Welcome to the RAS Solution Forums HEC-RAS Help HDF_ERROR trying to use HDF output file
  • This topic has 1 reply, 676 voices, and was last updated 8 years ago by Anonymous.
  • #6769
    I saw this message from computation window although I download hdf5:
    Sediment Transport Analysis HEC-RAS 5.0.3 September 2016
    Subroutine HDF_SET_COMPRESSION
    Computations Summary
    Completing Geometry <1
    Sediment Computations(64) <1
    Complete Process <1
    #000: ..\..\src\H5Pdcpl.c line 869 in H5Pset_chunk(): all chunk dimensions must be less than 2^32
    minor: Out of range
    #11172
    I have the same problem right now. Have you solved the problem? Thank you in advance
