Welcome to the RAS Solution › Forums › HEC-RAS Help › HDF ERROR BRIDGE SCOUR CALCULATIONS
- This topic has 0 replies, 141 voices, and was last updated 6 years, 5 months ago by Francisco_Z.
October 6, 2019 at 8:03 am #7469Francisco_ZParticipant
Hello to everyone.
I am a fairly new user to the scour calculations tools. Right now, I’m having a HDF Error every time that I run a steady flow plan with the Flow Distribution Locations enabled (needed to compute the scour on the bridge). I’ve run the same Steady Flow File, the same Geometry file, without these flow distributions and there is no problem.
I’ve tried to reduce the length of my reach, hoping that the HDF file generated were also smaller, but it didn’t help.
This is the error message that I’ve been getting.
Steady Flow Simulation HEC-RAS 5.0.7 March 2019
Subroutine HDF_ATTRI_SCALAR_CH
HDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0:Computations Summary
Completing Geometry(64) <1
Steady Flow Computations(64) 1
Complete Process 2
#000: ..\..\src\H5D.c line 170 in H5Dcreate2(): unable to create dataset
major: Dataset
#001: ..\..\src\H5Dint.c line 439 in H5D__create_named(): unable to create and link to dataset
major: Dataset
#002: ..\..\src\H5L.c line 1638 in H5L_link_object(): unable to create new link to object
major: Links
#003: ..\..\src\H5L.c line 1882 in H5L_create_real(): can't insert link
major: Symbol table
#004: ..\..\src\H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal failed
major: Symbol table
minor: Object not found
#005: ..\..\src\H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator failed
major: Symbol table
minor: Callback failed
#006: ..\..\src\H5L.c line 1685 in H5L_link_cb(): unable to create object
major: Object header
#007: ..\..\src\H5O.c line 3015 in H5O_obj_create(): unable to open object
minor: Can't open object
#008: ..\..\src\H5Doh.c line 293 in H5O__dset_create(): unable to create dataset
major: Dataset
#009: ..\..\src\H5Dint.c line 1044 in H5D__create(): unable to construct layout information
major: Dataset
#010: ..\..\src\H5Dchunk.c line 551 in H5D__chunk_construct(): chunk size must be < 4GB major: Dataset minor: Unable to initialize object HDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0: #000: ..\..\src\H5A.c line 242 in H5Acreate2(): not a location major: Invalid arguments to routine minor: Inappropriate type #001: ..\..\src\H5Gloc.c line 253 in H5G_loc(): invalid object ID major: Invalid arguments to routine minor: Bad valueI’ve read that some fellows have resolved the issue by downloading the HDF software and tools, but to be honest, I’m not sure how to apply these solutions.
Thank you all in advance.
