Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC-RAS 2D: 2d results comparison, eg vs dg
- This topic has 3 replies, 466 voices, and was last updated 10 years, 11 months ago by BrianS.
May 7, 2015 at 5:21 am #5790BrianSParticipant
I am using the October release of HEC-RAS 5.0beta.
I have a 2d model built of a 2000′ channel reach contained within a narrow (600′ wide) valley. The entire reach is modeled in 2d for existing and design conditions; 2 separate geometries.
What tools are available in the current release for comparing existing and design results, like those available for 1d geometries? Does HEC have any tools planned to compare results in the future releases?
May 8, 2015 at 11:27 pm #9304cameronParticipantThe best thing you can do currently is export out the results as a raster and do a comparison in another program by subtracting them.
You can also select each element in mapper and get results. Another option would be to use the result data in the hdf file, but it can be confusing if you have not dealt with that format before.
May 11, 2015 at 7:17 am #9305BrianSParticipantReturn-Path:
Received: from portal.pcz.com (portal.pcz.com [50.196.184.249])
by mbob.nabble.com (Postfix) with ESMTP id D95D6CD0057
for; Sun, 10 May 2015 19:18:21 -0700 (PDT)
Received: from EDDY.pci.com ([172.17.2.20]) by EDDY.pci.com ([172.17.2.20])
with mapi; Sun, 10 May 2015 19:18:14 -0700
Date: Sun, 10 May 2015 19:17:03 -0700
Subject: RE: HEC-RAS 2D: 2d results comparison, eg vs dg
Thread-Topic: HEC-RAS 2D: 2d results comparison, eg vs dg
Thread-Index: AdCJvJj1jKFCTZPGTEuje4ccmuqzywB0/jFJ
Message-ID: <[email protected]>
References: <[email protected]>,<[email protected]>
Accept-Language: en-US
Content-Language: en-US
X-MS-Has-Attach:
X-MS-TNEF-Correlator:
acceptlanguage: en-US
MIME-Version: 1.0Thank you Cameron.=20
________________________________________
From: cameron [via HEC-RAS Help] [[email protected]]
Sent: Friday, May 08, 2015 11:27 AM
To: Brian Schlosstein
Subject: Re: HEC-RAS 2D: 2d results comparison, eg vs dgThe best thing you can do currently is export out the results as a raster a=
nd do a comparison in another program by subtracting them.You can also select each element in mapper and get results. Another option=
would be to use the result data in the hdf file, but it can be confusing i=
f you have not dealt with that format before.________________________________
low:
http://hec-ras-help.1091112.n5.nabble.com/HEC-RAS-2D-2d-results-comparison-=
eg-vs-dg-tp1627p1629.html
To unsubscribe from HEC-RAS 2D: 2d results comparison, eg vs dg, click here=
<http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?macro=
=3Dunsubscribe_by_code&node=3D1627&code=3DYnJpYW5AcGN6LmNvbXwxNjI3fDEyMjAwM=
zA1ODg=3D>.
.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
bble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespac=
e-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleName=
space-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.Nabble=
Namespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subsc=
ribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_inst=
ant_email%21nabble%3Aemail.naml>May 15, 2015 at 1:23 am #9306Lonnie AParticipantI found out recently that you can view boundary condition hydrographs in the DSS file (at least in the March version you can). If your downstream is set up with normal depth boundary you should be able to compare the hydrographs and if grid set up properly with cells aligned like you would have XS the cell WSE along the boundary should all be very similar so you can select one cell in rasmapper to view the time series.
