Welcome to the RAS Solution Forums HECRAS Controller HDF5-DIAG error HEC RAS
  • This topic has 2 replies, 1 voice, and was last updated 1 year ago by Sabin.
  • #8256
    Ilariusmarc
    HI good evening to everybody. I am a young engineer, who has coped with an error concerning the unsteady flow analysis run. Actually, I am not able to figure out what went wrong during the run. Below you will find a screenshot of the error message I have faced.
    Thank for your attention
    #18344
    Sabin
    You might have already figured out the solution, but I’m just leaving these comments in case anyone needs it in the future. The problem you are seeing is because of the incorrect file path to extract data from the hdf file. Once you fix the file path, it should work. Hope this helps.
    #18346
    Sabin
    To add to the above, I noticed the above error appears if the model becomes unstable at any point in the simulation. So, make sure to check if the time step is within the acceptable limit.
    Happy Modeling,
    Sabin
