Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC-RAS Autobackup Behavior
  • #5623
    huesmann
    So at least for me, when HEC-RAS does an autobackup, it changes the program’s priority in the running programs to #2, below whatever program I have active at the time. For example, say I have HEC-RAS, Excel and Word open on my computer. I’m twiddling around in Excel, I switch to Word using Alt-Tab, then back to Excel. HEC-RAS should be #3 on the list, but then it does an autobackup. On my next Alt-Tab, instead of going from Excel back to Word, it now goes to HEC-RAS.
    Is there any way to change this hijacking behavior, other than turning Autobackup off?
    #8984
    Keymaster
    Return-path: Envelope-to: [email protected]
    Delivery-date: Thu, 06 Nov 2014 04:22:19 -0800
    Received: from mail-ig0-f194.google.com ([209.85.213.194])
    by joe.nabble.com with esmtp (Exim 4.72)
    (envelope-from )
    id 1XmM4s-0007DR-Qf
    for [email protected]; Thu, 06 Nov 2014 04:22:19 -0800
    Received: by mail-ig0-f194.google.com with SMTP id r2so790220igi.1
    for ; Thu, 06 Nov 2014 04:21:54 -0800 (PST)
    d=gmail.com; s=20120113;
    bh=VQ9xz5aSLifD02YUFw3JfQ3d7RMAlQUYSzTFWfitBdM=;
    b=SgVU0/JRR9zEGad7U+8fyCyz6FmU69N/RUofeylErGiIjZtOr7HwnbU6FvEtIpvUgg
    1ZftqfBAwZv6b1v4TexihPdesFmV1MID/GJmUev1m3yCSNxZlC/W2ZM24pA8mszfc06M
    M9Mnswk51Wkm8vRKLPuOgedhRcvYWVkSv3FoWwV0f413nEBsa8RsZKc+2OgDjFyIIf/j
    2b8BBJcC6nYoWRUl8XWOvhYVt7p87OXx9MgypfWRXSrLn7MXW/h94X5vPcCPoiDhExTw
    elbmUDc7xrv6jKVUNITCZVVnIFAg3UYqMPbmhCySEDwQSrKpWZZ3KzmB7e8W4wIwIJFI
    tDdQ==
    X-Received: by 10.107.133.234 with SMTP id p103mr4206270ioi.7.1415276514427;
    Received: from ?IPv6:2600:1003:b01b:922e:b4fa:4d27:33b2:af49? ([2600:1003:b01b:922e:b4fa:4d27:33b2:af49])
    by mx.google.com with ESMTPSA id 5sm3043795igl.17.2014.11.06.04.21.53
    for
    Thu, 06 Nov 2014 04:21:53 -0800 (PST)
    Subject: Re: HEC-RAS Autobackup Behavior
    From: The RAS Solution Content-Type: multipart/alternative;
    boundary=Apple-Mail-6C79183D-F18B-4A63-A7C1-C6D5190E6083
    X-Mailer: iPhone Mail (12A405)
    Message-Id:
    Date: Thu, 6 Nov 2014 07:21:52 -0500
    To: “huesmann [via HEC-RAS Help]”
    Mime-Version: 1.0 (1.0)
    X-SA-Exim-Connect-IP: 209.85.213.194
    X-SA-Exim-Mail-From: [email protected]
    X-SA-Exim-Scanned: No (on joe.nabble.com); SAEximRunCond expanded to false
    –Apple-Mail-6C79183D-F18B-4A63-A7C1-C6D5190E6083
    Content-Type: text/plain;
    charset=us-ascii
    Probably not.=20
    Sent from my iPhone
    > On Nov 4, 2014, at 10:47 AM, huesmann [via HEC-RAS Help] wrote:
    >=20
    > So at least for me, when HEC-RAS does an autobackup, it changes the progra=
    m’s priority in the running programs to #2, below whatever program I have ac=
    tive at the time. For example, say I have HEC-RAS, Excel and Word open on m=
    y computer. I’m twiddling around in Excel, I switch to Word using Alt-Tab, t=
    hen back to Excel. HEC-RAS should be #3 on the list, but then it does an au=
    tobackup. On my next Alt-Tab, instead of going from Excel back to Word, it n=
    ow goes to HEC-RAS.=20
    >=20
    > Is there any way to change this hijacking behavior, other than turning Aut=
    obackup off?=20
    >=20
    elow:
    > http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-Autobackup-Behavior-tp10=
    74.html
    > NAML
    Content-Type: text/html;
    charset=utf-8
    Probably not.
    Sent from my iPhone
    On Nov 4, 2014, at 10:47 AM, huesmann [via HEC-RAS Help] <[email protected]> wrote:
    If you reply to this email, your message will be added to the discussion below:
    http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-Autobackup-Behavior-tp1074.html
    NAML
    –Apple-Mail-6C79183D-F18B-4A63-A7C1-C6D5190E6083–
