Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS: Connecting two 2-D areas
  • This topic has 1 reply, 289 voices, and was last updated 10 years ago by Anonymous.
  • #5915
    I am testing a flood model with multiple 2D areas. The primary reason I decided to create multiple 2D areas was to increase the detail within the populated area. There are other areas in the floodplain that do convey water but the detail is not necessary. It is a large system and I wanted to reduce the amount of 2D points. The river itself is also modelled in 2D because we have bathymetry and there are backwater effects due to tidal influence.
    I originally thought it was a good idea but now I’m stuck. Is there anyway to connect these two 2D areas along the riverbank without modelling it as a weir?
    Hali
    #9540
    You can only combine them as a weir that I am aware of.
