Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS Beta 5.0 does not run. Error message: hdf5*.dll
  • This topic has 1 reply, 362 voices, and was last updated 10 years ago by Anonymous.
  • #5942
    “HEC-RSA cannot start because there are hdf5 libraries in your Window system folder”. AFter remove hdf5*.dll, the ras still does not work. re installed the program did not help at all.
    I appreciate if anyone can help with this issue.
    yc
    #9571
    There are two folders that have the hdf5 files, one is in the 64-bit folder and the other is in the 32-bit windows folder. There is a post somewhere on this blog where I gave the exact locations, but I can’t seem to find it.
