Welcome to the RAS Solution Forums HEC-RAS Help HEC-GeoRAS to HEC-RAS cross section problem
  • This topic has 14 replies, 2,778 voices, and was last updated 10 years ago by Anonymous.
Viewing 15 posts - 1 through 15 (of 15 total)
  • #5970
    Hi there,
    we are using HEC-GeoRAS and HEC-RAS for a university project. We created all necessary input files in HEC-GeoRAS. Once imported to HEC-RAS there seems to be an issue with the stations along the cross sections. The station numbering is imported as 0 or 0.010. The elevations are correct however the points to draw the cross section plots are on top of eachother.
    https://www.dropbox.com/s/6vufjcrd8q7k7p2/hec_ras3.PNG?dl=0
    Any clues?
    Here is a dropbox folder with the exported files from GeoRAS and two more screenshots.
    https://www.dropbox.com/sh/r13fq0763k1zk7r/AABkm0Fkye-9ZVNIAKit488Qa?dl=0
    Been spending quite some time on this but I haven’t managed to eliminate the problem.
    #9606
    solved the issue by tranforming all data from geographic to projected coordinates….mhh
    my bad
    #9607
    Please tell how did you do that. thanks in advance
    #9608
    jakob.iglhaut
    Return-Path:
    Received: from mail-lf0-f46.google.com (mail-lf0-f46.google.com [209.85.215.46])
    by mbob.nabble.com (Postfix) with ESMTP id 802B52000DA9
    for ; Thu, 4 Feb 2016 06:56:26 -0800 (PST)
    Received: by mail-lf0-f46.google.com with SMTP id l143so37901606lfe.2
    for ; Thu, 04 Feb 2016 07:01:41 -0800 (PST)
    d=gmail.com; s=20120113;
    h=mime-version:in-reply-to:references:date:message-id:subject:from:to
    :content-type;
    bh=j6pRNoZQ/RN9ryXRmjiQUD1mIbZvGfpvrJuSADsNN8A=;
    b=OjWmkakhvSI1eS9gJoR8qtK53+mEceGn8IefeEm6cmC193q36oVWeeVj0ulbvHwPMp
    xahFK4Kujr2FRXq4da92nXCnkRqW+fidMM/bZtreMalQPxL6JyOtXkPFONbTeQhZ76po
    wdlMLb9e26Y6K3ZTiBDAZ5VeAOhSAFHapiZ8XqHGcDmIn9cvyKe9gWiJFePKleG8EC+r
    vLSiFd0ou7CkCmLcKfBEw5QDOSh+ah5CHvRbc3RfKOxO/tIS9eV06XrbK/yPoFRviGnF
    VscEGHd04Ja9BVOeFgs2uPFA5Vnu/MvcofrO60BpdKfP5TXH8CgWcdaMeas0TG0/TFSZ
    mNOA==
    d=1e100.net; s=20130820;
    h=x-gm-message-state:mime-version:in-reply-to:references:date
    :message-id:subject:from:to:content-type;
    b=HOny2RmTycGLLmPx5jXCnK/OCxYV9qaoWPxvHdGjfW9qeiV/8+ubyAEVuvae1tNof1
    PaovUUlGlJMKaBxvOCt6zXGO1gvADvMyvmKtVrQHWvATCJBznlNRoJG/gx2Oz9P+oanq
    7x5CjQXtRq9e2OoxS3J50djjqjPcyHVOTwmJXszUMJmoFx4Kp5AFugMHEDh4AIu0GuvH
    2w9PxhJD4GvxmdWh8BAHBfqJFoVfzVipztOKPSa6yrrW3TEQScPYep2WodQON+hBfeFW
    JIIMH9ip6hNE6EQBxc/7PR1R5HmExajF4rg+RcaZzWpUec/CKkJINqjwBDFT4X2w4WCD
    JD1Q==
    X-Gm-Message-State: AG10YORNPbqindf2j9Zo6TfzfY14NkYz2/UIjyztBC2PnV5HNSIZcDPOcnzD20ACQC/yJYytHopIAQ0VH7AaMg==
    MIME-Version: 1.0
    X-Received: by 10.25.44.205 with SMTP id s196mr3716717lfs.0.1454598094895;
    Thu, 04 Feb 2016 07:01:34 -0800 (PST)
    Received: by 10.25.210.140 with HTTP; Thu, 4 Feb 2016 07:01:34 -0800 (PST)
    <[email protected]>
    <[email protected]>
    Date: Thu, 4 Feb 2016 16:01:34 +0100
    Message-ID:
    Subject: Re: HEC-GeoRAS to HEC-RAS cross section problem
    To: “bahnisikha [via HEC-RAS Help]”
    Content-Type: multipart/alternative; boundary=001a114106d2bcc9a1052af30217
    –001a114106d2bcc9a1052af30217
    Please tell me your problem that you are facing and i might be able to help
    you.
    Am 04.02.2016 15:51 schrieb “bahnisikha [via HEC-RAS Help]” < [email protected]>:
    > below:
    > http://hec-ras-help.1091112.n5.nabble.com/HEC-GeoRAS-to-HEC-RAS-cross-sec=
    tion-problem-tp2240p2288.html
    > To unsubscribe from HEC-GeoRAS to HEC-RAS cross section problem, click
    > here
    =3Dunsubscribe_by_code&node=3D2240&code=3DamFrb2IuaWdsaGF1dEBnbWFpbC5jb218M=
    jI0MHwtNjk2ODQ5NDky>
    > NAML
    %3Aemail.naml>
    Please tell me your problem that you are facing and i might =
    be able to help you.
    Am 04.02.2016 15:51 schrieb "bahnisikha [vi=
    a HEC-RAS Help]" <[email protected]>:
    -left:1px #ccc solid;padding-left:1ex">
    =09
    =09
    =09
    http://hec-ras-=
    help.1091112.n5.nabble.com/HEC-GeoRAS-to-HEC-RAS-cross-section-problem-tp22=
    40p2288.html
    =09
    To unsubscribe from HEC-GeoRAS to HEC-RAS cross section problem, click here.
    NAML
    –001a114106d2bcc9a1052af30217–
    #9609
    I am facing the same problem you had faced before. And want to know how to transform geographic co-ordinates to projected co-ordinate system in arcgis. I have used hecgeoRas and DEM file to extract cross-section data. please help.
    #9610
    jakob.iglhaut
    Return-Path:
    Received: from mail-lb0-f176.google.com (mail-lb0-f176.google.com [209.85.217.176])
    by mwork.nabble.com (Postfix) with ESMTP id C913D11F01331
    for ; Thu, 4 Feb 2016 08:54:40 -0800 (PST)
    Received: by mail-lb0-f176.google.com with SMTP id x4so35570019lbm.0
    for ; Thu, 04 Feb 2016 09:01:13 -0800 (PST)
    h=mime-version:in-reply-to:references:from:date:message-id:subject:to
    :content-type;
    bh=pe4+l4xGPStuWV0VxYSW1yj7WjaAjywSIM4s+qOVjMY=;
    b=0HEEOUt05sNslE6cAya0HDgYQrEE7sEjUrCJyjBGFY3ceDkcQGw8YTdrEkKSkAq2Zj
    7mDQgnJPaEtvt6iufmtMIfA9EkblI6O2Qu2kuXvvhniF1uc4U+rAbYdr5xoP6+8jWw4V
    PISZ3MEhPsiqnuNkMZJQmQ9dKGJC+pchoTLY/O/cZWb/0yYY3TK7OBrC+zRLybnKvQ0V
    ZBXpLtjWb5SKE5lYL7s3Nuct2o8uDWulxC37goNqJnsZpXV/+Mf/lxkaRhZcwqYkb8Ie
    hW3WhFgdEEKIO/P1SwskN7pcFLZHS0WvvNbJYIFqwE+k+yUQu1zxCJZTz0bT77UslWM2
    gm8Q==
    h=x-gm-message-state:mime-version:in-reply-to:references:from:date
    :message-id:subject:to:content-type;
    b=PPKBmf9ErEQUE5W6LgMRCNdQ1v1VzGX6OeDQsZTi2cKrHG210nLGp6ZBAk9Qrb6wst
    itMq4SZnroNzco4xkO8jLGWp49rfoz2Or69rdlt3cVNb5782Yf62K81nkKWJzBmjKoHl
    Uxuz/MWYTuFah+agk8U7fJAY7e3T2CW6qQRgqRmjmyTTmJbTSok0WFl3orfLh/+xwO2e
    LggI1ZtkMQ4FzA1KzJAdI2u3sdSbUsd2XQ4vx4E/Hvewmu4YRbyvzqP29o/Z37TUiwco
    2TiWkF7do/d3k4Jz8icJnxu+H79zFp9t/8dwY+/MirmND/I1KBxgytgzT6pJCl7HrqA7
    YUnw==
    X-Gm-Message-State: AG10YORCZSaTD8c8ivjNENknAwBX+fo5XOHEtvQPyeY0KdHzzyRwQ/stdX5oVRdFqVpXNBaaKzjF3/meIKbp+Q==
    X-Received: by 10.112.200.195 with SMTP id ju3mr3915852lbc.13.1454605266365;
    Thu, 04 Feb 2016 09:01:06 -0800 (PST)
    MIME-Version: 1.0
    Received: by 10.25.210.140 with HTTP; Thu, 4 Feb 2016 09:00:46 -0800 (PST)
    <[email protected]>
    <[email protected]>
    Date: Thu, 4 Feb 2016 18:00:46 +0100
    Message-ID:
    Content-Type: multipart/alternative; boundary=001a11c38d5230b6bc052af4aeee
    –001a11c38d5230b6bc052af4aeee
    That you can do by projecting the data in ArcGIS. Use the “project” tool
    from the Data Management Tools.
    Cheers
    2016-02-04 17:53 GMT+01:00 bahnisikha [via HEC-RAS Help] < [email protected]>:
    > I am facing the same problem you had faced before. And want to know how t=
    o
    > please help.
    > below:
    tion-problem-tp2240p2290.html
    > here
    > NAML
    %3Aemail.naml>
    That you can do by projecting the data in ArcGIS. Use the =
    "project" tool from the Data Management Tools.
    Cheers
    2016-02-04 17=
    :53 GMT+01:00 bahnisikha [via HEC-RAS Help] <ml-nod=
    [email protected]>
    ail_quote" style=3D"margin:0 0 0 .8ex;border-left:1px #ccc solid;padding-le= ft:1ex">
    I am facing the same problem you had faced before. And want to know how to=
    transform geographic co-ordinates to projected co-ordinate system in arcgi=
    s. I have used hecgeoRas and DEM file to extract cross-section data. please=
    help.
    =09
    =09
    =09
    http://h=
    ec-ras-help.1091112.n5.nabble.com/HEC-GeoRAS-to-HEC-RAS-cross-section-probl=
    em-tp2240p2290.html
    =09
    NAML
    –001a11c38d5230b6bc052af4aeee–
    #9611
    Thanks a lot for your patience. Could you also tell me at what point of execution should i transform the projection, that is after creating attributes in hecgeoras or before that? This action can be performed on what type of files?
    #9612
    jakob.iglhaut
    Return-Path:
    Received: from mail-lf0-f43.google.com (mail-lf0-f43.google.com [209.85.215.43])
    by mwork.nabble.com (Postfix) with ESMTP id 5174B11F4E49B
    for ; Thu, 4 Feb 2016 10:29:01 -0800 (PST)
    Received: by mail-lf0-f43.google.com with SMTP id 78so42184827lfy.3
    for ; Thu, 04 Feb 2016 10:35:34 -0800 (PST)
    :content-type;
    bh=UwO1N9MZf0UhRX5/9vUBfvPt6RRZRZK4NWGk3duAqPA=;
    b=T0zgVxn8i+4IMwoFDc6mYzzJgaQ/9F7L3cqLsUrXC8VVLlGX6/2VV8kbMpS4UlyVko
    +MfpejPey0gOGVLufhgJnxLrw9V+PL5dggFjyI2qL7ORjMRw3O4X+YXKbrpjchEJgGcQ
    ooGTm1V0cl6R0qSfIP4hdLLxIfU8ia4TbVIE3/wGakZwWn0vPb9hGid1dXw5GoMiKtVZ
    XqChgks9NfufVGhpsLt3n7dVPn7cI0HeskG1I188lOPuex+/G8FZsP7oDZp9olTCTfT1
    TcJBXX78HBvJ4+3IWYNWFm/Bw1BDcS9GorK43Qu/B2BrpqquVXPhrCUapkQYU9TNCZq5
    Z5GA==
    b=UFqAzS4d6erQH3X263m6ZGLdGORdkGBfsac5kS7Idq2rkd7Chka5ZpMnLRbONauQST
    I+Wiw/5MFJ59ZkMw85D903w10WKSAX7t4jTFXHieiWn/OPoZuXQkcIzgvt9siAjXX5iw
    UX2bxe+qRSdlS+99uY98Yh6G8w2jB9WWc0lvYiYib1PkwNf1EV+glA+nQfJeMpMFFHZY
    w+w2Cm/2/s/w6bWo9qHgA052j0CR024eN9Hhcf5QoXoDD5SL7StEyOv8doK/2yV/T7zU
    wx41HL375pV78XNKPDYhQBZKlGrspH3sxXMv6ivvUZVm1DK2L88Lo4peiu8gDLjIRk/y
    u1Mw==
    X-Gm-Message-State: AG10YOShRr/RMkFNqLDq/0nNsEGQy/dID10DhBJHsz8EYPLKGpy/Q5Ux0C2q8htE92Fw9wFhE+ifnCs0C90zYg==
    X-Received: by 10.25.87.134 with SMTP id l128mr3441506lfb.121.1454610927069;
    Thu, 04 Feb 2016 10:35:27 -0800 (PST)
    MIME-Version: 1.0
    Received: by 10.25.210.140 with HTTP; Thu, 4 Feb 2016 10:35:07 -0800 (PST)
    <[email protected]>
    <[email protected]>
    <[email protected]>
    Date: Thu, 4 Feb 2016 19:35:07 +0100
    Message-ID:
    Content-Type: multipart/alternative; boundary=001a11418da8983233052af5ff43
    –001a11418da8983233052af5ff43
    You should perform the projection at the very beginning. Once you have all
    your input data that you want to be working with (point, lines, polygons,
    raster (DEM)) you project it before you touch any HEC-GeoRAS tools.
    2016-02-04 19:23 GMT+01:00 bahnisikha [via HEC-RAS Help] < [email protected]>:
    > what type of files?
    > below:
    tion-problem-tp2240p2292.html
    > here
    > NAML
    %3Aemail.naml>
    You should perform the projection at the very beginning. O=
    nce you have all your input data that you want to be working with (point, l=
    ines, polygons, raster (DEM)) you project it before you touch any HEC-GeoRA=
    S tools.=C2=A0
    2016-02-04 19:23 GMT+01:00 bahnisikha [via HEC-RAS Help] <[email protected]>:
    Thanks a lot for your patience. Could you also tell me at what point of ex=
    ecution should i transform the projection, that is after creating attribute=
    s in hecgeoras or before that? This action can be performed on what type of=
    files?
    =09
    =09
    =09
    http://h=
    em-tp2240p2292.html
    =09
    NAML
    –001a11418da8983233052af5ff43–
    #9613
    Sorry to bother again. But, could you also tell me what data are you using in HECgeoras? I am using toposheets which I have georeferenced in the relevant projected co-ordinate system and DEM to digitize river features. And now, i get the error message that river node lies outside terrain! thanks, in advance.
    #9614
    jakob.iglhaut
    Return-Path:
    Received: from mail-lb0-f178.google.com (mail-lb0-f178.google.com [209.85.217.178])
    by mbob.nabble.com (Postfix) with ESMTP id C0DC7201C609
    for ; Fri, 5 Feb 2016 11:00:22 -0800 (PST)
    Received: by mail-lb0-f178.google.com with SMTP id cw1so54880391lbb.1
    for ; Fri, 05 Feb 2016 11:05:45 -0800 (PST)
    :content-type;
    bh=rELi9miyJgNlIYl7zIfaH3T2gqOzd9l2QeiEDP3tc7A=;
    b=a3EIsb6hz8YGR6aww40Ok4ey5PoDOr30/mY5CAGjLCfIoCD2BYwHyrXblLkGHZJWJt
    1z4WgLdvFs/KSZNC3y7wS1fJOdal633N59W4XqApO8gBbhrrrnTiKcGX+HD33tVnCGh8
    VqvyCONRH1T8ZjvZFHrMv/CBwtSehOYOuJsTxvN7unqaZGwnXQNbKvUNFh23WbBsWeeY
    iMGwcCiPSGaUC1V7d7MD1zYLHEAdxyJY9ybB9IXdWjm3AYUvZTxtey734MdYBoUM2BFO
    QywY37KG6Y3BJSCfXpOtW/llM3h0mQ/z/1jAgHhGO8goIK3KglMwn5IqFagE/ThufQt2
    NHZg==
    b=NYac5+G1hVCNQacuX0yWLjM1CnZfcFG330aXliw2KU1V2+D2A45+1FhUCDax3ThS2w
    u8hy75ItJejy8oUjfKn1yBHbUO2pmvlA3FyPikW7Olg3FTZvBFiz3PcvDHzq3Ds56acy
    aj2uZXoSYTgRPoeVPK/2iHvKrQJ9EeEI6+2khg1khQ5FyBc2C16t+zljq6nTTpXueuDa
    QEc6N2/po7XUL4louLyaFokCyeMjOXHU8hLeGltp0Cg92lHqzj/a8nTPFM9nBuyzJzmV
    T3mgkj1UZLZczfv/KrOnn9o9/ILggkWJISiAtzMwSJdD0ewwAJ43RuXP5MSYSpHDBwCM
    E0gw==
    X-Gm-Message-State: AG10YOTJ3P+W+YJ8NKktN68vh2gSsgxGaoxPhjKl5j8SI+5tkjMHOktQHrYbP4iH7Od0idsynz25ufNksHY1PA==
    X-Received: by 10.112.126.72 with SMTP id mw8mr6753801lbb.14.1454699144570;
    Fri, 05 Feb 2016 11:05:44 -0800 (PST)
    MIME-Version: 1.0
    Received: by 10.25.210.140 with HTTP; Fri, 5 Feb 2016 11:05:25 -0800 (PST)
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    Date: Fri, 5 Feb 2016 20:05:25 +0100
    Message-ID:
    Content-Type: multipart/alternative; boundary=001a11c37656c46e47052b0a8998
    –001a11c37656c46e47052b0a8998
    Your river line feature must fully lie within the DEM terrain tile.
    If you google the problem you will see you are not the first one facing it
    and there are some solutions to be found 😉 e.g.
    https://geonet.esri.com/thread/42371
    2016-02-05 19:56 GMT+01:00 bahnisikha [via HEC-RAS Help] < [email protected]>:
    > Sorry to bother again. But, could you also tell me what data are you usin=
    g
    > thanks, in advance.
    > below:
    tion-problem-tp2240p2295.html
    > here
    > NAML
    ace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNa=
    mespace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.Nabb=
    leNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_sub=
    scribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_in=
    stant_email%21nabble%3Aemail.naml>
    Your river line feature must fully lie within the DEM terr=
    ain tile.
    If you google the problem you will see you are not the first =
    one facing it and there are some solutions to be found 😉 e.g.=C2=A0https://geonet.esri.com/thread/42=
    371
    2016-02-05 19:56 GMT+01:00 bahnisikha [via HEC-RAS Help] <[email protected]>:
    Sorry to bother again. But, could you also tell me what data are you using=
    in HECgeoras? I am using toposheets which I have georeferenced in the rele=
    vant projected co-ordinate system and DEM to digitize river features. And n=
    ow, i get the error message that river node lies outside terrain! thanks, i=
    n advance.
    =09
    =09
    =09
    http://h=
    em-tp2240p2295.html
    =09
    NAML
    –001a11c37656c46e47052b0a8998–
    #9615
    suggestions given by you was very useful for my project.But i had a problem in it, initially i converted the coordinate system of all layers to projected coordinate system and we can’t convert the coordinate system of basemap to projected coordinate system.so the error ” river node lies outside the terrain” occurs.how to resolve it…thanks in advance!
    #9616
    Mafuzur
    I have the same problem. Have you solved this?
    #9617
    jakob.iglhaut
    Return-Path:
    by sloti25t09 (Cyrus fastmail-fmjessie45596-15566-git-fastmail-15566) with LMTPA;
    Tue, 24 Oct 2017 16:51:32 -0400
    X-Cyrus-Session-Id: sloti25t09-2053761-1508878292-2-8453307326987264097
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 0.0
    X-Spam-hits: BAYES_00 -1.9, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001,
    RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H3 -0.01,
    RCVD_IN_MSPIKE_WL -0.01, RCVD_IN_SORBS_SPAM 0.5, SPF_PASS -0.001,
    URI_HEX 1.122, LANGUAGES en, BAYES_USED global, SA_VERSION 3.4.0
    X-Spam-source: IP=’209.85.215.52′, Host=’mail-lf0-f52.google.com’, Country=’US’,
    by compute1.internal (LMTPProxy); Tue, 24 Oct 2017 16:51:32 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id 8C4C6C848E
    for ; Tue, 24 Oct 2017 16:51:31 -0400 (EDT)
    id 1D041F7BEDD;
    ARC-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=arctest;
    t=1508878291; b=atkz3e80l5PNDMOiPwkw0ThzrxBBX/8Ira0e20jUkeI9Y0v
    4LHMJ1xnxgQiQOXVNvDJDKHQ4U8lU6pCArnrQhPek3Itn+4mr82dQ8yXRqVIH9rO
    Xj+GcYCKoZxMpavmLEPwEWqT0zrZ4wyIT2kFm5W9RyDG+YlX5ZNjFsQ/SWwD69UN
    9kBGRULIP1a3nO+sCMCcf1f4bkk/ea51rjmculWMjtVbS9ZJECxfdyHQP+A5Qb5j
    Il0TGYkoMIVtNSyRdVY5rOWBaByt/prs6vpUK8AbWJbUQXi3TIgMYdd2JsGr5IKV
    P6JlFfGsLEr1pZzWx5Zzx+C+uTeaE9uQkdQoAgg==
    messagingengine.com; h=mime-version:in-reply-to:references:from
    :date:message-id:subject:to:content-type; s=arctest; t=
    1508878291; bh=A7yho6DepgPi1k9S2edvsK7eYPOwY/lxcROJdANXwdY=; b=p
    A6+5lQqz1kHE6SYh7WtMve8SG8qWERDBRy5ODS4iSnhisXpOipYs6Sd1IT/2rifJ
    dpH+S95YakpPUhDu01yMnu+xh2BY8r+y9Lkk72aBLP7pjwxzSXTX/IyCJQs3+OiF
    NEw4hJRXgGeizdPi+SiS3a1jo/nsAiWsFogdDDNHnN4JppbYjT84khs25B6OKL19
    P+z95kLSM3S/fjMWftJS97+u8FND3Itg3JJS0q78SubDR/Rk+zw8H3un4e7fzccD
    nkhx1zMxt/2qgL24HhJymsgm8DQAdrs3k7lJSVCK0umKN/w2M/rih1f8hJNrJSXf
    fN0WJZTeT3brIgLGttIUQ==
    ARC-Authentication-Results: i=1; mx4.messagingengine.com;
    arc=none (no signatures found);
    dkim=pass (2048-bit rsa key sha256) header.d=gmail.com [email protected] header.b=e4AFJr4F;
    dmarc=pass header.from=gmail.com;
    iprev=pass policy.iprev=209.85.215.52 (mail-lf0-f52.google.com);
    spf=pass [email protected] smtp.helo=mail-lf0-f52.google.com;
    x-aligned-from=pass;
    x-google-dkim=pass (2048-bit rsa key) header.d=1e100.net [email protected] header.b=kzDUz4Ss;
    x-ptr=pass x-ptr-helo=mail-lf0-f52.google.com x-ptr-lookup=mail-lf0-f52.google.com;
    x-return-mx=pass smtp.domain=gmail.com smtp.result=pass smtp_is_org_domain=yes header.domain=gmail.com header.result=pass header_is_org_domain=yes;
    x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128
    Received-SPF: pass
    (gmail.com … _spf.google.com: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:_netblocks.google.com’ matched))
    identity=mailfrom;
    client-ip=209.85.215.52
    Received: from mail-lf0-f52.google.com (mail-lf0-f52.google.com [209.85.215.52])
    Received: by mail-lf0-f52.google.com with SMTP id r129so25502740lff.8
    for ; Tue, 24 Oct 2017 13:51:30 -0700 (PDT)
    d=gmail.com; s=20161025;
    h=mime-version:in-reply-to:references:from:date:message-id:subject:to;
    b=e4AFJr4FW92aMJjtbs1JJ8dCS7LMOdPLOpOhJESeARFNyCAeBwlK6Q1WoOC1L8mKOI
    H3PpbJ7BMpXC67xyZhkPnd/NbjVXAgwu8bCela8uNr52SI8aUKKpVJ6RErR8PYSsbu+8
    //l5LhfXTKUkfAYSmh93yTri9Q5906v4avkM42EnxUclvvttTH/662I0hmlYsKyhyh6y
    viWiuXB1i0uEIvCdHMJDltMzg+bI7ptMlBOUc2QXIptyeqqFGqj1qDIb2HA/gk4y5iyh
    ijbbzHQcROK64cocd+w64HO54pjJxxxB5vZByHAAIT0XXypFnqseSH34bQ+PIPpOO6yf
    8xYA==
    d=1e100.net; s=20161025;
    b=kzDUz4SsrFo2EgGClDlicgxy8VAlUQ5bJv2lghu9bG/WJA9Lmc2qJXy2AHwStsJjdV
    g7EPx9Ah38NbNSJbon55gZ2cgqc9XR7GX+tw46jxw8MjBaPvdfmd+tyQTeJxReF6TKxh
    k0m8PbuV6IIyirvgx95uQDA4HsMlfv9nDQs9slCFpYk9brOV20Rm5kj8lLsz0xTN1sku
    vBSM64C/wri4RE4S9v4vNlZw8gG4WNkdsG0jQhl6y+4hSS9B7R1DzPpenr8r+/u2/mpw
    pvErOCBrdUKnlDlOP6E+kAmFQdg0li6wrqA7/qm2EoIKb9DPo6nsHE7hv6ZlyPiqSAle
    DmfA==
    X-Gm-Message-State: AMCzsaXBOX9j2y0uD64ILV2flz2Bga2LcbJ2Ve6ptZoyHh+pfjUPXsn4
    lEeF72/8xaGgcQ5XTtrFD+UkMUA/VSaBfnpz2n8=
    X-Google-Smtp-Source: ABhQp+TiM6JLmOOqbqIEm8EhBoJXDah6GHIRR6NuFli/PcI7WtwFKprbdYa/lwpQFBJqDrmE/bUrrBogkpgBdXIkM8M=
    X-Received: by 10.46.32.150 with SMTP id g22mr7518332lji.62.1508878288447;
    Tue, 24 Oct 2017 13:51:28 -0700 (PDT)
    MIME-Version: 1.0
    Received: by 10.179.79.153 with HTTP; Tue, 24 Oct 2017 13:51:27 -0700 (PDT)
    <[email protected]>
    <[email protected]>
    <[email protected]>
    Date: Tue, 24 Oct 2017 21:51:27 +0100
    Message-ID:
    To: “Mafuzur [via HEC-RAS Help]”
    Content-Type: multipart/alternative; boundary=”001a114309a8646cc5055c511aff”
    –001a114309a8646cc5055c511aff
    Yes. All your layers have to be in a projected coordinate system.
    On 24 Oct 2017 21:50, “Mafuzur [via HEC-RAS Help]” < [email protected]> wrote:
    > below:
    > HEC-RAS-cross-section-problem-tp2240p4670.html
    > here
    > NAML
    %3Aemail.naml>
    Yes. All your layers have to be in a projected coordinate=
    system.
    On =
    24 Oct 2017 21:50, "Mafuzur [via HEC-RAS Help]" <[email protected]> wrote:
    le=3D"margin:0 0 0 .8ex;border-left:1px #ccc solid;padding-left:1ex">
    =09
    =09
    =09
    http://hec-ras-=
    help.1091112.n5.nabble.com/HEC-GeoRAS-to-HEC-RAS-cross-section-pr=
    =09
    NAML
    –001a114309a8646cc5055c511aff–
    #9618
    Ituadi
    I faced same prob that you mention above..nd as you told i channge my al data in projected coodination but when i export data from hecgeoras to hecras ,which data it will taken i don’t know..so in hecras croseection part ,station values came 0 and 0.133.plz help sir..thanks in advance
    #9619
    Do the cross-sections look like they came in the correct coordinate system? You could check this in the geometry editor or mapper and see if the coordinates match what you had in GIS.
    What is the projection of the 3D XS Cutlines in GIS? Is it in the correct projection?
    Have you tried just creating the model in Mapper?
