Hello all,
I am currently working on a river model. Since the downstream part of it goes through floodplains, i’ve tried to model it with a 1D/2D coupling. Most of it works but when i plot the rresults in the RAS-Mapper, I get some strange results. My main concern is that shallow water seem to not be mapped in the final result.
When I use the default slop option for map rendering, it shows some ponds with no connections to the overflowing river, but my simulation tells me water is definetly overflowing here.
I did a second try with another render with the option to render the shallow water with the horizontal rendering method. And there i get some confirmation that thoses cells are really wet, but it just doesn’t show with the slopping method.
I’ve tried to turn the plot tolerance to ridiculously small depths. I also tried the full momentum method for computations but it did not seem to solve this problem specifically but i can’t seem to make it work
HEC-RAS version is 6.2, and time step for simulation is 1 second
PS : i can’t seem to add screenshot, i want to add some to better explain my problem so if there’s any tip i will also take it !
Thanks in advance for your help and tips
