Welcome to the RAS Solution Forums HEC-RAS Help HEC-2 to HEC-RAS
  • This topic has 3 replies, 381 voices, and was last updated 8 years ago by Anonymous.
  • #6827
    I obtained a .pdf image from FEMA of a HEC-2 model. I was able to convert the pdf to a text pdf using OCR pages. Does anyone know how to import this into HEC-RAS?
    #11273
    Converting a HEC-2 model to RAS can be a little bit of work, but you can usually at least import the geometry data.
    From the Geometric editor, go to File > Import Geometry data.
    #11274
    Julia P
    What is the proper format for importing a .txt file?
    #11275
    The .txt file is in a HEC-2 format? Does the import geometry not let you select it? If it doesn’t, I guess you could try changing the extension to .dat and see if that makes a difference.
