Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC-RAS 5.0.3 Move Cut Line Upstream/Downstream
- This topic has 5 replies, 1,880 voices, and was last updated 8 years, 4 months ago by Rufusraider.
November 9, 2017 at 9:29 pm #6681RufusraiderParticipant
I am having trouble in RAS 5.0.3 shifting cross section locations for georeferencing them to a new location. I have used this frequently in RAS 4.1 for a number of years, but it does not seem to be working in 5.0.3.
I have a georeferenced HEC-RAS model for existing conditions. I want to shift a cross section location to display in a different location for proposed conditions. I will eventually edit the cross section ID, Station/Elevation pairs and channel and overbank lengths to represent the proposed cross section. I remove the coordinates in the XS Cut Line Table. The cross section turns from green to brown showing that it is no longer georeferenced. I do not get the message in the lower left corner of the geometry file that cross sections are not georeferenced. I then click on the cross section and select Move Cut Line Upstream/Downstream and click on the new location on the stream centerline. The cross section does not move and turns green. There is only a single set of XY coordinates in the XS Cut Line Table.
I have also had this problem in 5.0.3 when georeferencing a HEC-2 model that I imported.
I also have the problem when I copy a cross section and I want to move the copied cross section to the proper location. Remove the coordinates and try the Move Upstream/Downstream and it does not move.
The model has a RAS Mapper file created for it. This does not work even if I delete the HDF file associated with the geometry file. I have tried deleting the HDF associated with the plan. I have tried removing all of the HDF files associated with the model and removing the layers in RAS Mapper. The Move Cut Line Upstream/Downstream does not work.
November 10, 2017 at 1:53 pm #11003Igloo_79ParticipantI use two methods for moving XS in the Geometry editor:
1. Edit > Move points – then move the start and end points of the cutline to your desired location (if there are lots of points it can be easier to delete them apart from the start and end points e.g. in the GIS Tools/XS Cutlines Table)
2. GIS Tools > XS Cutlines Table – paste in the new XY coordinates (you can get from the Measure Line tool]
Good luck!
November 10, 2017 at 5:33 pm #11004ldguethleParticipantYeah unfortunately it appears they broke this great feature… Been meaning to email them a bug report about it…
Lee
November 13, 2017 at 9:02 pm #11005ldguethleParticipantIssue is known and should hopefully be addressed in the next update.
November 17, 2017 at 11:20 pm #11006AnonymousGuestIgloo_79, Thank you for the work around with the measure line tool. I have been using the other method, but not happy with it.
LDGuethle, Did not know you were still using HEC-RAS after leaving AECOM. Hope things are going well for you. Hope the flooding in Houston did not cause you any problems.
November 21, 2017 at 10:02 pm #11007PaoloPParticipantFrom
https://drive.google.com/file/d/1X3LWpOYH-0sdjEhdf9vmjE221-BdtSgq/view?usp=sharing
you can download a simple App to move the cut lines because the RAS 5.0.3 only move the axis.
In the excel you have to define the X and Y desplacement.
Clicking on RUN button the App will open a shell to select the RAS project and the geometry you want to modify.Good luck
Paolo Polo
