bP/6kuL4FsohYzs0hgtW0xZTXDtbG6iNImaIIWh4LeIuYSeBl
    hicQXEt+N40901Qh7h6CjSIxaxy3idCbQuoGN6tV4EXMD1sUxylvW+Fl6hsLbk6oZVsD3PsUsH9l
    gTHmFLD/3UTj3lR0iRZjwS7W51AhVvfJnHrwn6CUudhxMfMqZgQ+Zz/UoELsr81i0XcEKgU7KPFE
    IesgFmz6hSIxXh2lZ4TpF0ICXN7gMC9z1E+8MQ8IIsh3r7H4HhgbCmCMEKv7HWE9wV5B+ZmCxdvR
    OMfqEW8QZUafbOuBsFGWrWYc94APtDGiJMeitd+gD03QH9O3FPQf1l2Fcvvb+tIGPOu61S63L2wp
    lAZu3W/AQBZZl4Avi3QsXjSrZeR1V7hBG40XwwPaOi+IY4ttDZVhb1MDaHIlbCi0oAyLHs2dAYtR
    ZS7RI4EdhBZ3sgZU5jmVITiHQAEsQtwzJiXeZ2MJbE+dEs6YfN47rqF9WaaGjvozPywY9mcXCgms
    AbPC50b6JGAVAxaj00URCokeC3tvofHpDD1zpgx9go9n5FhLqtO/YrCasXWoUU6iwU8Eba/yeEk3
    Cx8PncRLGKE8jvviLY4Ft1KGw6ytKWv7KSws70+FbULz+KhvJxsJ9tT8zJHPx1VHAR0g5Ndh+VPE
    q1IElFaj2FWOX6A5QulE/FFAtqe2bcqnlGYBRCOJoLNV6ZCGGFzuWPRmpVAoLsEf33ddqLOe6HvW
    +g52S4ewq0A9AXuNFDyjRASXvRkLoRMEoZuhDNzmlCZFa8NQy0Mg48mF8ZTbUchiY6HHv23NxNre
    FQFqFa4qtOMw6xsTNTm8oLlzXUw3mJQCWE75Znk77dM17r+oj8erDIGubOKURmR8qh53F+JdxFDP
    o0KREHhrC7T4V5V99Yy3ws/nQrcRpOin4gcoEAR6DyGuM8CedVfhFsI7o4ZS/DFhxYphteFXto7U
    1wfU92x/K3wQy+no1eNBXh5tLSc694kuCvNsXH29e6Vu/eETD7EKKsdx3ZeU8FWhGSK2CXgT8GBq
    NN7q65LvsfMo/x+m4wqLIT9UF27UJzd9cGUy0DtCxVEC7t/hQv6BkgsZmWCGMgjGRUIuRzwSkjvt
    aZXH1Uf2k7hoJvQEPThW4rgM2E1obhoKB1f1BCGTZe3hHq8pvCck0T5WvcYCiW5BdG0R8cn8gfFx
    l5FGGaGc4vzTlIYweBeWYN/9akNNjB9nBMInSiZvm8AiQzBQkKZEp+uZvfNWoreC6GFFUmCKJdV/
    gkRYpyoEZczW5xyh7Udv0vN9QvajnHf7oBLaHy/LeIbgIMwAaantDwqPQBcCb0BbecILb1J7UdYL
    PDO+YQSeFbJ/JkCHNWeO8dQMUvK4vzKfsH5rfK9onNDg11H5g0a/PUBhMCa+Czm/WOy/vP4ys59+
    ksiUh2uqO4+Fd/hQ7GgLHS0PLOq/sLvjruc1z08olcsLWbhJ0IAJWsGAS/TJoT3HMWsJ9xLiJqKh
    +VXMQ/XIzSzcdsrgmrPfeliI0BrQFpNRA6Jxu+perkQmCWD/w39+TdAnworwfDu0h7u3T8hHiFEu
    RHW/LOTXLL0mh3cnqDwCyB6RBYArylk4wAJloSK4WUwBwdcHffT9REBYpFlwL/QDxYd7OF6f2a+P
    BmsFb7Aqw/SJJURgOe5jTCzKTqB6XNXkaI+oNW4m+0JOElCak4Twf6TKpdwyrOZQ5aN4Ge9qQn7J
    FMFtFdZYsNA4bjLBvMwrCUocpUJ/uS3I9girPlSI54ByWKR0FiVzCD8AFiTPNftP+qmyRLhP1yeB
    NYSWssP1znaDdj8uPFjIGkFojlceCpx5Ysuyg5D1AFo/Z6kM4yJ4iWc2V8h8MX8AJybVrV5Is1+h
    JfjIusxAfeLcnfLX6pOtKEYEgd5ZyHheLbUMHvJ6edF8mFWUZNdzN4xuE5/8s26B30vAOmnkxb92
    LJj3GyV0L8qWaLHSvqikX0J7RjHSSl5oBssjQKPhKqOFsRwI0N2OSdwdn6r3XYS4euxTTlUZLIEH
    XHK0cwpQBAgowISzT9tYyKI6RrSqWwY9E40ernSEnQjyy0IWPgJhQHn6zMIzlxTN7wM6BLMQdL8d
    YaEgsLZX5yiPRdppy6L2pgXFh6eRWUylXaY0rC1u3tZChJFtBEElrGISVI8z4LbQZxYq+2r+Lonx
    ryKkjZRg464TD0HgEBAWJ3tmAK/CK7osEY9FdA/UY9WDUBo3BTdXGsJFBBoFTl32p79VPrEF5m5P
    oSk4+A6d1+NBqfy9Ko9nQL9Zs3gzeHooTHPhOfJCUY9UGkJm82SKAk+POXze0ccbIJ6D8KOgdxCa
    R4iit7hB3KWzlLCBT1TbKIjrlIbi306Id/egkF9GfbY0Zr0nGSiL8V2D0RvNYn8B9jzYziOHsgaJ
    kIG5oDKPKhOsV8YCTZ3KqD5BjCyQoWeEiogwmASVwSU/pk4+i8nc8jwaWNAaK4r1VNpdVoEFXY+O
    8qfGxFkUSotd8XqsyfKCIqxRhkprNIY5qgqmePpQHf7UuOihfZQTltDiFDXV1RcEzit0AoJVXiX4
    MM3x8S96BlP9vDenn1hksArqQ5te8CwMqvxS3gtKBFNtsKZQuPGYULZJhdsr99g5jO5L7uPA+4YD
    /wsaykAY/uJALgAAAABJRU5ErkJggg==
    Content-Type: image/png; name=”image002.png”
    Content-Description: image002.png
    Content-Disposition: inline; filename=”image002.png”; size=10118;
    Content-ID:
    iVBORw0KGgoAAAANSUhEUgAAAIIAAAA8CAYAAACqw2L4AAAgAElEQVR4Ae1dCWCU1bU+s+9r9oQk
    E3YwkIDFBQoJKFYrSrAuLRVBn/W1dEGqbW1tMdhNWyrSvlpbbUF5rUqLhCK4sQQQUJYkaIBAgEz2
    hGyTbfblne+f+SeTDZHSPhcOnvx3v/e/57vnnrv8oyQUCpFEIqELoKEShS4g378lCdp9mS5dD8iH
    LWpuspnjSpnLKER7pCHaHNzRVD0gPaQh8oCoy95PUg9IhtUIc5ML+UUew8tAYSgVUlIqpUeVMsn/
    tP2jdj3CmYLMAeb/OBguawR0/6Wj8wGhiquxyWQSkkoZCEopqcJgYLekUyGVPOOqdv6uYXvzOU43
    EAjw/1vpMhAubfcODYS5yQWsBTZBC6hUUkEjCFqBwSCE4amUwF2jkNB9h1dXFkeaFQuIfysYLgPh
    0gKBx/pgYi0wX6OWkVYbZpNRIWgEuVxCCpY8nnK5lN3SDKVGtj1vxYSnuBSUJTIMS5EHV3A55GPX
    A0MCQaWUFgAEEydlkk4jI71ORglxSlKw8MMAYEAIYAAwWDuopN/54i+z/8xvh/JEAOAJEv1h3+W/
    H8seGAyEucm5Op3MrGUANDU2U7otnbwqLRmMSjIa5CRnm0FgaIcIGAAOpVq66PY1Oc/zW8qYYzUD
    XlwEgwgOhF2mj1EPDAICq/5caAGVTknjcxNo2uRUyrkinboVOhqRouqbFgTtEAZDGBBsT6hlixb+
    Pvcefr9YwWOJKtYjhn+MuuByU9ADg/YRDHq5TcNAMCZq6fpJiSxSJ7mD3dTdKyOTTEFeb4h6XQGS
    RbSB+BS1g0ItX5U9N3FP+dvn2rl8P7Ob2cesxrOibetMqVySFwz5Mzt91TZ/0G3r9bfYvMEe4jBm
    X/jJWQKC3086eQL5Q55ikyKDFFLN7mAoYC9uesyen7yymMu8TJegBwYBIRAI5WnUUgoFFXRV2t28
    dOylQPDvdLK6hXRsN+gzNVRR2ds3RUSmCiwzMWWwzWC88paUuxkIv+P26R/68f151900faYlRTE3
    oOqYVOPaQz3+JuZGFrSXGYIPP9ldxmGOPr/XxsCwIQ2H5wMovKGYb1baGBxJVN9bSiqZodikTCtj
    cOz+Qtpvii5Bn3wmixi0fLTekb5rwjh9PsAg1WSSQqXjzq8nk9pHCl42JpmlVF3rIkenX1hCYnnJ
    xqXAwl4DuyV+abn61NRjaSNNszXxrkTSt5FM52I7IkgmXQolaMeRTpHgMCnTzSqpwa6SGe2+QK85
    SIHcUEjYnyoO8V4VC5e8QQZiyLu71X0ys9Z5oLrRWWpqcZ3EzgWnpXzsNMskKopTjyajMpUs6vQi
    uVS1OxQKFs1Lf9b+mZTqRbz0ICAkfDljV84VhnxMDwADlpFqfvpoIqUl9JDH20lqpZsOlXbyHoOk
    HwAACBEM3mPxJNd7yWzVUmbKeMpMmkAjrOPIpE/i/QcFhXjPmoXF8oT5EOS9ChlJebPCH/SQJ9BN
    vqCL/QwqjpWy/RngWUbC/3gqIQ+DgwFS7An2lFV17e483r6ZenytOVwYgGHWyuMpUTuGwZtappYb
    1oQoULQg40XHRfTPZybLICAkLczcNW2KkTUC7yFEwKBmd1BqolSrmTrdTZRkUtMHFZ3k6HIJG06x
    ABDcrCW8J+JZfRspMS6R1Hpfo1avOCY1tLcaLYpUjUYfsmrHMBIwsAP5OkUaKWVmUkktJJNqOCzE
    o1zOdoGbnL4OQSuEBHshwIDhJayEl7JSNadRcAFBcgY6yOlvL3MHuzYfaV5P1V0HM6EtuBibRZPB
    WmIEGdVJ6xRS5Qu3214u/sxI9yO86CAgaG5NK7z5+oTHNBppFAhh7cAaQiUjpVzDQtNSd3eQDh+v
    Ip1OT0Z9Avn89dEpAtPF2R2ewxUH2t45tOfse9yec9MWaOUT50gN5hF+pzbB51Vr1EG1UhtSSNSO
    qdZb7Dzac5nztYqUHAZGvloWb9bIU1jwcha4jFyBTgZFO6YJnjJgVIIDrEv8pJbqGXSsgaQq8gZ6
    yeGttfcEWopKmzd01naWZDLeCmQSpdmiTqUU43i7Sq5Zw9PQuq9kbb6sJSJgGQQEuj753rvmZ/wl
    MUFBEplfAINWmCLkpJJrGQg6NtB0DAYN7TxcxqPW2w8AKt56hlYo29ZU4vd5DIaEkMWYHIrXWtmm
    MPlIpnWRROnh6UFFCgaUUqolhUTLQtQ62F0ml2rsCqn2aJwyiXQyQ6ZFPaFAKYuzMUB4YpCy4APU
    7WkSpg4BDOwXgcHaRdASenkiAyOOtUQHtXnP2Dvc1UVHm4s625w1edAUBlU8JehtDos2qYgtkZV3
    j9xm/wiD51OZdDAQZidZpk41td//pRlkb6kIawWeItQKLQNBL4AgDAQd2Zsa6XjN8TAQWAuI9gE0
    wpl328jVzfM8u9WmIANARgojgOAjicpDIQnbByG2AJj5RoSg7uONVtIq9RRv4KfCwODQOBgUxVqZ
    1qGSysxm1dh8tTzRrJZbBSBg2nCzPdEHhIiWiGgMOU8fCaoxPI1oqcNrp3ZvVXFNZ0nZ0catZgZE
    AWs3c4ppNMXpktcBEItHbf/MAmIwEHjnQHdr2rofLZ1+T4LVSK2uStIo1aQGCAQgiE8dSUIKKnrv
    1SgQoAkEZuGXbOum3m4eoapQq1TlbTQmSzya+FClxtpzJiTzBiUyr1HJm1cMAepxBgGEfGiI7h42
    HElJAb+c4o0WSjYnUJw+jhKNiaRR6IsVkhBrI0WuRp5mNqoysL9A3d5mcvm6hGlCtCXC2qIPGLzE
    JIsyg8EXohrnu/Z2d03RodqN5Pb1LpFK5OZEQzrFGZKLZFLZmvvG7C3+VA7787zUkECgvMSR1063
    Hn7s3vvNHZ5qanNVMxAMrA304WcUEDp658Quau6yh7UBA0AEw4bHT3+zZHtDOdfdzNzGjM0lMDaX
    8MQ6cRCtrczLV0h1NtYGtjaHNy/ol+f3OAPCJpZJY6I0ayqDI8Vh0vD+VIiNVbnFrFOlCvZCu6tW
    0BRRMHA1YW0RtiXgxlSUoBpLWFnUO4842jxnikrqtlU7nE2LGRC2eGMqa6TEYqlUtvxrY98tG9TA
    T2nAUEDAq0ppTtJ9C2+3PffjO35GVR3vUavzLHe6QQCCWsagiGiIpo4GKq4oiq4eAAS5VFL/w9l7
    rov0Gdtq5GV2RdjDz6GAgJUiSHzCjbySVyu+mavX6vO63YFZXq+koKO7lxuooBRLGiWbLKRVhXPp
    VClsLDrJ4W4gHz9hT4jTRqwbexVYrsapsihJnU0NrjKAYt2xhr2Olu7aAqmUAWFIIqshbp1cJlv5
    3+NK7FzDp5qGBwLv0yTdmX7vAws//8el162gc72VVNn+ThgIAASDQdASDIgNh37La3veV8DUwFrB
    3en/588KDqzknoPAAQJsMzsjT8+0b47SSw2KW12uwCynK5DV6wxk8tPm5JHv84eqWfybaXvTw5we
    hFtQAAcY7tCBxt/O9wUkt3Y5PfndTpcNhmuKOZEMWhawjKcjNmYBiE42KgPByCpD0A59wIBhKYIk
    SZMtTBud3nqqd5UUH2vcY29y2HmqUtoSzclkNpjW8Z7HyqXjy+1c/6eShgMCOh07PXLKT7z3awuv
    eqLwy0+YpDyKzrTvZ/XrZhAYBSBo+FlWu4dK696KbjDVlHet/OO3j/6T8wMI0AACEOYsH5OoT1P/
    wO0JLup18fqfBc8AIAaC8IQbZxnBQGgvA+EmzgeNAOGjHEE7RPw81fNkz3Sy85+53S7Xso6e7gKv
    P2A2awwsOM4i9/DpqJH3PRp4ldESFnqM8EOxwIi4zcp0ytRNp05vHVX17Ck+3rifAVFboJArzYnm
    eN4MM6zk1j397QmnPnXLzvMBAWDAkbKcplhGz5038dnld/7X9Oz0XGp31wkjDgYkAOH1eWn9oRVR
    jfDnB9+fc7bMgc4SgeD66pqc+VKN7GdOd8AUBkCwDwAMBI+X7XaWX0+vH6BwhN5qyozUjzLAsC1E
    YMDoE4DAYVGqdOwuaOtqX+z2ewrUcgVfrHGSjJeqJJVTu6uODUoHAyKiCbjIIW0JtiMsKhtl6WaS
    w1dDJx1vFpfV7LX3uroLtGqtOd5icWjVqpXLJp55Olrxp8AxHBDwaqJWABh4C48Uo24fP/uuBXnf
    v/6qa6/RadiyZ7VrUCXyVm4KFVf+jU63HSCf01/8ywXvQq1jJGNa8Cz6zaQ8Y6rmeZxaDtICDAJc
    p5fygVVPj5+6uv3Uyex5rUHPecHQKD3MKA/CR7uAg0FA4HCBOr015uONpUuCodAyg1pnkylbuPUu
    YWu63VkvgBgbUZgaYC8IU0TEL25SIcyqHEmjDPm89KymsrZXik7WlVOv28mAUFNygtXOF3WWf/eK
    2iKx3k/y83xAwHthegCHNQPfYWW3MnvB5Clzb7zm/pnTJt+QFK83QEZ8KkGvn/g91Z/oKmSNgGlB
    AMIVefHKmx8au4ftAWO/aYABAGDgDmQv7wiOTbmSznXU0OlTldTh8HV2bqxLi5QhAgBPMIDAMh4e
    CBwfpUO1byxRyNSPyeVum0TZRkF5Ly83W6jdWRcGgAiGIYAgAIWnE6tqFGVqp9M59zE61r6t+GTN
    SYfP7y+wmPRkteh4hRFa+b3s5uJopZ9Ax4cBAZ0eqxlwbA3tAEDArZz3zZtnfLXglmvTUlOveqfm
    f9N+dNMGzO0gLA+9D7989VKFQfZgf00Qtg9wHS7eqiB7l5xGpymFQ6fde89Ra2PvvuaXam6JlAHh
    Y2pAeWAAM3ChQOC0Ah1vPrBEyYCQyZ02p/QU+SQ91NJrp15vOwMiwKpGXGryk6sRtASDBJpD1BoZ
    bD9k6WfCfnAcbHilrLapwcyIzLWYNGS1qtcF2aB8ZFK7PVLlJ+rxYUDAy8SCIWxAhjWEMF1wvAgO
    WbpFm1Hb4WyM9ACE5v/pjs/vZuMwvZc3jaARREDgQmx8gorqW9k+YDF/9fP5fGaQRg89+wx1NPVu
    a3qp5h7OHwsC2AgiEKAREPeRqbrjeKFarl3morNmJ9nJGXRQY3cFn3j2RGyGsPBjbQkBKABFBBg2
    th9GaKfRia4tjvcbdpbVN5+z8a6qzWpRk04vW8mAePrRyT2fKIPyQoCAzhbBEKsdxOkCQADLpqRb
    vlJa27Exkj6w5JfZ48dea30zdlUAIBh0Opow2swg0PLZgI7aHeV0tJqNRS9vQbPheby869cdRfW/
    4nIgbBEA0Arwow3QCBcFBM5LTd12s1yqWC2VBpZ0+EvJI23jTbMaauo5HhV2FAgR4UfBIGiOsMaY
    bLmTl51ZVNG5xX6wehufxvaY+YDObDTJHUolrfxxjvsTY1BihH8UgoEGFkY7P8U9AmwWuXmYnkkx
    qTFtYM/Ak5ltmhZOzr4ImfVGunriRF5t6CnJ2sE7kqeEew/jk4lSzZyIp/6OWtfrkeSisFEn3NBC
    /zIlG2yOeF3avXKpfnaa+vqyVPksSuQziXFx15FBydfzBBpoiwqn5v3iyjr+RnvPraIE9XjbnVc8
    YZs65kqHTCova2nxmNs7fKsfK1FUrSyTLYlk+lg/MJLDNDfZxl805fMdhBydTp5r4Cvsep1cuMrO
    19l5ySTd0tvg3vLmr6NraBEQEJAADKVc6uLpYWpjp1sQpFIt04dtunCnKuVKys+exbO8h3q8bCjK
    XHzJxUtuZTC6B9HR6a+lI+3YmhYlgSdYbKvo56B/jYwqazGXMEURtBUalOnLWtxHzHKeslx8R7PK
    sY9c/vNpd24G/+cN9VJJ+4t82plAn4tfYrsyPkgHmp+zV52rMLe1+G0aLa0tLJUv5s2plY9OdqK+
    jyWFp4YbUvK5dbvwaZtWK2fVHf6WIQoEfQQQWhl/6ka/+NOSI7iPKAoET4AhOH1kfB6vBOfvO9OK
    5aPkyb35272+wCxeMQj2wY2TFrL6bSKrXsVAaA2zp406e1zk96qott5FL754ajHta90aKV/cPwDQ
    oA1ETfSRjUXO+2Fk4wRre/0N+XW9Oxl2UmpyniB75z5+uVjjkQ1L0V7A0nOAkalnQFxpvY+6fPX0
    XtM6R4uj1cGDwabVKUiv1RYrpKqP5QpDnBrs6KXwMTJfD+FZGGv76JPjBCNBIjGptfInH/rHNauQ
    nFkcpQCCSPPZAb8grGCQ9+LYN2f8XZRkzCCrNo77mK/FS5XC0TPP1TQu6XOUbMii4r31LzMItiEv
    M2wDAAG3n7GfgLaK4GPnJSc7lzhbJ09dPtp4h8MkzaJkPpy6OuV+3mDK6KuMpy40Ikx9LtHf5Wuk
    nU0r6WzPLrrZ9nPzF8c/aIs3W+xut4/a2rv4AM25a1X5iF2/PTE6P1LIx+IRNRalX0gJmU1yspoV
    ZDLKBeEBCFGt0H+q4PME391PLTz0d34LEQQh1gizOM9O7qs5+8+27v558aydXk8gLyd1Hk1Om8VL
    tTZew4c1QSDoI4tmBN87sNBrJa/Q+k37/3jyuaofc3noXYBAywyw+WmSOYniVXMZCgZGJ86pqzjc
    zjwUOejtpjLiqY4j85nxFMnOjmKOx3NYwgjeWr7v7R0n98U391Y44g1mW0YS7076SsjN0wU0BK7I
    CQYktAX/E5aY7MazrUtKHV0yfpEgJelTaPaoL5BG00ybPniDmtqBbeIPitWUYlWXp8fLf/hkfulr
    gxrz9asLOCw3JtzO7mJmc4T5MSTlx4SWsbuYnn3PERMWdYan7bA3CgTNLam7LGZFfu6V2XzH0Egt
    7ZWUpueX6vDynr1UsBX4CyhWb+Fpgq+2O04f6hi/7gflnVwUwBC8dmTcLL6AuoPdu3l6uO7x7TM3
    phjGz7/Gdhvv5vWwivALF1vMfIcQ189eO7yFdpZsf33Dxg/+SO+27eN8AIGoDZJpsnkMnxn/xJaS
    Mb1g+o2UM+oKcvR28VTSxcmGpsL1q+wcY7clpecjT2ZyOuVyvrIzx+goc9H+18nR07WO06wcEhBh
    AazOHzvVxkw5I8bS0bpTnPyjUaY1RchQ3d5IT+94RXAX5M4iW1xKtMyy2kp6g4/xZ2QHm746W/fD
    +8bsWUdfv7qQEy8ryMkz56aPEdLa2xqFNhSV7SGHq9ux5NqbzShnIKE8MQ/aDP/rx/a7PH7fUgbD
    uoHphwSC8bYRD8ZZFavz52ZSbkYSHaio5QEYpNQ4GTnafbzt6w1/18BgwPcNbFDyuA3+94ob9/2V
    KxCAcE1W3EyZVPJ2pMLHb//jDXtvmfydvK0H98zqcNZL2KKmeLO2pvhwSd2BI5XlNUca9rEOjZUq
    ysFKxMpaINsyKunlFfc8ZHxwwdeoy9PMR8s4u2JVoTDxJRUMjP5U/P5+WlB4L63++uO05Ia7onk6
    +J6CRZMezbdy/W+IAYNRMlvQHmIxX796be6IsUvWLv4J5Y4YQ23OajEGl1/5phNmqQ8nHMq1c16k
    t2ozqejoHirImSWcdTh9GDdhQpn1HR1074s/pS7aTc3t+sC0tHzZ6jsepDSLhbrczWJSoe0evqyz
    ZufLlDdmKgGkQ9HANqP8Bc/+gMrqTt07EAxDAgGqdMwoXdWEiVk0JetKquQdU7NpLI1K5s1jFd9Y
    dvD1s4Z6tiNCYSAwGPgy6/uP5O3+PDdIGMkMhBkiEKQS2r33dOtcjsPcDoaZgb0HkBiGfCDEidog
    ROON2bxj82bps9uNmalGKml8lVp7q4SE4p/RcZ/ns413RC9lJ91IabwNDPJQE5U2buKTR3FvK5qM
    4nVZNDXlNqpu6KI53/uSo6O7cw6fdJbySFzCIFi767vP8KFaOZU1FkWBh9y8TU1XJH6BwzdHC/vC
    mO9Tfdf7VN78hhCWqBtNmZbPRfPCP3vkt9gobqP36v530Dsg08TEuTQp6WZBWGatntbe8xM60vCP
    fu8mVoi2z8z8Gq+2tGTvOMRlYgyG6YbRD9E71X/mC759swDanJtSQFa+c5H16AL+FsUxiv5y+KyY
    JxYIorFHUJO+jKzirvaG/PJQC8VZlWTSnuErhRr+gimRRqUmkS1hDB05fYgCfNbPX0TxHBma/O0/
    TR3xuwdK6rhwCNeCr530fMeRv3xaz34IGIyRjng84Yf6hzuWAASEBShVs2z10seNaSlq2njiEeGQ
    KDYh3G311f2CMNKwR3GiZTvtsv++X1ysp81dzUvDgzR//OO0YtFD5uXPrFhD930OBu7qTV9/khp7
    3h02f1PVydiiyMy3oivb9hLKBHmDTjrjOBBtr5rvXUKTbTj23WhYvwLYs7fmeXJ4Ggl1g4oqHqWG
    7uOCe+Af1NPqrKK7sp8WbpOL9SLdcP30xuknaf64x+mxeffT8pd+81NOuoh5YN9HrX6URfYa1/Lk
    RFVp+PcPwh+4ymT8BbREwd8bKMlqTKKCaXfTvsq3+BZQDV8iCVJilnYiZ61lxkIjJ8GsJAt/Nd3Q
    7vknymRCpUbmbnhiCIAQNQKCw0C4Km6ULTXjy5gOfrvrG1TVfiaaRas00IzRt1BpbTG1djdEw+EY
    qeumVlMjvbDvCWG7WIycmpFP6daxVFqzm2ra+wTZ2lJIjyxYT2tefW6m3ev+7ZK8O8y8qqVnt/fP
    H29IpSnp+bTv9BZyege8Am+XtXV2U2WNqHnEZ7j2YHwKrWssjL4D2n/n574rbKZtK38+2p5KBsME
    6830nv012n1yh9h0un7iV2hSSh6Hb6X9Z7YI4ZXUSEnKl2mEZWxMveEsKD8zfhydaDgcLQOOXaEi
    WnLtclq+4Smc38AI72WO7fv+QMB8eUwnv29UhukvcUYz4btH4WsjNuz4AzgeynwDib9rKMh9gMob
    9lNZw+v4ND6HC4XVixFPyXEqAQjP7ajuYS+WfUrmsKkc1gTs7Udig/BkdSKfByOvvq2OXty2M5rQ
    qDXSc0t/x3OLjr444Tu09E/30MHK96LxE4xuamt9i7bvAybDdF3OXFo07QmC7fDA9Dvoll/MoS6n
    aJIcpILsE4ItUbhj/d2Lr7mZ3izpn/+qMVfTo196kefXSrrvqhvorlVQHDH0JaKaejftfbcjJpDo
    W/OW0ZUjr6La1jpa8bcfROO+v2Ap5aTcJPhNU0bSvJ/Pica9atxImw++Ss2OcFmo++YJy4T4jNxc
    Kio+RCfrTwh+Z8tWemDuyH71on+2/OhV0qkMtGH/i/SrTT+Plt1UfYTuvkpPtvhUg50ojiM8zFiZ
    RalvaggHSbqL6l7Yyur99psMT90yfa5Zo9IzGPA5Gn/XwFfAMOx7+UOT9LiRfLP4fiqpfSOTswZy
    RpgN/BtL8xJ4+WnQyvdxmI5ZxoyRj3pgaWHrOVbw7I0SwhlvkhF5OdNpewkDrbxvBC6ee5MAgqxF
    V9GuVRspWZfD8dujmZtyPbT7/eJ+eVbcNo/WvfUK3bvqQapaf5CyTDPohYMbonk2FG+jvJxrid55
    RTC+rvvzLwbkX0hP73yFVr72PHU89TaZpJO4jv3R/HA0nfP0y7N47p20JG+pkGbn4dJ+cU/0rqc/
    bOqzMWLf79nezfR+VUW07I5zFTS7kpEWIcR19ob7o6x8By2cvrRf2csWfFkAAZLfOf0eWvjTR8Ss
    nO4gvfRdElYsdqIEjgDazgsEQUiOjbUvPN/u3b3jwJnF8/Ky8zIsk/PSLFlsPPXwj2W4qutam6rH
    JI3do5dZtjw465VS3j+4Ndmq3DhqhJbieIvWqONv5vtAADcIYIDWgHZAPSIg2Bkl7BHkYK7HUg92
    iEgZCelkb+4b7byM7xcPPzavYvMYdUYqPX1MKAJ5UUZsPPIIhC1VpoH5J4+8gkoPv4kl25DxCBzY
    jpnZDKwI8TK1X32lp8vFqEHPgXFnG2sJPBxhWyv2XYwazL59FBvXFyq4TPyXJ8H+NFAj9MXuarZX
    7aLC3/25intpiyjMcI/1pRIEyptH227UJ78fb1JMNukVlIjLf2Ghi/lEiUJDDAQC0ojxeD9Rd/fV
    wi5HDxuDOrzDxdHF5AV4THwH8qOQjfctLoYAfgDnP0AKrgNy6EcDBYtIQbiRVIgX/bFPjCUwwiBI
    aWePbw8PSL5azptPBl60R8IRxywS3GiECBCEo4w+CoSOYfNHUNl9obwR9AbxJhGV/mE75Y7MFub9
    mGjBifhY2n30AC2+4U6CzYFNJWwmxRI2qFAX+f2ETZtc1gCx9MJbG9jIuplKH10vCKn4aP9pITbt
    UO7MpBH9gtc+/DSF3mockqtePNQvLdo8XFqE/wsU2/fRYmKFFA2MOETBwysKXXyKcaIQA3wy4cAF
    VPxghowvjj6yaFoG50OlAlBQyAWRL3hsMws9f/J0YTko5sHonP292whx965aRkMJBUKPpac3/UmY
    TjYVrqWnNz0XFnokAUYgOns3hNvraS0+VULzZ9wYmz1sXzz5bdq865805RvX94s7nwegWrn1eS4/
    bBiKaZc/u4KwmQXjVWTYMGC0J59tI5EAfGyOienwRBjy/ztouKkBAoYAxafoRhtE4cMNgh8AMQIE
    OGAKBgI0PsOYxmENzCAREGHf+f6+0/JasWpfI794ytqH1widISbH6BVGsBgw4AnwoDNFkEDVzn64
    z+CKTY6yUVbRntdbySH7Cwvu+1U/2ySAAx0uEtyxfjH8fE8AoZANTKxEChc9jF1MITnaI7jX988N
    bYWd0McWPRRtO1IMV/cyXlpfavowjYD6IGhR+KJbfIoACSr5d5Hwy6wuT4DcLhd/fk6wmkQADHyi
    3OHIz58wr1r+hxWCVoA6xWiJJfjRebFkiqTZ9NhaQZixcbFu5EWZAA00C3/i9DKVNpywn60qwVYv
    AAJNMZBQ38A6B6bp5w+GnCgPwsWeyPlIBDfaBO018H0H5i07O7zROTDthfqH0whifhEAECRoSD9v
    LZtwoQW3krucftJ0+/heQw+A8D/MIlguFAw+KuvYUmb+4Fv8wlkYKVCxUI1YSWDehX8ljzKxA9Ew
    CAnqv7qpVuhMpN+87w0qOxteNSDNfBbwklmsbjIAAAdBSURBVLl3CdMFppmyI6Vv06nuIxzloQM1
    zxcl73kGW7wQBqYiaJbq5jrBXoGQsHQdSLBlCunhaDDsFHtnCwOs6+3i9nfiF2h+MGPtkp/Qstu+
    RrA50C6RzLyqyR2VLbQLYZiezPGJBHsB9szu9w/0WymhDbBr8ET7oG1EGmhTxcaJac73/DAgiHlF
    AAzlD/H5wnxmNqh8fD2dt514r8EckGPCg/ChdTB14AmOBcTAcjlaWN928olNFl4YHQfjEKNUHKkA
    wLq3X0HaKEEA6Oh1W1+qYZWagY4HxxqQULWYp9e98bKTGt0v0XG+dRKur42uSLoCp4NQ3xhxqBsg
    FAnzODpfpOh8zt845F09WwwWQIANKIH+8cHzRS4f7I/5MDrnczpoiFiC8Iury2nB2h+Tvb62ho9l
    tUtm3Ro/PyePVn/zZ2TWYE8uTCi3rPYUrTuwVdgTiK0XKVCWSEPFOZw9YvSgZ/QYelDMRwiYZrP+
    lc8XFiaYlMI+ApaQuOVU3+b+zjPb7DDVA8weZneEsZkhLiPZOYDyE+8syPviKxiZkhtSBFWJkQPh
    lJ0pF8ARu9SCUHb9eiNZbhtHjj3V3+ff4NFSmmYGf6CZzjxeKN0fauXDgBr+WqWU7PxzbE4/NrfQ
    rnbmM3zeULj2/sI7zSGZYJcAQOHpIFsYnbHaB+UJU1ZSCi145ntOPlasQVg/quvcS7vO7uAwKaWb
    UmlC4pV8OWEKnxjF8wlWvJDW7a/hr4Sc/BnWST5lKqWTLeFy8kfOoBTDFN7Gjef9aBjdDNcAt5/Z
    z+n5V0WEsIv5s76Ut5aE//1C09CHTh9eKJZ9WA+lMAOmWGALZ8Edvd4CB3drK46q8btLvITEB7Hd
    Tv/iSFocLWM3q5kZHW+PuIfSCLgmNh27i6IahdChpkUjkPNGCfMpjp0xLThaOyqojT90xBTWwN/y
    h7VPNO0AB8CIhXsdcxML6Goc7a7Z8AchGUY/eChDEQCBtpi9mncQT7W+RMVnoVkGEoDWyuyn2k4X
    M9r19sBEA/zojyCXt4ef7zBDe/5H6EKmBqhzzPejmAGGfhSvV03lmUBAqJsvpGJHy+vjX09hw5Fn
    i4mc+FVmBbOVGQACwrOZIYR3mSGw/iShPHEexMiMVcmxCTFVrP7G44I6f/yFVU463vUXjofmEXWg
    mt1KZrwnOhVTFAAAzYT6m5gbaPFUK1/0yMRlD7N++E0rgO7BBQ8QrHYYgsWl71ZEQIByoV1igY12
    APRgnA0nM+P9sauH9qBfQcgHxmARNSbi0KdoP/pO7PfYei4WJHj/2HaylzsH6gHnB+ehsRw3Y7h4
    pUyqNWuVUzVK2RQuRcfpUBp+GMfR6fKXOpxeO4fhBTAVoBEiIwwv/1dmuPtobrKdhZwJIQMIUMuO
    3k7+qZ5aQVAQCOwG0BrWBIUv/NrJX5v8irWAnYPamPFEp0JrofM1zHhJ1I2RChBAOLgl4uK7CJP5
    K+rSB6+7i5bN+bIwL4vaCHWLqwUBnLw0XP73p/mXYnbU0KZjv+JLDygDe9AoE+WLBCBAA6I9ECS0
    J1hsD8AAgSAP0ortwhNAACKNzGg7wIz2ow/RZ+gv+C+G0N4a5s7YqeFCgIDKxjFnMafAMwShUWC8
    nMgikhGOhgP1IgjwstXMHzCjowaSkabH/5rn9wW5Y7MTIACMVFjGmCaweojaCo18xa2yZzNPCa1c
    iIvZzlzJDOFg9MVqBLEN6Hh0KPwgCV8snEop+p+TXjWzYEq+Fle+cN0MWgL7ArhyJhh2FUecWBHQ
    1gqcHuG90LF2ZmgXlCkS4lAPGAIHGGLbAz/CkU4cJEgLN/oMacHoT6RFGNqL9GD4L4ZQPvrJdzFA
    ECsEOhOZgVSMNisz0ItGwQBCg8WGix2BuF5mjBjMk+AGZoACaQapKQ6LY8a0ksGXVEYTzi7U0rCB
    xYEC9fD3D3WuiojRhyAIAcI4zdwY8fPjggjtTmWexJxIU1InUKpxXL+c+AmWlt5a3nOoiISj3QA0
    RhfqxBSA9/nE0L8ChOFeEsIGIEQgQBuImgFx6DQgEcIXRyLQjfChgAAVOpo5nRnTDcpCOUMROh8I
    h0aoZgYI4B+qXA4ektBuABzTIOZyjESEDUd4F4AbwEOd55jxbp8oigUCOvhSEToeQkEnwY0nwAES
    hY54kZFmOGGhk2uZARpoB4Ahdqphb7QOCB2jEULBNPNRQcBZhDZBxVcxo24AEcYa6hTfQWwvBI40
    AB5A52D+xIGA29yPLtRG6JdpGA9G7FCM5OhUxEGVip0mdiwHDUkYkWpmgACMaSlWMAAX5lSsEMAo
    WwQhOz8yoX0YGKgH7YVRh6eoGdBelA+gAQioE2604xNJsRrhUgEBnRhLoh+jSZwyEB+rMeC+EBIF
    BCGhLLFsUTAQzqUWBupBfQCeWB87o+1HnRfafuT7WNK/Awh40dgOE/0Dw2K1ANyX6f+xBwYB4f+x
    LZer/pj0wP8BX8SwgvQzVmoAAAAASUVORK5CYII=
    –_005_SN2PR0601MB0926336071E348A5E0E902F4D4000SN2PR0601MB0926_–
    #9209
    cuba28
    Thank you very much Sir, I’ve read the user’s manual help many times but I still have problems with bridges, I think that I must persever more, it requires experience… Thanks a lot and have a great day too
    Amel.
    #9210
    Take the difference between the US Face X-Sect and the DS Face X-Sect, subtract the bridge width, then divide by 2, = this is the “Distance”
    #9211
    cuba28
    Thanks a lot for your explanation, I get it.
    Best regards
