Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS Controller RAS ID for sediment outputs?
  • #7389
    I’ve been working on a project in which I need to analyze sedimentation in a tidal zone over a 5 year period. In order to simulate the tidal flows I am running the model over 6 hour increments and reversing the flow with every new run. I’m borrowing this methodology from an article found in the Journal of Marine Engineering and Technology. Because so many runs will need to be preformed, I am trying to automate the process via the HEC-RAS Controller in VBA. I have hit a barrier in that I’m unaware of any sediment output related HEC-RAS ID’s. I was wondering if anyone can tell me whether or not “Breaking the HEC-RAS Code” includes any HEC-RAS IDs for HEC-RAS sediment outputs? Any and all help is appreciated! Thanks in advance!
    #12433
    majiddehghani
    Hi
    excuse me can you run sediment analysis using Hecrascontroller now?
