Welcome to the RAS Solution Forums HEC-RAS Help HEC RAS 2d BC critical depth
  • #7079
    CanJu
    Hi all,
    I’m about to model a small artificial channel with HEC RAS 2d which also consists of a wire at the end of my model area. Since hec ras does not bring very accurate results with the modeled wire i was thinking to define the outflow BC at the wire and set it to critical depth.
    But now I’ve seen that RAS 2d doesn’t include that option. I’m wondering why?
    Beside that is there anything wrong in setting my outflow BC to critical depth?
    Thanks for any help.
    Cheers
    #11822
    You can do this a couple ways. You can set a normal depth to something artificially high (like 0.5) and the software will treat it as free outfall.
    The other option which is better but more tedious is to draw a 1d storage area at the downstream end of your model and connect it to the edge of your 2D area. Give the storage area an artificially low elevation (if the outfall terrain is at 100-ft put your storage area a bottom elevation of 10-ft) and give it unlimited storage by typing 1000000000 or hold down zero until it stops. Set your connector to the exact elevation of the terrain and change the weir coefficient to 0.2 (VERY IMPORTANT). This also will be treated as free outfall. I notice very odd results if i do not put my 1D storage elevation editor much much lower than the terrain, i usually do 1-200-ft below the terrain at the connection.
    Question: what do you mean a “wire”???
    #11823
    CanJu
    Return-Path:
    by sloti1d2t14 (Cyrus 3.1.5-551-g079e021-fmstable-20181002v2) with LMTPA;
    Fri, 12 Oct 2018 01:55:46 -0400
    X-Cyrus-Session-Id: sloti1d2t14-3149061-1539323746-2-13644677477042061658
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 1.3
    X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
    RCVD_IN_MSPIKE_H2 -0.001, SPF_PASS -0.001, URI_HEX 1.313, LANGUAGES en,
    BAYES_USED none, SA_VERSION 3.4.0
    X-Spam-source: IP=’209.85.167.47′, Host=’mail-lf1-f47.google.com’, Country=’US’,
    by compute1.internal (LMTPProxy); Fri, 12 Oct 2018 01:55:46 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id 84380C6584
    for ; Fri, 12 Oct 2018 01:55:45 -0400 (EDT)
    id 07C6F5E3477;
    ARC-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=fm1; t=
    1539323745; b=qCcsc+4U+xFLdUcp1jn0NM9aPKP6+5UsBWw5SveoCbz1Cnoqh8
    qC1Mjap4Z3pa4CcvwXTh666T8lpRvTYnbG0P3G2cs0sUbg1TpXwWooDrHpPIaz8A
    GfxGcuaKvnu/Op4BEKyspxYtDFjzNlwb1lsYoJTANWD2jGNo86xlNIL5kCO1bGCO
    frcePLj6bQPS26eLqMzg8CbtqC+PBdMWjY/sbzCNpLDBXAW0HwTVl5h5clRZoC+N
    OvBWG6xbUsIoR118Hg8MFGTZ+8O0OYolKGBeTGGWw17ZodG7Dqe8t4xTM/jLFTxH
    dP74WQesPH1mrRYROmyezftQMWHMklmTVjAg==
    :date:message-id:subject:to:content-type; s=fm1; t=1539323745;
    bh=M68hW71u4Ar39fRg8gmr2C4RW5JdddpeLxytMc2BO08=; b=aluvXm4DHJxr
    nFjbcnhhGX7kAd2dotvyVaTjkasA4aiwR+wn4cmGWV53NNiQnJaAlp6XPjAYYS+/
    RDlrqKBqp3Ykl/X+HRNsy0U5nxws1PsMPnoFt6kP5po4Du1AbJUknjjqeXBIURGc
    jKY1s8iRPlO6FTuc+/qTK/kpds/Lzubx4r3rzG1RvMkafF98v9RzHSGtWxEiwDPE
    6TlakFbnZCNSSVDCHWHlJSGnPRj/dF3MrP4Sb/klELyLGy0XaneS/L+xuP6ngBuY
    KykVPonO7jWqEfL8RYzf1IWxIxf6kIEaOvxElyf5B5WvKpFXVMH6EMaTc/TCjunP
    oIXfbqMJOA==
    [email protected] header.b=Ts1mssht header.a=rsa-sha256
    (p=none,sp=quarantine,d=none,d.eval=none) header.from=gmail.com;
    iprev=pass policy.iprev=209.85.167.47 (mail-lf1-f47.google.com);
    spf=pass [email protected]
    smtp.helo=mail-lf1-f47.google.com;
    x-cm=none score=0;
    [email protected] header.b=rGRnejP8;
    x-ptr=pass smtp.helo=mail-lf1-f47.google.com
    policy.ptr=mail-lf1-f47.google.com;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-vs=clean score=0 state=0
    x-cm=none score=0;
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT02
    NDkyJmNvZGU9YW5Wc2FXRXVZMkZ1WTI5c1lVQm5iV0ZwYkM1amIyMThOalE1TW53dE1UQT
    BNVGMyTlRJNU53PT0
    X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedtkedrudelgddutddtucdltddurdegtdejrddttd
    dmucetufdoteggodetrfdotffvucfrrhhofhhilhgvmecuhfgrshhtofgrihhlpdggtfgf
    nhhsuhgsshgtrhhisggvnecuuegrihhlohhuthemuceftddtnecunecujfgurhepgghfjg
    fhfffkuffvtgesrgdtreertddtjeenucfhrhhomheplfhulhhirgcuvegrnhgtohhlrgcu
    oehjuhhlihgrrdgtrghntgholhgrsehgmhgrihhlrdgtohhmqeenucffohhmrghinhepnh
    grsggslhgvrdgtohhmnecukfhppedvtdelrdekhedrudeijedrgeejnecurfgrrhgrmhep
    ihhnvghtpedvtdelrdekhedrudeijedrgeejpdhhvghlohepmhgrihhlqdhlfhduqdhfge
    ejrdhgohhoghhlvgdrtghomhdpmhgrihhlfhhrohhmpeeojhhulhhirgdrtggrnhgtohhl
    rgesghhmrghilhdrtghomhequcfukfgkgfepjeeiieefnecuvehluhhsthgvrhfuihiivg
    eptd
    X-ME-VSCategory: clean
    X-CM-Envelope: MS4wfOCFNdM0JdhwsOuCsCjOYJ/Zh+jkATLJOmrhl4TKaNDbYV09Pw0M7qzsGp0VIDzPT+GVO9B8ZyGvyx/2rtuC/lSYrkJpL1RvNzlMUvJW/wfx5n/Bv1+3
    9kKA7plFjxoPyn8SBt4mdIyqV/o0TisMxvNNIMBaXb7odfliHwI1PHEmroRDwmqTeoTNOTK6zUIsUBopkytiZmUhsk0sDW6yIlsBTj0t0yRYz3PE86Y5Zvba
    X-CM-Analysis: v=2.3 cv=KuKcJleN c=1 sm=1 tr=0 a=OjAXoK3CVIMGaZH8qBVlRA==:117
    a=x7bEGLp0ZPQA:10 a=fFC8T-gT05AA:10 a=smKx5t2vBNcA:10 a=9I5xiGouAAAA:8
    a=8yALVErd97-atHsjddsA:9 a=QEXdDO2ut3YA:10 a=5CR1VMvmZDYA:10
    a=x2G-Z0Q4dF7hsxb_T4MA:9 a=V-XaETMbTM7pbu1C:21 a=ARFN2YZ7Uv8kHtb7LS-q:22
    X-ME-CMScore: 0
    X-ME-CMCategory: none
    Received-SPF: pass
    (gmail.com … _spf.google.com: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:_netblocks.google.com’ matched))
    identity=mailfrom;
    client-ip=209.85.167.47
    Received: from mail-lf1-f47.google.com (mail-lf1-f47.google.com [209.85.167.47])
    for ; Fri, 12 Oct 2018 01:55:44 -0400 (EDT)
    Received: by mail-lf1-f47.google.com with SMTP id m18-v6so8452658lfl.11
    for ; Thu, 11 Oct 2018 22:55:44 -0700 (PDT)
    d=gmail.com; s=20161025;
    b=Ts1msshtA0haEfIzSFRYuopgqCxDL2Nz+XzEAccFb8GfrJeo+x6895Y/Bl/ikBmTtG
    tH8SrTsjf5q98a8EPL8VV0SENSjUxWkP3swWaKcvINS2nOzePkue8D+ijHl7JOt6K1L9
    0sqeYHSXR8NZjGPKWyFFKFTAhwfBdqCo306YrYLAT4IcFgkWw8JugV9gzleJShDUMGOA
    WGtwC4/LfT3I8ULAWRaYVWMVH2y9qdmsgd4P3DTy3IVCkYzASkQrIPrw6JznE4S0dswb
    eJQrPA7AUwK6JE2Rfelv5+nI53eF8yifhm9FEACLdTExnl8x/0CC6AKwUAa0u1Fwui8o
    K0uw==
    d=1e100.net; s=20161025;
    b=rGRnejP8g15+4ZjNiiZ/2J9UIz+vQzbQfB3k53YNL24nXIBz2xlno108G8wyRppF5V
    mYEZsJJUuXjmgWYyJ93htmOCKEG2OV6QyTQHql6FNVcbitJRQc3NIb6UsiGBbJYlEi4+
    6bklKZFk7CKX5t54JL+etOT1gwfWBPfrvZ2GBFfHIBWkx14RVLJqF1HMgDejU5apo++r
    tmepuxoe/EFjgpTwiZXdof4FTVjsxVU4jbRP1EXR+GuCaCu2ZbhyxaFE0kgBwEWfVMYO
    hdj6oz2laWIO090EHArJAROvciRkIo5vChbCN8tPtiTECbJ/RWAaF0HsKnBVneSkm2s/
    UI8w==
    X-Gm-Message-State: ABuFfogAXS7KuWg3Talux5Kdvu/vHMpafkCXhBKIG6nu/WN0jE7jbT2V
    Sd75lug+vcOOFJA0scuH/ur8mTgRp3h98/s4pRHtcA==
    X-Google-Smtp-Source: ACcGV61voBzzSgj48GxEeZgR9CWswETHqIbI/9FMQKWzBLahnBUPWxDldDXAyHORJ2Dl7P8gfdkCIy8gvtwP62B92G0=
    X-Received: by 2002:a19:7510:: with SMTP id y16-v6mr2834409lfe.100.1539323742241;
    Thu, 11 Oct 2018 22:55:42 -0700 (PDT)
    MIME-Version: 1.0
    Date: Fri, 12 Oct 2018 07:55:34 +0200
    Message-ID:
    Subject: Re: HEC RAS 2d BC critical depth
    To: “Luis Partida [via HEC-RAS Help]”
    Content-Type: multipart/alternative; boundary=”000000000000d9c860057801bc09″
    –000000000000d9c860057801bc09
    Sorry WEIR, it should be.
    Thanks a lot for replying.
    On Thu, 11 Oct 2018, 21:30 Luis Partida [via HEC-RAS Help], < [email protected]> wrote:
    > outfall.
    > area at the downstream end of your model and connect it to the edge of yo=
    ur
    > 10-ft) and give it unlimited storage by typing 1000000000 or hold down ze=
    ro
    > and change the weir coefficient to 0.2 (VERY IMPORTANT). This also will b=
    e
    > below:
    > http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-2d-BC-critical-depth-tp=
    6492p6503.html
    > To unsubscribe from HEC RAS 2d BC critical depth, click here
    =3Dunsubscribe_by_code&node=3D6492&code=3DanVsaWEuY2FuY29sYUBnbWFpbC5jb218N=
    jQ5MnwtMTA0MTc2NTI5Nw=3D=3D>
    > NAML
    %3Aemail.naml>
    Sorry WEIR, it should be.=C2=A0
    Thanks a lot for replying.=C2=A0
    On Thu, 11=
    Oct 2018, 21:30 Luis Partida [via HEC-RAS Help], <[email protected]>=
    wrote:
    ex;border-left:1px #ccc solid;padding-left:1ex">
    You can do this a couple ways. You can set a normal depth to something art=
    ificially high (like 0.5) and the software will treat it as free outfall.=
    =20
    The other option which is better but more tedious is to draw a 1d s=
    torage area at the downstream end of your model and connect it to the edge =
    of your 2D area. Give the storage area an artificially low elevation (if th=
    e outfall terrain is at 100-ft =C2=A0put your storage area a bottom elevati=
    on of 10-ft) and give it unlimited storage by typing 1000000000 or hold dow=
    n zero until it stops. Set your connector to the exact elevation of the ter=
    rain and change the weir coefficient to 0.2 (VERY IMPORTANT). This also wil=
    l be treated as free outfall. I notice very odd results if i do not put my =
    1D storage elevation editor much much lower than the terrain, i usually do =
    Question: what do you mean a "wire"???
    =09
    =09
    =09
    http://hec-=
    ras-help.1091112.n5.nabble.com/HEC-RAS-2d-BC-critical-depth-tp6492p6503.htm=
    l
    =09
    To unsubscribe from HEC RAS 2d BC critical depth, click here.<= br>
    NAML
    –000000000000d9c860057801bc09–
