Welcome to the RAS Solution Forums HEC-RAS Help HEC-2 to HEC-RAS
  • This topic has 2 replies, 260 voices, and was last updated 10 years ago by Anonymous.
  • #5909
    I currently have to build a hydraulic model from past hec 2 records. Does anyone know where to find the guidelines for creating an effective model are located? I dont want to rebuild the entire stream just a portion of it and calibrate it using WSELs as boundary conditions
    #9530
    I do not know about any guidelines. But you can save a lot of effort by going to the Geomectric Editor>File and select Import data to bring in the HEC 2 cross sections.
    #9531
    THe hec-2 file that fema had on record was only PDF…this is going to be a headache
