Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS 5.0 Projection Issue
  • This topic has 1 reply, 282 voices, and was last updated 8 years ago by Anonymous.
  • #6612
    Hi All,
    I’m new to RAS Mapper and am having an issue with my terrain data matching up with my 1D spatially referenced data. I’m setting the projection to Pennsylvania State Plane North (the same datum used to create my 1D sections), but the terrain appear to be showing up somewhere in the Midwest. I referenced in Google Satellite imagery and it’s lining up perfectly with my 1D sections, but not the terrain data.
    #10861
    Toby
    I have tricked RAS before with the issue, by deleting the spatial reference in RAS mapper, and then creating the terrain, then assigning the sp. ref. again. I have had your error, when I know the terrain data and XS data should match, and they end up getting moved elsewhere. Just don’t let RAS mapper associate a projection with the document as you add your raster files.
    Hope this helps.
