Welcome to the RAS Solution › Forums › HEC-RAS Help › HEC 4.0 model for irrigation scheme
- This topic has 18 replies, 870 voices, and was last updated 10 years, 9 months ago by Anonymous.
June 17, 2015 at 9:58 pm #5819AnonymousGuest
Hi everyone. I was wondering if HEC could be used to study an irrigation scheme, composed by a dendritic layout of a few canals, connected by flap gates. The inlets of the irrigation scheme also depend on the tide in the river, so there are also a few inlets with tide/flap gates.
I would like to develop just a easy model, where I could enter the boundary conditions (levels upstream of the flap gates which are the inlets of the system), and also the outflows for irrigation.
It is possible to develop such a model in HEC RAS?
Thank you very much
June 18, 2015 at 3:06 am #9357Lonnie AParticipantUse unsteady and should have no issues doing this.
June 18, 2015 at 7:58 am #9358Chris G.KeymasterReturn-Path:
Received: from mail-pa0-f46.google.com (mail-pa0-f46.google.com [209.85.220.46])
by mwork.nabble.com (Postfix) with ESMTP id D02522130690
for; Wed, 17 Jun 2015 19:58:55 -0700 (PDT)
Received: by pacyx8 with SMTP id yx8so50474206pac.2
for; Wed, 17 Jun 2015 19:58:48 -0700 (PDT)
d=gmail.com; s=20120113;
bh=I+6pk4kbVquA9eTfctaDLGaND3WPsIpOyhCnZMSanvE=;
b=lhRl/Fi7qJPdBtpM/ll0CBdBGVC12PQPi6oncxp34S4Hi1mRD5HrMt7WhdD/dvg/Rq
T7MPa1ZjPmOKRXiUPHj+6sz3q7ZlKdVuQgv4y7NJz+S75IgHNXWeV7I2NE9fhYX+bdqz
wxfgQghJrALL64IDWZmLWqxbbjjqRNs6Jq77jmysqCBS6wlsiJhPd3eno5Ha8u0UIeTH
m7fL48oKLRD28atxuQbLjQ8yGklc+BCVToCEpBhUjWH3l1go7d7+upSb+NhY79W7hjry
b3d8M3ozqEHSmw8x06juUMwi65lw21Loqa72dnBP+0KUMIdRl+JIs4bQO/5RVB85OD6K
4lkg==
X-Received: by 10.70.42.101 with SMTP id n5mr16965051pdl.93.1434596328410;
Received: from ?IPv6:2600:100f:b113:5bd8:d8f8:b9ce:d8b4:c137? ([2600:100f:b113:5bd8:d8f8:b9ce:d8b4:c137])
by mx.google.com with ESMTPSA id r4sm6228479pap.8.2015.06.17.19.58.46
for
Wed, 17 Jun 2015 19:58:47 -0700 (PDT)
Subject: Re: HEC 4.0 model for irrigation scheme
boundary=Apple-Mail-3E9578F0-35AB-4CA8-8B18-13F31AD1EB4D
X-Mailer: iPhone Mail (12D508)
Date: Wed, 17 Jun 2015 19:58:44 -0700
To: “John Clark [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-3E9578F0-35AB-4CA8-8B18-13F31AD1EB4D
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableDefinitely. I’ve done it myself a number of times.=20
Sent from my iPhone
> On Jun 17, 2015, at 9:58 AM, John Clark [via HEC-RAS Help]
wrote:
>=20
> Hi everyone. I was wondering if HEC could be used to study an irrigation s=
cheme, composed by a dendritic layout of a few canals, connected by flap gat=
es. The inlets of the irrigation scheme also depend on the tide in the river=
, so there are also a few inlets with tide/flap gates.=20
>=20
> I would like to develop just a easy model, where I could enter the boundar=
y conditions (levels upstream of the flap gates which are the inlets of the s=
ystem), and also the outflows for irrigation.=20
>=20
> It is possible to develop such a model in HEC RAS?=20
>=20
> Thank you very much=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/HEC-4-0-model-for-irrigation-sch=
eme-tp1738.html
> NAML–Apple-Mail-3E9578F0-35AB-4CA8-8B18-13F31AD1EB4D
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitDefinitely. I’ve done it myself a number of times.Sent from my iPhoneOn Jun 17, 2015, at 9:58 AM, John Clark [via HEC-RAS Help] <[email protected]> wrote:Hi everyone. I was wondering if HEC could be used to study an irrigation scheme, composed by a dendritic layout of a few canals, connected by flap gates. The inlets of the irrigation scheme also depend on the tide in the river, so there are also a few inlets with tide/flap gates.
Thank you very much
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/HEC-4-0-model-for-irrigation-scheme-tp1738.html
NAML
–Apple-Mail-3E9578F0-35AB-4CA8-8B18-13F31AD1EB4D–June 18, 2015 at 2:15 pm #9359AnonymousGuestOh great! Thank you both Lonnie and Chris for your responses.
Actually I will try to develop the model in HEC-RAS running with conditions introduced by used in EXCEL (like the initial level at the irrigation canals, the tide level at the inlet, among others). That it is possible right?
Another question that I have is:
In order to control the total inflow volume entering the main irrigation canal (from the tide gates) for a certain time interval the better/easiest way to do it is to create a storage area (representing the river) connected with the main irrigation canal by a tide gate right?
June 22, 2015 at 7:15 pm #9360AnonymousGuestHi everyone.
I would like to simulate a flap gate between 2 river reaches.
I tried a lateral structure with a diversion rating curve, but how can I define the relation between the levels of the 2 river reaches?
June 22, 2015 at 9:25 pm #9361AnonymousGuestAssuming that both sides of the weir are modeled, RAS will recognize the differential between the water surface elevations and (based on the lateral weir characteristics) compute the flow at any time over the weir. The direction of flow is based on which side has the higher water surface. The lateral structure can either connect to a storage area or another reach.
June 22, 2015 at 10:20 pm #9362AnonymousGuestActually I am trying to simulate a tide gate (with only 1 direction) connecting one inlet channel to the main channel. It is possible to do that with a diversion RC? Or should I specify the culvert characteristics?
And what boundary condition should I have in the last section of the inlet channel. It should work like a reservoir.
June 22, 2015 at 11:45 pm #9363AnonymousGuestLateral structures can contain culverts that have flap gates. You can find the data entry from: Geometric Data > Lateral Structures > All culverts. Under the culvert description there is an entry for the type of gate. Under flap gates, the direction of flow can be chosen.
Hope this helps,
MichaelJune 23, 2015 at 2:29 pm #9364AnonymousGuestThank you very much.
What is the best DS boundary condition for the channel act as a “reservoir” i.e., with no flow leaving the DS cross section. When the flap gate is closed, the level in the channel should rise until the level is high enough to open the flap gate.
I tried Rating curve with 2 values near 0 but it is impossible.
June 23, 2015 at 8:21 pm #9365AnonymousGuestIf the downstream area is not a RAS reach or storage area; suggest that you use a stage hydrograph for the D/S BC. Commonly use this for situations that have tidal or reservoir connections downstream. For these applications, the D/S connecting cross section should be large enough so that the velocity head is negligible.
MichaelJune 23, 2015 at 10:48 pm #9366AnonymousGuestActually it will connect with the main reach, but as I am using a lateral structure as a flap gate, I need some DS boundary condition for the last section.
However, I think stage hydrograph is not aplicable because the level in the reach may depend only the inflow (given by the tidal level upstream) and the outflow from the lateral flap gate. Am I correct?
This stream acts like a reservoir in order to provide inflow for other channel by a flap gate. I hope that my explication is clear enought.
June 24, 2015 at 7:49 pm #9367AnonymousGuestA schematic of your system would be useful to look at to figure out what BC’s are appropriate.
MichaelJune 25, 2015 at 2:47 pm #9368John ClarkParticipantHi Michael. You are right a schematic overview always help!
In my simulation, the inlet channel is not connect with the main channel (as you can see by the image cross section 1 is the last cross section). In cross section 1 I have a BC of a rating curve with almost zero flow, in order to avoid the inlet channel to lose water when both tidal gates are closed.
In my simulation the tidal gate 1 is simulated as a lateral structure flag gate avoiding negative flow (from main channel to the inlet channel). I have not yet the tidal gate 2. I would like to set the levels in the river as a time series. It is possible to do with a storage area? And then connect with a flap gate to the first cross section of the inlet channel?
Sorry for all my questions and long post
Thank you very much for your help.
June 25, 2015 at 8:05 pm #9369AnonymousGuestI would model this situation by connecting the inlet channel to the main channel. A couple of cross sections would be needed between the flap gate and the main channel. Those sections should be large enough that the velocity is negilible.
If you want to model the main channel as a storage area, the inlet channel still needs to be connected to it. Think that you can prescribe a stage time history for a storage area in RAS.Michael
June 26, 2015 at 11:52 am #9370John ClarkParticipantSorry I did not get it. If I connect the inlet channel with the main channel, there will be 2 “connections” between the 2 channels (the flap gate and the junction).
How can I avoid flow leaving the main channel into the inlet channel through the junction, even with a very wide cross section?
Actually I want to model the inlet channel as reservoir (storage area).I did not find a boundary condition for the time series level for a storage area.
