Welcome to the RAS Solution Forums HEC-RAS Help Hec-Ras 2D results doesnt appear
  • This topic has 4 replies, 566 voices, and was last updated 8 years ago by Anonymous.
  • #6823
    Hi everone
    In my project i cant see any water surface or velocity at Rasmapper.
    There is a water surface at cross section but cannot see anything at rasmapper.
    I couldnt fine any solution at all.
    I need your helps guys.
    Thank u all
    #11264
    have you created a terrain at the Ras-Mapper ?
    #11265
    hi
    thanks for respond, yes i had created terrrain. 1d result can be seen but 2d result doesnt appear.
    If it helps, i can share my file
    #11266
    is the 1D model connected to the 2D model?
    #11267
    i try to create 2d model. I have a map, flow hydrograph.
    i can see 1d results at rasmapper, but at 2d, i cannot see any water at rasmapper ( i can only see unsteady results at cross section, not rasmapper).
