Hello
I install HEC-RAS 5 when I launch the software it give me a message that I did not understand “Error loading HEC RAS RasMapper componant About did not load.Le ActiveX component can not create object?
and thank you in advance
Has anybody found a work around? I get the same error on Windows 7 Professional 64bit on two different work stations. This is serious a serious bug, as HEC-RAS does not start up.
I have this problem, too. With version 5.0.1.
After this reported error comes an additional one: “Run-time error ’91’: Object variable or With block variable not set”
Got the same problem.. Installed on Windows 7-64, 8-64, and 10-64.
Looking for a cure… But lost in the sea of nothing to see… Please if you have clue… I’m ready to get the info! Thank’s!
