• This topic has 5 replies, 1,669 voices, and was last updated 7 years ago by Anonymous.
  • #7015
    This is the error that im getting
    Geometric Preprocessor HEC-RAS 5.0.5 June 2018
    Finished Processing Geometry
    Starting to copy Geometry Data to Results
    Completed copying Geometry Data to Results
    Performing Unsteady Flow Simulation HEC-RAS 5.0.5 June 2018
    Subroutine READ_UN_Q2D_BC
    SA: gee BCLine: ds
    Check that all of the boundary conditions appear correct
    Computations Summary
    Completing Geometry(64) 1
    Preprocessing Geometry(64) <1
    Complete Process 1
    #000: ..\..\src\H5A.c line 626 in H5Aopen_by_name(): can't open attribute
    major: Attribute
    minor: Can't open object
    #001: ..\..\src\H5A.c line 876 in H5A_open_by_name(): unable to load attribute info from object header
    major: Attribute
    #002: ..\..\src\H5Oattribute.c line 537 in H5O_attr_open_by_name(): can't locate attribute: 'Face Point Indexes'
    major: Attribute
    minor: Object not found
    #11659
    appears there is an issue with your downstream boundary condition called ds.
    #11660
    Hey, do you solve that problem? i have the same erro and i don´t know what to do
    #11661
    I had a simmilar problem.
    I solved it just moving the downstream BC line outside of the perimeter.
    My downstream BC was ‘Normal Depth’
    I hope that works for you.
    #11662
    JValdes.
    Mucho capo!! gracias
    Thank you, I also have my BC line inside. Solved it with your help!
    #11663
    uribealdo
    Many thank, I had the same problem, but I solved with your help
