Welcome to the RAS Solution Forums HEC-RAS Help Getting Negative Flows and this error
  • #7318
    While unsteady simulation I am getting high depth at upstream cross sections and while proceeding towards downstream the depth is reducing and inundation is not coming prpoerly. I am running with 3 months daily time series. In the view summary output table, the computed flow values at downstream cross sections are giving negative values.
    Q tot Depth WSE
    9.97 0.41 315.31
    -1.55 0.04 314.57
    0.97 0.09 314.67
    -30.17 0.52 315.64
    6.61 0.17 314.81
    1.02 0.10 314.70
    475.81 1.23 317.14
    -7.87 0.00 314.50
    5.37 0.21 314.87
    -0.11 0.00 314.50
    #12272
    The problem is most likely caused by the downstream boundary condition being incorrect. Suggest that you check that what is being used is consistent with the situation being modelled.
