Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC-HMS to feed into a HEC-RAS model
Hi!
Someone knows a straightforward way (or in any case…a way) to use the output DSS file of a HEC-HMS model to feed into a HEC-RAS model?
I try to avoid mechanic work!
Thank you in advance!
HMS creates a DSS file with the hydrographs. You just select the DSS file as the inflow.
Please enter an answer in digits:
