Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC-RAS 6 Error
- This topic has 2 replies, 61 voices, and was last updated 5 years, 1 month ago by Igorshev.
February 25, 2021 at 1:56 pm #7853IgorshevParticipant
Hi for everyone!
I faced some errors on HEC-RAS 6.0Beta.
Error message while I try to compute any standart (or mine) example run:
Plan: ‘Unsteady Run with 2D 50ft User n Value R’ (Muncie.p04)
Simulation started at: 25Feb2021 12:02:12 PMWriting Geometry…
2D Interior Area: Mesh property tables are current.
Completed Writing GeometryGeometric Preprocessor HEC-RAS 6.0 Beta
Finished Processing Geometry
Writing Event Conditions …
Completed Writing Event Condition Data
HDF5-DIAG: Error detected in HDF5 (1.10.6) thread 5220:
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5F.c line 444 in H5Fcreate(): unable to create file
major: File accessibilty
minor: Unable to open file
#001: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5Fint.c line 1509 in H5F_open(): unable to open file: time = Thu Feb 25 12:02:16 2021
, name = ‘C:\Users\Ïîëüçîâàòåëü\AppData\Local\Temp\03d85d35-3816-4636-b842-36694a2c4691.h5’, tent_flags = 13
#002: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5FD.c line 734 in H5FD_open(): open failed
major: Virtual File Layer
#003: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5FDsec2.c line 346 in H5FD_sec2_open(): unable to open file: name = ‘C:\Users\Ïîëüçîâàòåëü\AppData\Local\Temp\03d85d35-3816-4636-b842-36694a2c4691.h5’, errno = 2, error message = ‘No such file or directory’, flags = 13, o_flags = 302
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5L.c line 825 in H5Lexists(): not a location
minor: Inappropriate type
#001: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5Gloc.c line 246 in H5G_loc(): invalid object ID
minor: Bad value
minor: Bad value
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5Ocopy.c line 221 in H5Ocopy(): not a location
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5O.c line 110 in H5Oopen(): not a location
minor: Bad value
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5A.c line 1566 in H5Aexists(): not a location
minor: Bad value
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5A.c line 268 in H5Acreate2(): not a location
minor: Bad value
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5A.c line 620 in H5Awrite(): not an attribute
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5A.c line 1528 in H5Aclose(): not an attribute
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5O.c line 943 in H5Oclose(): not a valid file object ID (dataset, group, or datatype)
minor: Unable to release object
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
minor: Bad value
#000: D:\build\HDF5\1.10.6\hdf5-1.10.6\src\H5F.c line 671 in H5Fclose(): not a file ID
minor: Inappropriate type¥®¡à ¡®â ®¥ ¨áª«î票¥: System.IO.FileNotFoundException: ” ©« ‘C:\Users\®«ì§®¢ ⥫ì\AppData\Local\Temp\03d85d35-3816-4636-b842-36694a2c4691.h5’ ¥ ©¤¥.
¢ System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
¢ System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
¢ H5Assist.H5Writer.Squeeze(String filename)
¢ RasMapperLib.Scripting.CompleteEventCommand.ExecuteWith(Dictionary`2 kvpArgs, List`1 otherArgs, ProgressReporter prog)
¢ RasProcess.Program.Main(String[] args)Error with program: RasProcess.exe Process Count = 3 Exit Code = -532462766
Computations Summary
Completing Geometry 2
Preprocessing Geometry <1
Completing Event Conditions 3
Complete Process 7I got this errors on the Desktop with one local disk (C:)
but when I try do it on Desktop with several local disk, I don't get any error.Properties of date format on the both Desktops are the same.
Regards, Igor
March 3, 2021 at 1:07 pm #13011StefanParticipantHi Igorshev,
i got a similar problem:
Writing Geometry…
Bramaputra: Mesh property tables are current.
Completed Writing Event Condition DataPerforming Unsteady Flow Simulation HEC-RAS 6.0 Beta
+STOP! Error in the time window.
HDF_ERROR trying to close HDF output file:
#000: ..\..\src\H5T.c line 1761 in H5Tclose(): not a datatype
minor: Inappropriate typeError starting unsteady simulation – Stopping compute process
This error also occurs with the HEC 6.0 Example projects and the model runs smoothly when unsing HEC 5.0.7.
So i guess this error has something to do with windows region settings but i didnt figure out whats wrong.
Another source of the error could be the HDF Version as we both have different ones.
Did you ever try to reinstall HEC 6.0?Best,
StefanMarch 3, 2021 at 1:39 pm #13012IgorshevParticipantHi, Stefan,
I’ve check that windows region settings on the both desktop are identical. So, I think it is not the source of this error.
Best,
Igor. -
