Welcome to the RAS Solution Forums HEC-RAS Help HEC-RAS 1D: Modelling buildings
  • This topic has 2 replies, 385 voices, and was last updated 8 years ago by Anonymous.
  • #6519
    I need to model the flood line of a river in HEC-RAS 1D.
    The flood line is currently going beyond buildings. What is the best way to represent buildings – ineffective area, normal obstruction, a higher Manning coefficient or is there another way of modelling it?
    #10690
    Lonnie A
    It is hard to state which is best not knowing what the overbank looks like. If you think the area with the buildings is going to be just storage and no velocity in floodplain then ineffective would be a good choice. If there are a lot of buildings, enough that you would have difficulty capturing their effect, and you feel there would be velocity in the floodplain I would go with a higher n-values to reflect impact. Now if just a few buildings I would use blocked obstruction. The blocked obstruction will add wetted perimeter for the walls and potentially be more accurate.
    #10691
    Thanks Ronnie
