Welcome to the RAS Solution › Forums › HEC-RAS Help › HDF_ERROR trying to use HDF output file
  • #7573
    Good morning, I’m currently receiving an error message in HEC-RAS after running a steady flow analysis and I would like to know if anyone knows how to resolve this issue.
    The error message that I’m receiving is listed below.
    Steady Flow Simulation HEC-RAS 5.0.7 March 2019
    Subroutine HDF_ATTRI_SCALAR_CH
    Computations Summary
    Completing Geometry(64) <1
    Steady Flow Computations(64) <1
    Complete Process <1
    #000: ..\..\src\H5D.c line 170 in H5Dcreate2(): unable to create dataset
    major: Dataset
    #001: ..\..\src\H5Dint.c line 439 in H5D__create_named(): unable to create and link to dataset
    major: Dataset
    #002: ..\..\src\H5L.c line 1638 in H5L_link_object(): unable to create new link to object
    major: Links
    #003: ..\..\src\H5L.c line 1882 in H5L_create_real(): can't insert link
    major: Symbol table
    #004: ..\..\src\H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal failed
    major: Symbol table
    minor: Object not found
    #005: ..\..\src\H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator failed
    major: Symbol table
    minor: Callback failed
    #006: ..\..\src\H5L.c line 1685 in H5L_link_cb(): unable to create object
    major: Object header
    #007: ..\..\src\H5O.c line 3015 in H5O_obj_create(): unable to open object
    minor: Can't open object
    #008: ..\..\src\H5Doh.c line 293 in H5O__dset_create(): unable to create dataset
    major: Dataset
    #009: ..\..\src\H5Dint.c line 1044 in H5D__create(): unable to construct layout information
    major: Dataset
    #010: ..\..\src\H5Dchunk.c line 551 in H5D__chunk_construct(): chunk size must be < 4GB major: Dataset minor: Unable to initialize object HDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0: #000: ..\..\src\H5A.c line 242 in H5Acreate2(): not a location major: Invalid arguments to routine minor: Inappropriate type #001: ..\..\src\H5Gloc.c line 253 in H5G_loc(): invalid object ID major: Invalid arguments to routine minor: Bad value
    #12686
    are you running the model on the network or local machine? Try deleting the hdf file and then running again.
    #12687
    lucyiow
    Hi there did you ever solve this? I have the same problem!
