Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS 2D Error
  • #6904
    I have a major problem during a 2D Unsteady Flow simulation.
    The data which I use are the followings:
    -Terrain
    -2DFlowArea
    -Mannings jpeg
    -BC Lines
    -Dam
    In unstedy flow i use precipitation for boundary
    Writing Geometry
    povod?: Mesh property tables are current.
    Completed Writing Geometry
    Geometric Preprocessor HEC-RAS 5.0.4 April 2018
    Finished Processing Geometry
    Starting to copy Geometry Data to Results
    Completed copying Geometry Data to Results
    Performing Unsteady Flow Simulation HEC-RAS 5.0.4 April 2018
    HDF_ERROR trying to use HDF file
    Subroutine READGridGeometry
    #000: ..\..\src\H5D.c line 334 in H5Dopen2(): not found
    Computations Summary
    Completing Geometry(64) 3
    Preprocessing Geometry(64) <1
    Complete Process 3
    major: Dataset
    minor: Object not found
    #001: ..\..\src\H5Gloc.c line 430 in H5G_loc_find(): can't find object
    major: Symbol table
    #002: ..\..\src\H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal failed
    major: Symbol table
    #003: ..\..\src\H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator failed
    major: Symbol table
    minor: Callback failed
    #004: ..\..\src\H5Gloc.c line 385 in H5G_loc_find_cb(): object 'Cells Surface Area' doesn't exist
    major: Symbol table
    Anyone any suggestion?
    #11406
    I need some help regarding adding the precipitation in the HEC-RAS.
    1- What does the actual mean of time series of precipitation? Is it mean the accumulated rainfall?
    for example
    Date Simulation time Precipitation (mm)
    11-01-2019 07:00 00:00 30
    11-01-2019 08:00 01:00 30
    11-01-2019 09:00 02:00 30
    Does it mean the total rainfall added on the 2D flow area during the whole simulation time is 90 mm? Please elaborate?
