Welcome to the RAS Solution Forums HEC-RAS Help HEC-GeoRAS Export RAS Data – empty message window
  • This topic has 0 replies, 219 voices, and was last updated 9 years ago by Anonymous.
  • #6376
    I just start working with HEC-RAS and I’ve got problem with export my ESRI files to RAS. I do complete pre-processing in ArcMAP 10.2.2. (I use HEC-GeoRAS 5.0.3) and everything was great until I have to Export GIS data to RAS: Export RAS Data. When I click OK ExportRASData window is empty like below:
    https://drive.google.com/file/d/0B3PqRv0QA38eVjlVQUVLSHpVMG8/view?usp=sharing
    Due to I can’t continue work in HEC RAS, because I have no files to import.
    Before, I pre-processed data by tutorials on youtube and paper tutorials and I have got the same problem on the same step. When I check data in attribute tables in feature classes according requires in tutorials for me everything is fine.
    Have You got any advices where is the problem or what where I do mistake?
    More screens from my project:
    XSCutLines3D
    https://drive.google.com/file/d/0B3PqRv0QA38ed181U0FEaTBzS0E/view?usp=sharing
    https://drive.google.com/file/d/0B3PqRv0QA38eOXVkUWlEN254TEE/view?usp=sharing
    (I know that it it should be drawn more precisely, but I did it so many times and never work, so now I just want do achieve correct export.)
    Regards,
    Marta
