  • #7483
    Has anyone had the following error running RAS 5.0.7? It’s a 2D model only. The error appeared after 37 hours of computation time, still on the first half of the rising limb of the largest inflow hydrograph. In the previous run it appeared after about 10 hours of computation time. I’ve tried removing hdf files as noted as a fix for other hdf errors but that doesn’t help. Reruns don’t necessarily stop at the same time. There’s nothing odd that I can see happening at the computation points at which it stops. I have had versions run to completion. Suggestions of where to start to debug and get to run?
    Subroutine HDF_Q2D_Write_REAL
    +Time= 0.0000 31DEC1999 24:00;ITER= 0
    #12555
    Ran the model on the c drive instead of the network and no longer had the problem.
