Welcome to the RAS Solution Forums HEC-RAS Help Hacr Ras 2D, basic question. Hydraulic table.
  • This topic has 4 replies, 155 voices, and was last updated 6 years ago by Anonymous.
  • #7425
    I have another basic Her-Ras question. In the ras mapper, in Geometry->2D flow Area, if right click, there is the command Compute 2D flow areas Hydraulic Table. I never use it, and now I am wondering if this is something that the software do automatically, or if the user must do every time…
    thanks
    #12492
    no one can help me?
    #12493
    NMP
    As far s I know, software does this automatically every time after you press run. If you don’t do this before hand, the run just takes a bit longer.
    #12494
    Lonnie A
    yes done automatically but you can preprocess ahead of time using this feature
    #12495
    ckatsoulas
    The only time you would use it manually is if you have a SA/2D connection say for a culvert and you wanted to set the weir to the existing ground levels using the new automatic feature. You need to compute the hydraulic table before you can use this feature to match the weir levels with the ground levels.
