Welcome to the RAS Solution › Forums › HECRAS Controller › HEC-RAS Controller with matlab
- This topic has 5 replies, 1,518 voices, and was last updated 10 years, 4 months ago by Anonymous.
December 7, 2015 at 1:41 am #8175AnonymousGuest
Does anyone was able to control HEC-RAS using MATLAB? Any pointers will be appreciated. My direct email is [email protected]
Regards,
ArtDecember 7, 2015 at 9:18 am #13500SolomonParticipantReturn-Path:
Received: from mail-ig0-f173.google.com (mail-ig0-f173.google.com [209.85.213.173])
by mwork.nabble.com (Postfix) with ESMTP id ADCE12F58D8E
for; Sun, 6 Dec 2015 21:19:00 -0800 (PST)
Received: by igvg19 with SMTP id g19so71854306igv.1
for; Sun, 06 Dec 2015 21:18:59 -0800 (PST)
d=gmail.com; s=20120113;
h=mime-version:in-reply-to:references:from:date:message-id:subject:to
:content-type;
bh=Aqr7XYEBVdNtofQUfuvAQ6LLA6aVgAMbvrhtzVRzTeQ=;
b=yDadAGD0cnpstkMPDhI/UK+uwgNw9HhEKI/2fmLfUeSauhfhL7tXQSEHZEpNOCS87t
4MxAztQRPh7mCNuptqESmqfpX4cp6XivYQz0ZT4m8OQPDvIzhplTj8aLfJFKUfbSDC8h
DlZVcSRMKDoYtKy2DBJzKbtjQucTpUR8o231qe6rfRpOXnfyvd+tcbXnpUHSrq8Yvo9N
YrLzgxbO0hU/ALRPE0jmAa8adCNnHtyygmDPb9WQycvNfbm4RibX7PKSCPcNNUAhuvmU
iyqzc6OE8MDtf+8JqDKTwQzjHdnnQe2LpAfg4M/5bQKNtfR7xCEOKUfkhZ21vHwPINPm
+1QQ==
X-Received: by 10.50.73.135 with SMTP id l7mr2941540igv.19.1449465539596; Sun,
MIME-Version: 1.0
Received: by 10.79.114.201 with HTTP; Sun, 6 Dec 2015 21:18:40 -0800 (PST)
Date: Sun, 6 Dec 2015 23:18:40 -0600
Message-ID:
Subject: Re: HEC-RAS Controller with matlab
To: “Art [via HEC-RAS Help]”
Content-Type: multipart/mixed; boundary=089e0129482c9a756d052647fe47–089e0129482c9a756d052647fe47
Content-Type: multipart/alternative; boundary=089e0129482c9a7565052647fe45–089e0129482c9a7565052647fe45
Content-Transfer-Encoding: quoted-printableYou can use this attached code to call the controller. It was given to me
by my advisor Dr. Gerald Corzo from UNESCO-IHE.Best,
Solomon VimalSolomon Vimal
On 6 December 2015 at 15:41, Art [via HEC-RAS Help] < [email protected]> wrote:
> Hi,
> Does anyone was able to control HEC-RAS using MATLAB? Any pointers will b=
e
> Regards,
> Art
> below:
> http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-Controller-with-matlab-=
tp2170.html
> To start a new topic under HECRAS Controller, email
> [email protected]
> To unsubscribe from HECRAS Controller, click here
=3Dunsubscribe_by_code&node=3D1184&code=3Dc29sb21vbi52aW1hbEBnbWFpbC5jb218M=
TE4NHwtMTUwNDgwMjgwOQ=3D=3D>
> NAML
ace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers=
%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_em=
ail%21nabble%3Aemail.naml>
Content-Transfer-Encoding: quoted-printableYou can use this attached code to=
call the controller. It was given to me by my advisor Dr. Gerald Corzo fro=
m UNESCO-IHE.
Best,
Solomon Vimal
<= font color=3D"#333333" face=3D"verdana, sans-serif">Solomon VimalOn 6 December 2015 at 15:41, Art [via HEC-RA=
S Help] <[email protected]&g=
t; wrote:.8ex;border-left:1px #ccc solid;padding-left:1ex">
Hi,=20
Does anyone was able to control HEC-RAS using MATLAB? Any pointers =
will be appreciated. My direct email is [email protected]Regards,
Art=09
=09
=09
will be added to the discussion below:http://hec-ras-help.1091112.n5.na=
bble.com/HEC-RAS-Controller-with-matlab-tp2170.html
To start a new topic under HECRAS Controller, email ml-node+s1091112n1=
[email protected]
To unsubscribe from HECRAS Controller, click here.
NAML–089e0129482c9a7565052647fe45–
Content-Type: application/octet-stream; name=”run_ras.m”
Content-Disposition: attachment; filename=”run_ras.m”
X-Attachment-Id: f_ihvi9lip0ZnVuY3Rpb24gcnVuX3JhcyhyYXNfZmlsZSwgbl9jaGFubmVsLCBuX2Zsb29kcGxhaW4pDQoNCmg9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–089e0129482c9a756d052647fe47–
Hi Solomon,
Many thanks for your response. I tried to use the function you sent me with no success. I am also using HEC-RAS 4.1. Can you post your main Matlab function that is calling the routine “run_ras.m”? I guess I am having a mistake there. Do you have also a Matlab function that runs HEC-RAS and extracts some data?
Many thanks for your help!
Art
Hi all,
Now I am able to run and control HEC-RAS from MATLAB. One of the tricks is that for some reason, you need to work in the C drive. If you work in the network drive it seems that there are some permission issues.
Cheers,
Art
Thank you Solomon for sharing your code.
Regards
My code has such error:
No method ‘Geometry_GetNode’ with matching signature found for class ‘COM.RAS41_HECRASCONTROLLER’.
My code shows below, anybody can help me to solve this?
clc;clear;close all;
ras_file = ‘D:\RasModel\Program\HuaiRiverProject.prj’;
h=actxserver(‘RAS41.HECRASCONTROLLER’);
h.Project_Open(ras_file);
riv=’Huaihe’;
rch=’Middle’;
rs=’116185.3′;
bb=h.Geometry_GetNode(riv,rch,rs);
