Welcome to the RAS Solution Forums HEC-RAS Help GIS Data Export for Ineffective Areas?
  • #7089
    Does anyone know how to or if you can export the GIS data for ineffective flow areas along your cross-sections?
    In RAS Mapper I found that if you right click on your cross-sections then “generate layers”>”ineffective block lines on XS”. This seems to be what I want but it says “No features were generated” when I try it. Maybe this feature isn’t working yet?
    I’ve also tried the GIS Export and checked “Ineffective Areas”, but I’m not sure where that information is stored in the .sdf/.xml.
    Any help would be appreciated. Thanks!
